Author Topic: WM tension on Cooks blades  (Read 1937 times)
Offline petefrom bearswamp
  • 70-12 still feel pretty good and going to retire
« on: July 18, 2010, 06:51:27 PM »
Anyone out there using Cooks super sharp on their WM?
I bought 30 last year (.042, 10*) to try some  and had problems running them at WM specs for .042 blades. Kept breaking at the weld.
Cooks gave me credit for the 10 that broke and i had them re- sharpen some to use the credit up.
The first one i tried from them that had been sharpened broke at the weld on the third log.
pete
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo vintage Homelite super xl12
241 acres of woodland
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: WM tension on Cooks blades
« Reply #1 on: July 18, 2010, 09:13:51 PM »
I know nothing about Cook's tension specifications, but in my opinion, no properly welded band should break at the weld regardless of the tension.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #2 on: July 19, 2010, 07:08:44 AM »
I agree with MM.
I would think that any band, regardless of brand name would stand up to even the highest tension setting on an LT40.
That weld joing is supposed to be just as strong as any spot in the rest of the band.
Did you ask Cook's about tension specs?
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline gator gar
« Reply #3 on: July 19, 2010, 07:30:13 AM »
When you to a weld test down here on pipe, they'll cut out strips perpendicular to your weld and put it a machine and pull those strips til they pull apart. It should break anywhere BUT the weld. Same should apply to a blade.
Offline ladylake
« Reply #4 on: July 19, 2010, 07:41:56 AM »
 I haven't heard any wide spead trouble with Cooks blades breaking at the weld, most likely you got a bad batch, maybe a rookie welding them up.    Steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
« Reply #5 on: July 19, 2010, 04:47:16 PM »
I have been on the phone several times with Cooks.
they are at a loss and also cannot give me tension specs for my WM.
Also I have only been 3 blades down in the box of 10 they sharpened and 2 of them are only touched on the backs of the teeth and on the face of the tooth no grinding evident in the gullet.
I'll check the rest and call cooks tomorrow. Hopefully they will address my problems.
Makes a man want to drink (more)
LT40SHDD51
Kubota 900 RTV
Offline paul case
  • Original wearer of the PCM.
« Reply #6 on: July 20, 2010, 12:05:36 AM »
i havent yet had any problems with the blades from cooks on my ez boardwalk mill except that every time i put one on i hit metal.   pc
pc
Offline ladylake
« Reply #7 on: July 20, 2010, 04:03:26 AM »
 If the first sharpening doesn't hit the whole gullet it's no big deal, a lot of mine are like that, no sence in grinding off more than needed to get them sharp . By the 2nd or 3rd sharpening it should be hitting the whole gullet.   Steve
Offline bandmiller2
« Reply #8 on: July 20, 2010, 05:58:29 AM »
Pete, could be guide or alignment problem try a different brand of band,but that many breaking at the weld smacks of poor welding or annealing.Try less tension.
cooks ss blades- problems?
Started by mike phillips on Sawmills and Milling
Last post January 15, 2019, 09:33:40 PM
by mike phillips
Cupping Band Blades...Too much Tension?
Started by logwalker on Sawmills and Milling
Last post December 19, 2008, 09:40:13 AM
by MartyParsons
question
Low Tension Blades & Urethane Belts
Started by DR_Buck on Sawmills and Milling
Last post February 25, 2004, 02:17:55 PM
by woodrat
moved
MOVED: Cooks 6 weeks where are our blades
Started by Jeff on Sawmills and Milling
Last post July 08, 2012, 07:51:52 PM
by Jeff
