Author Topic: Wavy Cuts  (Read 10137 times)
Offline Meadows Miller
  • Location: Find a Job You Love & You Will Never Work Another Day In Your Life
  • The Walkabout Sawyer
Re: Wavy Cuts
« Reply #20 on: September 04, 2010, 11:53:47 AM »
Gday
Magic was Spot on With his comment that there is a big difference between a Sawyer and someone who Has a Sawmill Mate  ;)
A sawyer who takes pride in their work and  equipment ,how they maintain it and operate it will produce consitant quality Timber Day in Day out Without Fail  ;) and id recomend that you take the time between now and when your current reliable sawyer retires to suss out and find yourself a good one if not persist with this one just put it to him that he wont be getting paid for miss cuts  Mate  ;)
Good Luck
Regards Chris
4TH Generation Timbergetter
Offline LeeB
Re: Wavy Cuts
« Reply #21 on: September 04, 2010, 05:52:27 PM »
Just an addendum to Cris's post. "suss out" means to figure out.
Offline Magic Smoke
  • Is letting the magic smoke out of the wires bad?
Re: Wavy Cuts
« Reply #22 on: September 05, 2010, 11:25:20 PM »
If he has used several blades (especially a new one) and it cuts wavy right off the bat, then the issue is probably not the blade. Something as simple as a loose drive belt can cause wavy cuts... when the belt slips, the blade slows down causing wavy cuts (especially in wide cuts). If the drive belt is good and tight then he needs to do a blade guide alignment.
Offline JRHill
Re: Wavy Cuts
« Reply #23 on: November 06, 2019, 12:18:13 PM »
Noticed this thread while researching some ideas and solutions for wavy cuts.
I have a WoodMizer LT50HD. I use the WoodMizer soap/lube. A few months back the blade got below the leading blade guide/roller. I didn't notice when I started the cut and mid way through the mill was bogging and the blade was steaming. It was a quick shut down and the dreaded "stuck in the middle of the log" scenario. The blade was being pushed to the rear of the slot in the bracket and pushing metal on metal on the guide bracket. Blade was burned on the rear edge, of course, and now junk. When freeing it and removing I saw the blade wheel belts were burned/scorched. Dang. Got new factory belts and replaced them - it was probably time anyway.
But darn it, since this happened I can not get a straight cut out of the saw. Even with fresh blades. I'm sawing 2 to 3 year old 12 to 16" Doug Fir that was bunked and with relatively clean bark (I have a debarker and use it when needed anyway but no stuck rocks or stones). I've inspected the blade guides and jewelry and all looks good. I think this batch of blades were resharps but can't recall now. I do have a box of new ones but *DanG I don't want to trash another blade let alone a new blade. And I've NEVER had a bad experience with resharps from Woodmizer's Portland store.
Any ideas?
Best from WA,
JRHill
Offline alan gage
Re: Wavy Cuts
« Reply #24 on: November 06, 2019, 12:43:59 PM »
So you haven't gotten a single straight cut since the incident? I assume you've tried multiple logs?
Alan
Timberking B-16, a few chainsaws from small to large, and a Bobcat 873 Skidloader.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: Wavy Cuts
« Reply #25 on: November 06, 2019, 01:09:49 PM »
Unfortunately, to eliminate variables, its best to try with a new blade and new bandwheel belts.  Most of this below can be done in a very few minutes.
Check band tracking on the bandwheels.
Check the band roller guides for flat spots or grooves cut into the back shoulder.  Check for flat spots on the contact surface with no band on.
Check to make sure they are rolling smoothly with no band on, and with no wobble.
Check the make sure the idle side blade guide arm is rock solid, with no band on.  Tug on it hard, back and forth, up and down.
Make sure your HP blade guides are rock solid with the band on and are not touching the band.
Make sure both guide block assemblies are still rock solid.
Check their alignment.
Check the main drive belt tension (very important any time there is a loss in cut quality).
Check band alignment.
HobbyHardwoodAlabama.com
Offline Bandmill Bandit
Re: Wavy Cuts
« Reply #26 on: November 06, 2019, 02:34:44 PM »
Lots of relevant advice BUT, MM nailed it! "Owning a saw mill dont a sawyer make"!
