Author Topic: Circular sawyers  (Read 1542 times)
Offline bandmiller2
Circular sawyers
« on: August 21, 2010, 08:17:16 PM »
It pays to check the tightness of headblock mounting bolts,especially if you have a wood set beam,alot of mine were loose must be the hot dry summer.Any part of the mill that bares weight will settle with time and movement,especially with wooden foundations.I would not be surprised if even concrete and steel will settle.Myself I use a good carpenters level that I've calibrated with a precision machinests level.Frank C.
Offline r.man
Re: Circular sawyers
« Reply #1 on: August 21, 2010, 09:15:37 PM »
Vibration and temperature changes, the bane of anything that is supposed to be tight. The millwrights where I do electrical repairs from time to time swear by locktite of some sort. I think they keep a couple of different strengths depending on the seriousness of something vibrating loose. Nothing like a large piece of steel going through your headsaw or chipper to ruin your day.
Offline Ron Wenrich
« Reply #2 on: August 22, 2010, 07:26:43 AM »
You'll get settling and metal fatigue in the all steel mills.  We had some of our metal tubing collapse from turning logs.  We had it rebuilt.
Offline paul case
  • Original wearer of the PCM.
« Reply #3 on: August 22, 2010, 08:56:58 AM »
loctite and self locking nuts are great but those wooden parts shrink and they will have to be tightened up from time to time. i dont think there is any way around it.  pc
pc
Offline Autocar
« Reply #4 on: August 22, 2010, 12:14:43 PM »
I had mine on 6x12 I beams tied togather by 6x12 I beams, then the mandrel box which I made out of 6 x12 H iron was tied by 5/8 inch bolts solid to the rails which was bolted to cement pilers. But one late summer when the ground got real dry the pillars did rock a little when turning logs but never had a problem sawing.
Bill
Circular sawyers!
Started by NZJake on Turbosawmill
Last post November 29, 2016, 11:20:41 PM
by NZJake
Circular sawyers
Started by bandmiller2 on Sawmills and Milling
Last post March 06, 2018, 08:51:17 PM
by bandmiller2
MD Sawyers
Last post May 13, 2009, 07:13:30 PM
by StorminN
NH sawyers
Started by woodmills1 on General Board
Last post November 06, 2003, 04:22:57 AM
by woodmills1
