Author Topic: Understanding GVW ratings for gooseneck trailers and their load capabilities...  (Read 69800 times)
Offline mahonda
throw some rock in the box it helps tons!
"If your lucky enough to be a logger your lucky enough!"
 Burly aka Dad
Offline T Red
LD have you looked in your owners manual to see what the Gross Combination Weight Rating is?  It varies a lot by truck, even the same brand with different builds.
In my experience this was the limiting factor.  So I ended up buying a single axle road tractor and lowboy for my needs.  With it I can legally haul 37,000.  The worst thing about it is the tags and yearly dot inspection.  I do the inspection on mine but most people would have to have a garage do it.
The good...  it was cheap, it's surprisingly reliable
The bad it needs a new radiator core, and it may make more sense to just get another truck.
Tim
Offline LOGDOG
Hmmmm ...I'll take a look and see what it is.  :)
Offline Bobus2003
I was using a '06 F350 Crewcab Single Rear wheel Powerstroke 6spd 11,200 lbs GVWR and a 32' GN 20K lbs. GVWR trailer to haul my equipment JD440, JD550G, Link Belt 1600 Excavator, 1845 Skid Steer. I got a CDL so thats not a problem.. Never been stopped or hassled about the loads.. Here a few months ago i did Upgrade to a '06 F450 powerstroke.. Makes towing a little better, but don't really notice any differnce from my F350. Manual tranny Helped my F350, where the Auto Sucks.. (F450-F550 Chassis Cabs have De-tuned Powerstrokes From the F250, F350 Powerstrokes)
Offline Gary_C
  • Sunrise on the Prairie
Chances are you will not like what you find and I don't know of any laws that limit you to that number. For the most part, the GCVWR is used by the manufacturers to limit their liability. And then at the same time they advertise those pickups pulling some huge loads and then tell you not to try this with your vehicle. You know the drill.   :)
As I said before, tire ratings are the number one limiting factor. Second would be axle loads, not necessarily ratings. And third would be total combined load, not necessarily ratings. Also you can be ticketed for both overweight on an axle and/or total load as well as being overweight on your license. But I've never heard of any law that you can be ticketed directly for being over your GCVW rating.
Offline Bobus2003
Had the Center of my Clutch disk Tear free on my '06 F350 at 26K miles or so. Destroyed the Throw out bearing and the clutch Disk and center came out in pieces.. When i got the new clutch in there Ford told me the reason for my failure was i was towing too close to my Maximum Vehicle Tow Rating.. I called BS on that (I have exceeded it many times) but thats no reason for a clutch disk to Tear apart
Offline Ironwood
    • http://www.branchandburl.com
I had a South Bend 450 HP clutch (same as OEM only heavier) rip the rivets out of the center, spun it just fine >:( South Bend gave me half off the new clutch, but no labor or tow, this was at about 20,000 miles after install. Unit was still in good shape, just rivets broke. I think the new one had upgraded that engineering defect. I think I get them from Black Cloud deisel'
 Ironwood
Offline T Red
I agree with what you've said.  As far as the law I have not seen it either although that is true for many laws.  We had a couple of dmv officers at a cattleman's meeting, they stated they would go by the gcvwr of the towing vehicle, along with the tires, axles etc.  The disappointing part of the meeting was they themselves could not completely agree on most of the rules.  The same laws they write tickets for everyday.  ???
I don't follow you here.  What are you considering the difference in axle load and ratings.  Are you saying you can be over the axle rating and be legal?  Where's the limit if you go by the combined load and disregard the  truck rating?
  Been there with a class 8 truck, but don't see how this would apply to a light truck unless you followed the manufactures axle wt rating.  10k on a 1 ton w/ duals, which is much less than the 20k allowed by the feds.
Tim
Tim
Offline Gary_C
On a pickup with a dually axle, the axle could be rated at say 10,000 lbs and with four 3000 lb rated tires you could legally carry about 12,000 lbs. What the axle rating is saying is that your springs are not rated for 12,000 lbs, but there are no laws for being over loaded on your springs.
So essentially the gross axle, vehicle, and combined ratings are more about your springs, drive train, and brake capacity. And there are no actual laws that I know that will prevent you from abusing those components.
But as you said, these DOT enforcement guys are unpredictable and don't always follow the letter of the law.
Offline T Red
So if you could distribute the load over all the axles on a 1 ton w/ duals and tandem duals on trailer
truck "E" rated tires.  I wish I could find "G's" for my truck.
     front axle 6000
     rear axle   12000
trailer "g" rated tires
     tandem duals  28000
totaling    46000
minus the truck and trailer wt say 17000 (guessing here) the payload would be 29000.  Talk about dangerous, you may get it moving but stopping?
I believe the NC DMV would find a violation to write you up on if they seen that load.
Tim
Tim
Gooseneck Log trailers w/ Grapple
Started by RKONeilJr on Forestry and Logging
Last post October 01, 2016, 09:37:28 AM
by bigblue12v
Stupid question about gooseneck trailers.
Started by Old Greenhorn on Forestry and Logging
Last post December 10, 2019, 07:43:59 AM
by florida
Load Trail Gooseneck Trailer
Started by Corley5 on For Sale
Last post June 30, 2018, 11:32:09 AM
by Corley5
A nice days cutting worth of Sycamore and a gooseneck load of smaller tie logs .
Started by RayMO on Forestry and Logging
Last post March 05, 2014, 08:38:11 AM
by RayMO