If some one showed up to my place with "mangled components" hanging off his mill, he wouldn't even get a chance to set up. if he is too dumb to KNOW that blade lube is NOT optional, he is to dumb to understand MOST of the principles of cutting good lumber, weather it laziness or his "give a *DanG is busted"! He DON'T deserve patronage ($$) from me or any one else.
A good owner and operator will produce good lumber no matter the mill brand.
Its just that a good operator can make more good lumber faster with not as much work on a Woodmizer. ;D  :D
If you ain't livin on the edge you are takin up way to much room. Of course at my age if I get too close to that edge any more theres a good chance I may fall off.
2001 Dodge 1500 4x4. 2018 F150
2007 Woodmizer LT40HDG28 almost Super
2 Logrite 36 inch cant hooks and a bunch of stuff I built myself
Offline Brad_bb
Re: Wavy Cuts
« Reply #27 on: November 06, 2019, 04:52:25 PM »
All these posts and the OP has never said what type of wood was being cut or how frequently the waves were occurring, whether the wood being cut was knotty or not...
These will help focus or eliminate what might be going on.
If you are getting fairly consistent wavy lumber from him, I'd lay a bunch out and inspect it with him.  If he blows it off and tells you it'll get flat in planing....then that tells you he doesn't care.  If he want's to trouble shoot it with you, then that's a good thing.
Among the other causes that have been listed, my waves have been caused by 1)the band, 2)drive belt tension(too loose), and 3) the wood itself.  Milling really hard wood like osage, I'll get more waves than normal because it's so hard and the the band will sometimes try to follow changing grain direction.  I also proved the same thing when cutting Honey locust.  It's pretty hard too, but the knots are extra hard, and depending whether you're cutting up or down the tree when you hit the branch knot, affects which direction the blade wants to go- up or down.  When cutting really hard wood, or wood with really hard knots, you need to slow your feed rate down for sure for those. If you try to continue at the normal feedrate, when it hits hard and quickly changing grain direction, the band will try to follow-  the path of least resistance.  Slowing the feed rate down so the teeth can cut through the knot fibers before the blade advances.
This thread is a good reminder to me to check my drive belt tension.  I'm going to be cutting a bunch of osage soon and I need to make sure it's correct before I do.
Re: Wavy Cuts
« Reply #28 on: November 06, 2019, 05:20:19 PM »
You are bang on that one Brad!
I have learned that I can do hand check of the belt by raising the head and reaching in from the bottom. I check it cold and then again after a log is cut every time I fire up the mill. That way the belt don't get a chance to delivery wavy lumber. Having said that, WHEN I do see a wavy board it is the FIRST thing I check
Offline GDinMaine
Re: Wavy Cuts
« Reply #29 on: November 07, 2019, 07:22:26 AM »
It could have been a the wood as well. A bone-dry spruce, cherry, ash, oak and so on, will do funny things to the blade and makes you scratch you head as for what might be wrong. For me dry spruce presents the greatest challenge. The knots are very hard and in the transition the blade makes waves. I tend to see smaller, but more frequent waves caused high feed rate in tough wood as opposed to long, more gentle waves caused by dull blade issues. The first thing I try is slow the feed down. Sometimes way down. If that does not help I put on a fresh blade right away. If I do make some wavy lumber I always point it out to the customer and immediately start looking for a solution, even if they say they don't care. I hate doing a bad job and I get very frustrated by crappy lumber.
It's the going that counts not the distance!
WM LT-40HD-D42
Offline Percy
  • Resident trouble maker
Re: Wavy Cuts
« Reply #30 on: November 07, 2019, 09:18:05 AM »
I couldnt agree more...Dry spruce, specially the bigger ones, the blade sounds like its cutting a rock the whole way down the log.... :D :D
Offline rastis
Re: Wavy Cuts
« Reply #31 on: November 07, 2019, 01:01:41 PM »
My experience is this:
1 - bands that are dull but properly set for the type of wood, will cut slowly and will load the engine down. They also seem to gather the most dust and pitch.
