Author Topic: Mobile Deminsion teeth  (Read 2142 times)
Offline John Woodworth
« on: April 02, 2010, 01:23:55 PM »
Have any of you Mobile Dimension owners found a source for teeth other than MD.
Two Garret 21 skidders, Garret 10 skidder, 580 Case Backhoe, Mobile Dimension sawmill, 066, 046 mag, 044, 036mag, 034, 056 mag, 075, 026, lewis winch
Offline DanG
Re: Mobile Deminsion teeth
« Reply #1 on: April 02, 2010, 02:58:46 PM »
I'm pretty sure you can get them from Menominee Saw, one of our sponsors, but when I called a couple of years ago they didn't have the Stellite teeth.
Offline sigidi
« Reply #2 on: April 03, 2010, 03:51:18 AM »
You guys on mobile dimension saws, do you use TCT tips? and what size are they?
As DanG said, it's always nice to use a forum sponsor ;)
Offline DanG
« Reply #3 on: April 03, 2010, 10:22:54 PM »
I don't know what a TCT tip is, but the MD blades use an insertable "3 pattern" tooth.  It is an older style and is getting hard to find.  They are made in solid steel, chrome, carbide, and Stellite, which is a patented alloy.
Offline sigidi
« Reply #4 on: April 03, 2010, 10:37:15 PM »
TCT is Tungsten Carbide Tooth - the kind of teeth we use on a Lucas and like most circular blades in skilsaws and the like
Offline bandmiller2
« Reply #5 on: April 04, 2010, 08:21:50 AM »
Dan,how do you sharpen your bits,especially the stellite and chrome.A box of 100 bits must last just short of forever.Frank C.
Offline DanG
« Reply #6 on: April 04, 2010, 09:36:26 AM »
You're right Frank.  When I got my mill in early '02, it came with 50 new teeth of each size, and I'm still using on them.  I did buy some more last year, but still using the old ones.  Of course, I ain't doing much sawing anymore.
I don't have a good way to sharpen on the mill, so I just change them out, then resharpen on the bench grinder.  If they're not chipped, it only takes about a nanosecond.  I keep a couple of sets ready to go in some little ziploc bags, so it only takes about 5 minutes to change'em out. :)
Offline sigidi
« Reply #7 on: April 05, 2010, 12:42:07 AM »
Any chance of seeing a pic of these teeth?
Offline oakiemac
  • God bless the U.S.A!
    • Hickoryandoak
« Reply #8 on: April 05, 2010, 04:44:31 PM »
I buy some of my teeth from Menominee saw. They are iron teeth so you have to sharpen more often. I usually put them on if I am sawing logs with possible metal because they are considerably cheaper and easier to sharpen. The stellite teeth from MD do last a lot longer but if you hit metal and take out a corner of the tooth then it is hard to get them back to good.
How Mobile is the Mobile Dimension Mill?
Started by Mulekicker on Sawmills and Milling
Last post June 20, 2015, 07:38:32 AM
by dgdrls
Mobile Dimension - Mobile MFG
Started by willysjeeps on Sawmills and Milling
Last post October 31, 2017, 10:24:29 AM
by DanG
Has anyone seen my teeth?
Started by Sprucegum on Sawmills and Milling
Last post November 10, 2008, 12:59:47 AM
by Sprucegum
All teeth...
Started by Kbeitz on The Outdoor Board
Last post September 06, 2017, 07:50:31 AM
by Chuck White
