Author Topic: mill shaking  (Read 1787 times)
Offline bushhog920
mill shaking
« on: May 24, 2010, 12:29:45 AM »
I have a norwood mark 3 15hp and it has a problem of shaking side to side,  worse with hardwoods. i sharpen and set my own blades with a cooks sharpener to 10deg. and use simmons 1 1/4 X 7/8 . i know it is a light duty mill and thought of beefing up the frame some but before i do that any ideas on how the settle it down? would changing the hook angle to less help?
Offline paul case
  • Original wearer of the PCM.
Re: mill shaking
« Reply #1 on: May 24, 2010, 12:39:45 AM »
mine is not a norwood but it will shake some if i try to feed it too fast on too big a log. could be you are using too mch angle on the teeth for hardwoods. most use 7 at the most some even recomend 4. depends on what you are cutting.pc
pc
Offline bandmiller2
Re: mill shaking
« Reply #2 on: May 24, 2010, 06:10:50 AM »
Bushhog,is your mill supported its whole legnth sometimes the center of the mill that carries the most weight will settle and be left unsupported allowing movement.Anouther thing be sure one or two teeth are not overset,that will cause movement as they come around.Frank C.
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
Re: mill shaking
« Reply #3 on: May 24, 2010, 06:12:44 AM »
Check the mill alignment. After you take a cut do not lift the saw head. Will the blade scrape the sawdust off the cant? If not check the alignment.
Marty
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
Offline ladylake
Re: mill shaking
« Reply #4 on: May 24, 2010, 06:38:54 AM »
  If it does it with a new blade it might be time to beef up the frame, on my last saw job they were describing the same thing about thier nieghbors Norwood.    Steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline sawwood
Re: mill shaking
« Reply #5 on: May 24, 2010, 07:31:10 AM »
 We have a Norwood mark 4 and on large logs we git the shaking if feeding to fas and have to
 stop some time. Also we find that the center suports are loose and it helps some after we tighen
 it up. We have a mixbag of blades and that might be some of the trouble. Going to try some of
 the WM 7 deg blade soon.
 Sawwood
Norwood M4 manual mill, Solar Kiln, Woodmaster
18" planer/molder
Offline nas
  • Measure twice and cut aw DanG
    • Traditional forest products
Re: mill shaking
« Reply #6 on: May 24, 2010, 07:31:57 AM »
I had the same problem with my Norwood but only when I cut dry oak timbers.  I heard of someone who put bracing cables with turnbuckles from corner to corner at the top of the frame.  Said that helped.
Better to sit in silence and have everyone think me a fool, than to open my mouth and remove all doubt - Napoleon.
Indecision is the key to flexibility.
2002 WM LT40HDG25
stihl 066
Husky 365
1 wife
6 Kids
Offline pineywoods
Re: mill shaking
« Reply #7 on: May 24, 2010, 10:25:01 AM »
Too much hook angle and or too many teeth per inch. I sharpen blades for a neighbor with a norwood. We've played around with various blade configurations. 1 inch tooth spacing and low tooth angles seem to work best. Tried a couple of blades with 15* hook. It shook like a wet dog, even in small pine logs.
Re: mill shaking
« Reply #8 on: May 24, 2010, 11:19:53 AM »
trash beneath the band wheel tires will make the head shake too.  You got v-belts for tires?
saw head shaking
Started by sawwood on Sawmills and Milling
Last post May 15, 2008, 09:20:18 PM
by sawwood
Mission Impossible, and then we mill. Tighest spot you've gotten your mill into?
Started by Delawhere Jack on Sawmills and Milling
Last post May 05, 2013, 06:10:18 PM
by Delawhere Jack
TK 1220 mill owners??? comments and mods for your mill?
Started by opticsguy on Sawmills and Milling
Last post August 16, 2016, 08:21:50 AM
by deepsouth.us
Mackinaw Mi. Water powered saw mill Mill Creek
Started by jimparamedic on Travel Guide
Last post April 12, 2019, 02:56:29 PM
by jimparamedic
