Author Topic: Quality of cut.  (Read 4720 times)
Offline AtlanticAcres
Quality of cut.
« on: June 28, 2010, 07:46:28 AM »
My buddy bought a mill and we are having fun. We sharpened the blades and set the kerf. We are getting a 'feather' edge along some of the boards.
The feathers are strains of wood not completely cut off and only occur on the 90 degree edge. Doesn't happen all the time. Can someone explain.
TIA - AA
Work hard to get it down - play like tomorrow may end!
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Quality of cut.
« Reply #1 on: June 28, 2010, 08:00:00 AM »
Are different species different/worse than others.  What you describe, to me, is stringing or tearing rather than cutting.  That is one of the indicators that I use to determine if a band has dulled and is in need of being changed.
And welcome back.  How is the kitchen floor?
Offline Chuck White
  • Sawing Mobile since 2005
Re: Quality of cut.
« Reply #2 on: June 28, 2010, 09:29:19 AM »
Welcome AtlanticAcres.  ;)
I agree with most of what Magicman said, but I sometimes find that the same thing happens when the blade is pushed a little too fast!
I've only ever had it happen with Pine, Poplar and a few other softwoods.
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline tyb525
  • Always learning.
Re: Quality of cut.
« Reply #3 on: June 28, 2010, 09:37:12 AM »
It also seems to depend on which way the grain is running. I've had it happen in almost every species I've cut.
Re: Quality of cut.
« Reply #4 on: June 28, 2010, 10:20:13 AM »
Thanks guys.
We are milling pine and spruce. And yes we are probably pushing the mill too fast.
TIA
Re: Quality of cut.
« Reply #5 on: June 28, 2010, 04:03:53 PM »
Magicman,
Kitchen floor is complete along with new cabinets. Also, I ran into rot this spring in the porch and had to rebuild. I tried uploading images (mac based here)
but found it frustrating...
Re: Quality of cut.
« Reply #6 on: June 28, 2010, 04:23:01 PM »
Ok... try this. Link to Forest Forum Gallery. This shows rebuild of porch with 1x12 boards. I used hand forged wrought 2.5" nails for floors.
I pre-built flooring - ship lap - and pre-stained before installing.
I will add photos of mill and other stuff... my currant project is building a post and beam addition to my workshop that will become a green house among other things.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Quality of cut.
« Reply #7 on: June 28, 2010, 04:29:36 PM »
You have done the hard part.  Now, all you have to do is start your post, open your gallery in another window, click on the photo you want to post, and then click on this sentence that will be just below the photo "Click here to copy this photo code directly to your Forestry Forum post window".   Then click preview to see the results of the photo added to your post.
Re: Quality of cut.
« Reply #8 on: June 28, 2010, 04:33:06 PM »
Ok... here goes.
The red colour will change this fall to an ocher... we are still discussing! :D
Re: Quality of cut.
« Reply #9 on: June 28, 2010, 04:47:45 PM »
These images show kitchen cabinet build plus floor of kitchen. I apologize for posting in this section... but hey it works.
Cabinets are all wood 3/4 and 4/4. Doors were made in my shop with table saw mounted router.
This was part of a kitchen remodel. Floors are 3/4 x11.5" nailed with hand wrought nails, some new, some old.
Enjoy.
Re: Quality of cut.
« Reply #10 on: June 28, 2010, 04:50:51 PM »
Oh... the mill!
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Quality of cut.
« Reply #11 on: June 28, 2010, 05:17:22 PM »
Boy AA, when we got you cranked up, you really took off !!!  Good job with your flooring and cabinets.   :)
Now somewhere when you set up your gallery you add a number to your forum member number which makes the gallery available for viewing by other members. (If you want that.)
Re: Quality of cut.
« Reply #12 on: June 28, 2010, 07:09:54 PM »
OK.  Will do that next!
AA
Re: Quality of cut.
« Reply #13 on: June 28, 2010, 07:31:33 PM »
It's a function of your profile.  I fixed it.
Offline WDH
Re: Quality of cut.
« Reply #14 on: June 28, 2010, 07:38:47 PM »
AA,
I am glad that you got the mill in the pics or we would have had to fine you  :D.
Just kidding!  Nice job.  The cabinets look great!
Re: Quality of cut.
« Reply #15 on: June 28, 2010, 07:57:19 PM »
Thanks all.
I had fun building the cabinets but realized I need a bigger(don't we all) shop or I have to get ride of a lot of stored house parts.
I also have to think about better heat sources other than a kerosene heater. I am thinking solar and part of the greenhouse attachment will hopefully supply some solar heat to the shop. I am hoping to use the greenhouse to dry some wood too. It will be 12'x22' with a sloped roof - 7.5' at lowest. 10.5' at highest.
WDH - we are starting with this mill. Actually I have two friends that co-bought the mill.
I supply the tractor with forks, and logging winch. The pic of the mill shows our first cut.
We are milling material to get my greenhouse built - albeit - slowly. After that we will be
milling for a permanent structure for the mill.
Our first board cost us about $45,000 including cost of used mill, new tractor, used winch and forks - lol! :D :D :D
I will obey the forum police and post in appropriate areas...
TIA
PS: Ok Tom I trust ya... not sure what ya fixed.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Quality of cut.
« Reply #16 on: June 28, 2010, 10:15:58 PM »
He did the number thing and now your Gallery shows up.  You've got a lot of friends here.
I drove through your home location a few years ago.  Beautiful country.   :)
Offline Meadows Miller
  • Location: Find a Job You Love & You Will Never Work Another Day In Your Life
  • The Walkabout Sawyer
Re: Quality of cut.
« Reply #17 on: June 29, 2010, 09:20:33 AM »
Gday
AA Nice thread and nice pics mate n dont worry about it being micxed topics as its nice to see everything you have been upto Mate  ;) ;D ;D ;D 8) 8) 8) 8) 8)
With the mill it might be that your outer guide might be getting alittle play in it as you move it out as i see your in small logs  ;)
Regards Chris
4TH Generation Timbergetter
Offline Sprucegum
Re: Quality of cut.
« Reply #18 on: June 29, 2010, 09:33:59 AM »
I don't know why you think its mixed topics - no one has mentioned food yet  :-X
What size is that spruce on the mill and what did you get out of it? I try to do some small stuff but my circle mill cuts a pretty wide swathe  :-\
Re: Quality of cut.
« Reply #19 on: June 29, 2010, 10:01:07 AM »
Spruce just knock the sides of em make a 4x4 1/6 then split em up the guts  ;)you dont have to worry about kerf too much then I can get that on a circ on a 6" dia log Mate  ;) :D  :D ;D  ;D 8) 8) 8)
Good quality trees or poor quality trees?
Started by Dobie on Ask The Forester
Last post March 23, 2016, 06:06:47 PM
by SwampDonkey
Cut Quality
Started by Rougespear on Sawmills and Milling
Last post August 03, 2016, 12:07:09 AM
by Rougespear
Air Quality
Started by Ron Scott on Forest Education
Last post June 19, 2004, 04:10:45 PM
by SwampDonkey
Timber Quality
Started by FrankLad on Timber Framing/Log construction
Last post August 30, 2006, 01:53:59 PM
by Jim_Rogers
