Author Topic: Cleaning Blades  (Read 1085 times)
Offline MrMoo
  • Do you have a spare log dar
Cleaning Blades
« on: November 04, 2003, 06:43:56 AM »
Hi Folks,
My question is about what to use to clean blades that have some pitch on them before sharpening them.
I know there have been topics about this and I did a search but I guess I used the wrong terms because I came up empty. Anyway I hope nobody minds talking about this again.
I know diesel fuel will clean them but since I am doing this in my cellar I was hoping for something a bit less smelly. Don't want to upset the Mrs.
Looking forward to hear what everyone uses.
Thanks,
Mike
Offline woodmills1
  • the truth shall set you free
Re: Cleaning Blades
« Reply #1 on: November 04, 2003, 02:55:40 PM »
I try to remember to spray up my blades and run them a little before I take them off to have them clean before sharpening.  If I forget or there is a lot of buildup that doesnt come off I just take a scraper to them and push it off.  My woodmizer sharpener is pretty forgiving of buildup arount the tip but doesn't like a blade that has gunk all around.  Remember to watch for any stuff right in the bottem of the tooth face gillet area as that will cause the sharpener to push the blade too far and change the geometry fo that tooth.  By the way way back when I started I added lestoil to the water in the sharpener to clean the blades but that wiped the bearings out of the sharpener motor and ruined the pump so.......... :o
Offline MrMoo
Re: Cleaning Blades
« Reply #2 on: November 05, 2003, 06:48:15 AM »
Thanks Woodmills,
I always keep an eye on the gullets. I learned that one the hard way with a blade that hit metal. The metal stuck to the tooth and broke the stone when it went down to grind the tooth.
Mike
Offline bull
  • im getting board on a daily basis  ho hum
Re: Cleaning Blades
« Reply #3 on: November 05, 2003, 01:27:41 PM »
Clean them before you take them off the mill
Open your lube full, and run the blade,I use a hardwood stick w/ a cotton rag and run it over both faces of the blade.
I use Dawn or octagon diswashing liquid in my lube, about two tablespoons per tank full,it does a great job...
                    Bull..
Cleaning blades
Started by Rambjor on Sawmills and Milling
Last post February 10, 2020, 10:17:46 AM
by DDW_OR
Cleaning Blades
Started by Jacar on Sawmills and Milling
Last post February 23, 2003, 06:50:52 AM
by solidwoods
cleaning saw blades
Started by mooleycow on General Woodworking
Last post December 25, 2011, 03:34:09 PM
by D._Frederick
Cleaning saw blades
Started by D._Frederick on General Woodworking
Last post November 02, 2009, 05:43:08 PM
by johnjbc
