Author Topic: Want to start sawing, Will frozen logs mess up my mill??  (Read 7417 times)
Offline Valley Mick
  • Red Necks have more fun.
« on: March 28, 2010, 11:43:11 AM »
Got a question.  Was wondering how to tell if a log is frozen, and if it will mess with sawing it.  Want to cut up some poplar (aspen).
It's been above freezing for a little while off and on.  Gettin the sawing itch.  Have been told frozen logs will mess a band mill up fast.  Is this hog wash or not???
But have also been told winter is a good time to saw cedar logs???  Is this a matter of opinion or is there a reason behind it.  Thanks alot
Why do you always realize it was a bad idea after sometin's BUSTED !
Offline red oaks lumber
Re: Want to start sawing, Will frozen logs mess up my mill??
« Reply #1 on: March 28, 2010, 12:08:18 PM »
wew saw all year long, frozen wood wont bother anything
Offline sdunston
  • New York (the great tax state)
« Reply #2 on: March 28, 2010, 12:56:02 PM »
Same here, they say less hook angle and keep the feed rate the same but slow down blade speed. On the other hand I have used 10deg blades on frozen hemlock with no problem,,dust just freezes on the boards.
Sam
WM LT28, American fordge 18x8 planer,Orange and white chainsaws, NH TC33, IHT6 dozer, IH-H tractor and alot of other stuff that keeps me agravated trying to keep running
Offline ladylake
« Reply #3 on: March 28, 2010, 01:28:55 PM »
4* hook works good, a liitle less set will keep the sawdust from packing behind the blade.   Steve
Timberking B20 14000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline Toolman
  • "DONT TREAD ON ME"
« Reply #4 on: March 28, 2010, 09:18:51 PM »
I've heard the ice crystals may be harder on your blades(dull quicker), but I've never really noticed much of a difference. Cant say that about chainsaw blades though. Ice will dull them pretty quick.
"A government big enough to give you everything you want, is strong enough to take everything you have" (Thomas Jefferson)
Offline stumpy
  • I feel alot more like I do now than I did before
    • Rustic-woodfurniture/Stumpy's Wood Works
« Reply #5 on: March 28, 2010, 09:39:49 PM »
I've found that frozen logs are no problem, but partially frozen give me alot of trouble.
Woodmizer LT30, NHL785 skidsteer, IH 444 tractor
Offline dad2nine
  • If you aren't making mistakes, your not doing nothing
« Reply #6 on: March 28, 2010, 09:47:41 PM »
Personally I like sawing logs that are frozen a lot better than not frozen. The log just lays there and the board come off as flat as can be - it's like sawing a log with zero stress  :)
Offline dad2nine
« Reply #7 on: March 28, 2010, 09:48:33 PM »
Personally I like sawing logs that are frozen a lot better than not frozen. The log just lays there, the band sings a nice song and the board come off as flat as can be - it's like sawing a log with zero stress  :)
Offline Puffergas
    • Puffergas
« Reply #8 on: March 28, 2010, 11:25:24 PM »
Just look out for frozen mud on the surface of the log.  >:(
Somewhere 20 miles south of Lake Erie.
GEHL 5624 skid steer, Trojan 114, Timberjack 225D, D&L SB1020 mill, Steiger Bearcat II
Offline paul case
  • Original wearer of the PCM.
« Reply #9 on: January 16, 2011, 10:26:32 AM »
related to this,
do any of youall notice blades dulling faster with frozen logs?