2 - bands that are under-set for the type of wood they are cutting, will almost always produce a wavy cut, regardless how sharp they are.
3 - bands that are over-set will produce more sawdust then is necessary, but if they are sharp, they will cut just as well as a properly set and sharpened band.
that's all I got...
John
Is there a guide available for type of band and tooth set to use for various wood species? Ive been contemplating getting the gear to sharpen and set my own bands. We cut pine, maple, oak, cherry and walnut or whatever species the wood fairy happens to deliver.
Offline CCCLLC
  • It's not to big, load it!
    • Carolina Custom Cut
Re: Wavy Cuts
« Reply #32 on: November 07, 2019, 01:18:39 PM »
Wood Mizer site has some lists and guides on that in their blade selection pages. Maybe a copy for Sawyer as a curtisy as well.
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
Re: Wavy Cuts
« Reply #33 on: November 07, 2019, 02:12:47 PM »
I am always going to sawmill jobs where I am asked if I am going to cut wavey wood. How often did the last guy change his blade, i ask? change a blade they say, he used the same blade all day.
NO I do not cut more than 1 wavey board as I change the blade, adjust what I need to make sure we are sawing perfect or near perfect lumber.
I am seeing wavey lumber at the kiln now from someone elses sawing, slabs cut thru the pith and then they wonder why it spits and moves in the kiln.
I really do not want someone swearing at me and giving me a bad name because they had to send a board thru the planer numerous times.
Offline JRHill
Re: Wavy Cuts
« Reply #34 on: November 10, 2019, 08:09:11 PM »
Well, *DanG.
Broke everything down, inspected and back together with a fresh blade but not new wheel belts. I got the Woodmizer tool out and checked all the blade alignment specs. A few weren't "perfect" as the millennial kids say but well close enough. I buttoned it up and loaded the lube jug, checked everything again and it ran a perfect cut.
It is just another of those things where ya fight it and then when ya put it back together the problem evaporates. you never get to find out what was wrong. But thanks for all the input.
Offline bushhog920
Re: Wavy Cuts
« Reply #35 on: November 10, 2019, 09:22:55 PM »
So what do y'all set to for different types of wood? I cut mostly pine and shoot for .025"
Offline JRHill
Re: Wavy Cuts
« Reply #36 on: November 10, 2019, 09:35:48 PM »
Not sure what you mean... .025 straightness in the cut? I don't have any difference in pine from Doug fir, er when I'm not battling an elusive weird thing like the above.
Offline bushhog920
Re: Wavy Cuts
« Reply #37 on: November 10, 2019, 11:08:54 PM »
Tooth set on the blade sorry should have been more clear. .025" seems good for me if I over set to .030" my boards start getting a rough surface finish.
Offline Chuck White
  • Sawing Mobile since 2005
Re: Wavy Cuts
« Reply #38 on: November 11, 2019, 06:48:43 AM »
I cut mostly W/Pine, Hemlock & Cherry and I set my blades in the .025-.028 area!
If you try to get them set to the "exact" number, it can get very frustrating!
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline dougtrr2
Re: Wavy Cuts
« Reply #39 on: November 11, 2019, 09:04:52 AM »
If he has been cutting for 15 years, he has it figured out by now. My opinion is that he just don't care and has little or no pride in his work. I'd find another person to saw for me in the future.
There is a difference between "cutting for 15 years" and "cutting for one year 15 times".   Maybe he just isn't learning.
Doug in SW IA
Wavy Cuts
Started by millit on Sawmills and Milling
Last post March 11, 2008, 03:43:58 PM
by millit
wavy cuts
Started by dustyhoosier78 on Sawmills and Milling
Last post January 07, 2020, 10:19:03 PM
by dustyhoosier78
Wavy cuts .
Started by shortlogger on Sawmills and Milling
Last post March 09, 2017, 11:17:58 PM
by gww
wavy cuts
Started by revid on Sawmills and Milling
Last post August 20, 2015, 06:57:52 PM
by MSSawmill
