Author Topic: Blade selection  (Read 1736 times)
Offline Chuck White
  • Sawing Mobile since 2005
Blade selection
« on: April 19, 2010, 10:55:36 AM »
What is the best 1.25" Wood-Mizer band for sawing White Spruce on an LT40 with a 24hp motor?
Using the 10° band with 22-24 set ain't working very well, I get wavy lumber.
Even with a fresh band.  Running fast or slow.
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline coastlogger
Re: Blade selection
« Reply #1 on: April 19, 2010, 11:28:02 AM »
Have you tried more set?Like 28 or 30?
clgr
clgr
Offline pnyberg
Re: Blade selection
« Reply #2 on: April 19, 2010, 12:30:03 PM »
I'm currently cutting spruce for a customer, and having some problems with wavy cuts as well.  I'm using new DoubleHard 1.25" 9 blades.  I don't have a setter, so the set is whatever they put in at the WM factory.
I think being generous with the lube helps.  I'm using water with a cup of Pine-Sol per 5 gallons.  I'm also learning to pay closer attention to the tension gauge.
The thought had gone through my head that maybe I should try 10 blades instead, but I guess that wouldn't help.  :)
--Peter
No longer milling
Offline John_Haylow
  • "If you are going through hell, keep going." W.C.
Re: Blade selection
« Reply #3 on: April 19, 2010, 09:24:16 PM »
Chuck, I have been using the 7* blades with very good results
2004 Wood-Mizer LT40HDG28
Offline woodmills1
  • the truth shall set you free
Re: Blade selection
« Reply #4 on: April 19, 2010, 09:34:00 PM »
spruce bad :D hard :o to   havent done well yet unless new 7 degree  :D ;D 8) knots to hard
Offline ladylake
Re: Blade selection
« Reply #5 on: April 20, 2010, 05:25:41 AM »
Less hook, more set.     Steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline petefrom bearswamp
  • 70-12 still feel pretty good and going to retire
Re: Blade selection
« Reply #6 on: April 20, 2010, 06:07:57 PM »
Had a major problem with Norway spruce and got some 7 * blades , .055 1-1/4 had set of .028 to .030.from WM.
worked better but still had some wavy lumber.
Logs were 20" plus.
Pete
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo vintage Homelite super xl12
241 acres of woodland
Offline sgschwend
  • My new Brand X sawmill
    • Brideck Enterprises Portable Sawmill Service, Washington
Re: Blade selection
« Reply #7 on: April 20, 2010, 07:10:50 PM »
I love cutting spruce, it is my most favorite wood.  However, it is Sitka Spruce here.
http://www.na.fs.fed.us/spfo/pubs/silvics_manual/Volume_1/vol1_Table_of_contents.htm
Good reference, I am guess you are not cutting white spruce unless you are in Alaska or Canada.
Offline Chuck White
Re: Blade selection
« Reply #8 on: April 20, 2010, 08:12:05 PM »
Well, we're not in Canada, but almost!
We're about 35 miles from Canada in the upper-most part of New York.
There is a lot of White Spruce here, and the best of it was hand-planted in the 30's & 40's.
There are some scattered wild White Spruce, here and there.
Looks like I need a 7 blade to make a decent cut, I think I'll stick with the 1x.045-158 WM blade on the LT40.
~Chuck~
Bandsaw blade selection
Started by Farmer Jim on General Woodworking
Last post July 19, 2014, 02:07:57 PM
by Farmer Jim
Blade selection question
Started by AnthonyW on Sawmills and Milling
Last post September 16, 2014, 09:29:23 PM
by AnthonyW
More Blade Talk and Selection
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post November 11, 2014, 08:10:41 PM
by AnthonyW
Band Blade Selection
Started by Shawn on Sawmills and Milling
Last post February 24, 2006, 09:27:14 PM
by LeeB
