Author Topic: The real cost of bands? Swing mill have lower cost?  (Read 5936 times)
Offline ARKANSAWYER
  • Poor white Southern trash
Re: The real cost of bands? Swing mill have lower cost?
« Reply #20 on: May 08, 2010, 06:30:31 PM »
Sigidi,
  On a band mill like the LT70 you will go through 3 or 4 blades a day sawing like we do if you do not hit any FOD while sawing out between 4,500 to 6,000 bdft.  On the LT40 I use 2 or 3 blades a day with no FOD and will cut 1,500 to 2,500 bdft of lumber.  Both machines have de-barkers.
  But I can saw 1x12's very easy and faster then a swing mill.  I can saw an 8" log just as easy as a 30" log so band or swinger have their limits and merits.
  With circle blades the start up cost is higher but over time the cost per bdft drops to very low.  With my scragg mill the blades cost about $900 each and it cost $40 to put in new insert teeth.  By the time I file them a few times and get ready to replace them my cost is some where around $0.0008 bdft which is alot lower then my band cost of around $0.012 bdft.
ARKANSAWYER
Offline Meadows Miller
  • Location: Find a Job You Love & You Will Never Work Another Day In Your Life
  • The Walkabout Sawyer
« Reply #21 on: May 08, 2010, 07:20:44 PM »
Gday
Arky are you running 1 1/2 or 2" .050 & and .055 bands on the lt70 Mate also 4500 to 6000 is bloody good going production but I would expect it with the setup you have  ;) ;D 8) 8)   how many do you have working with you on the lt70 and edger Mate ? Allan thats 10.6 to 14.1 m3 sawn per day Mate
Regards Chris
4TH Generation Timbergetter
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #22 on: May 08, 2010, 08:23:14 PM »
A box of 15 blades .045x158"x10 degree sells for $330.00. That is $22.00 per blade. If you sharpen your blades yourself, and you get 6 sharpenings, then your blade  cost is really $3.00.  Thanks
I would think that the initial cost of the resharpener should figure into the formula somewhere  ???
Offline sigidi
« Reply #23 on: May 09, 2010, 06:25:53 AM »
Yeah good point MM, how much does the average sharpener for bands go for? with the Lucas we get our sharpener as part of initial purchase.
As for doing my own tips... I have thought about it, but then I'd need to send 'em off to get hammered/tensioned anyway and I figure I am good at the sawing but would have to learn the saw doctoring all from scratch and any of our mills are only as good as our blades/bands right? so then I'd be going out on jobs and not be 100% confident I have the best set-up I can for my customer until I have done a whole whack of learnin on saw doctorin... just my spin on tipping.
Always willing to help - Allan
Offline ARKANSAWYER
« Reply #24 on: May 09, 2010, 04:39:05 PM »
 I am running 1 1/5 wide, 0.055 thick, and 10 degree bands from WM  There is a 3ph edger and 3 men standing behind me.  I saw standing at the front so I can see the boards so I know grade and when to flip the cant.  I have never figured out how to saw from the back of the mill as opening cut is important as much as grade.
  If we get into pine or really good logs it is not a problem (for me and the LT70) to do 8,000 bdft a day.  How ever the electric motor is not very loud and I here lots of whinning behind me.  ;D
ARKANSAWYER
Lower Cost Portable Mill
Started by KiwiCharlie on Sawmills and Milling
Last post June 25, 2002, 10:04:27 PM
by Bro. Noble
real cost of electricity
Started by r.man on General Board
Last post March 12, 2016, 05:15:58 PM
by Mooseherder
What does it cost to mill a tie?
Started by Bill H on Sawmills and Milling
Last post October 17, 2005, 09:46:57 PM
by Bill H
Running cost statistics on your mill please??
Started by Wife on Sawmills and Milling
Last post March 07, 2005, 03:05:27 AM
by Wife