i sawed a little this last week. it was frozen post oak. i noticed that my blades didnt last as long. i was using new blades. usually i get 400 to 500 ft on a new blade and i was actually only getting 300 ft or less. i started with a new blade and sawed 1 log into 8 2x12-16' and some flitches and made 2 cuts on the second log and it was getting dull. put on another new one and sawed 2 more logs and had to change it. the third blade finished the job that totalled 870ft. logs were not skidded and were real clean. my feed speed was much slower than normal but that may be because i am a pansy when its cold. pc
pc
« Reply #10 on: January 16, 2011, 10:56:03 AM »
we might have a little shorter blade sharpness in frozen wood but sawing too slow will dull your blade also.push the feed speed as hard as you can ,to the point of band wave then back down just a touch
Online terrifictimbersllc
    • Terrific Timbers LLC
« Reply #11 on: January 16, 2011, 11:12:21 AM »
I like sawing frozen and use 9 degree blades.  One problem I've had is determining whether the wood is sound, when there are lines or seams, etc, it isn't always easy to tell if it's a natural coloration or a crack.  Sometimes water in voids leaves boards looking like the wood is filled with epoxy, it looks great but you know it might not be.  It can be a problem if you're not sure boards are meeting the customer's requirements.  Throwing down the board hard is one test.
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide,  LogRite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #12 on: January 16, 2011, 05:33:07 PM »
I will never know.   ;D
Offline Kansas
  • In the mountains of Kansas
« Reply #13 on: January 16, 2011, 05:48:18 PM »
The 1 1/4 blades resaw blades do okay on frozen wood. The 1 1/2 inch wide blades do okay on the Woodmizer. We reduce the hook angle down to about 8 degrees. The 2 inch wide blades used to not cut worth a hoot in frozen logs. We tried everything; hook angle, set you name it. They would wave all over the place.This year, where we switched to Kasko .45 thick blades, as opposed to the .55 Woodmizer blades, they are cutting darned good in frozen logs. It makes no sense. I can't explain it.
Offline bugdust
« Reply #14 on: January 16, 2011, 06:41:50 PM »
I finally got to saw a few white pines last week and found the surface was froze hard enough that I had trouble getting the chain saw into the log. Once I began milling, the 10 went easily through the log. I began by leaving a few boards on the cant before off bearing and found them froze together. From that point I pulled each board separately. I've never sawed completely frozen logs, but these guys say to use lesser degree pitches. Since I don't depend on sawing through cold weather I stay content sitting close to the fire.
Since I retired I really like work: It fascinates me. I can sit and look at it for hours.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #15 on: January 16, 2011, 08:44:46 PM »
I use woodmizer .55 1/1/4 7s cuts all wood here good, froze or not   8) 8)
A&P saw Mill LLC.
License NH softwood grader.
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
« Reply #16 on: January 17, 2011, 01:23:53 AM »
A few issues I've had with frozen logs ...
1) When the log is cold enough to freeze the sapwood, you'll sometimes find your blade tries to follow the interface between the heartwood and the sapwood. It's fine when the blade is buried in the sapwood, or when it's cutting deep into the heartwood.
2) When the surface of a log has ice or frozen snow on it, even very small amounts of dirt will dull your blade quickly. The ice traps the particles of dirt and prevents the blade from blasting them out as the tooth passes. This is especially true on the exit side. I've seen sparks flying off the blade where it exits a frozen log.
3) Slabs and flitches freeze to the cant.
4) Frozen logs can be hard to clamp and will sometimes roll on your opening cut.
5) Icy logs can slip all over the deck of the mill when you load them, and often won't stay put when you try to turn them to just the right position.
6) Icy sawdust can build up on everything. Be sure to clean all the surfaces as soon as you finish sawing -- especially inside the blade housing.
I don't think ice itself will cause a blade to dull. A few years ago the Wood-Mizer Way had an article about sawing blocks of ice on a band mill.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Issues sawing frozen logs with swing mill?
Started by terrifictimbersllc on Sawmills and Milling
Last post February 13, 2015, 12:22:12 PM
by logboy
Sawing Frozen Oak with Circular Mill
Started by Thomas Ruga on Sawmills and Milling
Last post January 26, 2013, 12:34:14 PM
by KnotBB
Quick question and i hope i don't start a mess
Started by sgtmaconga on Sawmills and Milling
Last post December 08, 2006, 07:43:51 AM
by DanG
When you can't take the logs to the mill........sawing in the woods
Started by cutterboy on Sawmills and Milling
Last post July 01, 2012, 10:13:10 PM
by JoeBrittany21
