Author Topic: hard maple  (Read 1332 times)
Offline abooley
hard maple
« on: July 05, 2010, 08:12:02 AM »
Has anyone had any success using hard maple for framing or siding? How does it weather?
aboo
Offline bandmiller2
Re: hard maple
« Reply #1 on: July 05, 2010, 08:22:10 AM »
Aboo,for outbuildings where twisting and bowing are not a problem its OK not great though,if your going to nail it do it when its green outherwise you may have to drill the nail/screw holes.I'am not sure on the use as siding.Frank C.
Offline abooley
Re: hard maple
« Reply #2 on: July 05, 2010, 09:01:59 AM »
I have a customer who is planning to build a barn. He has a large amount of maple and wants to incorporate the use of the lumber from the maple into the barn. I am thinking that using the maple for framing material would be a better use than for siding since it would be out of the weather. He also has red oak to be cut, this I felt would make better board and batten siding. I suggested using poplar for the framing material. Any thoughts?
aboo
Offline Chuck White
  • Sawing Mobile since 2005
Re: hard maple
« Reply #3 on: July 05, 2010, 10:58:14 AM »
I think either one would make good beams for framing, but as BM2 said, if they're allowed to dry, they'll need to be predrilled.
I'm wondering though, if you were to use a "power nailer", they might nail up ok.
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline OneWithWood
  • I am happy!
Re: hard maple
« Reply #4 on: July 06, 2010, 12:50:14 PM »
I would use the hard maple and oak for the framing.  If kept out of the weather it should be fine.  Use the poplar for the board and batten.
One With Wood
hard maple vs. soft maple
Started by redpowerd on General Board
Last post September 19, 2003, 02:05:58 PM
by redpowerd
Hard Maple
Started by EZ on Sawmills and Milling
Last post October 31, 2003, 04:44:12 PM
by Den Socling
Hard maple
Started by Firewoodjoe on Forestry and Logging
Last post August 25, 2018, 09:47:15 AM
by Ed_K
Is this hard maple?
Started by bakerhardwoods on Tree, Plant and Wood I.D.
Last post June 07, 2013, 09:41:55 AM
by bakerhardwoods
