Author Topic: chainsaw wood chips for fireplace kindling?  (Read 9294 times)
Offline motif
« on: September 13, 2010, 06:28:49 PM »
after I cut my fire wood with my chainsaw wood chips smell with oil...obviously.
I wonder if I use them in my fireplace as kindling will cause any problems.
Looks like a good material for this purpose...
Offline isawlogs
  • A smile is contagious ... Start an epidemic
Re: chainsaw wood chips for fireplace kindling?
« Reply #1 on: September 13, 2010, 06:31:19 PM »
 I don't see where a problem could arrise from burning the chips .
   Marcel
Offline LeeB
« Reply #2 on: September 13, 2010, 11:20:49 PM »
I use planer shavings all the time in my shop stove. I can't see where chips would be any different.
Offline motif
« Reply #3 on: September 14, 2010, 02:43:38 AM »
chips with oil in it, I don't know e.g. health hazard, fireplace clogging etc.
Offline beenthere
« Reply #4 on: September 14, 2010, 11:38:13 AM »
I'd be more afraid of my shadow.  ;D
Offline motif
« Reply #5 on: September 14, 2010, 11:51:39 AM »
hell man, how do you look then?  ;D
Offline fuzzybear
« Reply #6 on: September 14, 2010, 11:53:07 AM »
  There are people here that come for wood chips all the time. They pack paper liquor bags from the liquor store with them. Then they toss it in like a regular log and light it up. It works very well, light and forget.  The liquor store here will give away a small stack ( 10 bags or so) every time you go in.  The bags used for wine bottle/rum bottles are the best. When you fill them they are the same shape and size as a "real" log.
  As far as oil goes, you always have a small amount on each log as you cut anyway, as long as it's not soaked with oil you will have no problem.
  Stay worm winter is coming.....  -10 here this morning.
  I'll turn on the fans and start to send it down south soon. ;D :D :D
FB
I never met a tree I didn't like!!
Offline VT_Forestry
« Reply #7 on: September 14, 2010, 11:59:20 AM »
I always have a 5-gallon bucket full of saw shavings for lighting the campfire/fireplace.  Cut length-ways down the log and get the nice long curly ones, they work best and it doesn't take too many cuts to get a good pile that will last you awhile :)
Forester - Newport News Waterworks
Offline LeeB
« Reply #8 on: September 14, 2010, 02:20:08 PM »
I've also used them for smoking chips in the meat smoker. Not enough oil on them to fret over.
Offline isawlogs
« Reply #9 on: September 14, 2010, 06:21:29 PM »
 If you can clog a fireplace with a handfull of chips you are using to sart a fire .. I would strongly sujest you replace said fireplace sir .
 As for the oil on um .. how much fuel oil goes trough a furnace over a winter , how much sout is in the cheminy. Aint any more hazerdus to use chips out of a saw then to heat with oil. Actualy a lot less.
   Marcel
Offline LorenB
« Reply #10 on: September 15, 2010, 10:17:52 PM »
Motif,
My experience is with burning chips off my planer and occasionally sawdust.  I soak the chips in used engine oil before I use them as kindling.  The oil provides extra heat to help start the fire, and I get rid of my used oil at the same time.
I have found that generally the chips don’t work too well unless they are dry.  That’s even more true for sawdust.  They also do not absorb the oil as well if the chips are wet with water.  I would guess that most of the chips from a chainsaw would be wet.
If you are just going to use a small amount, you can lay the chips in a thin layer in a tub or something similar.  Leave the tub in the sun and stir the chips several times a day.  Bring them in at night.  In a few days you’ll have nice dry chips that should start easily.
Good luck,
– Loren
Loren
Baker 3667D portable sawmill, Cook's edger, Logrite arches & peaveys.  Husky 272XP chainsaw & two Echos.
Offline bert0168
« Reply #11 on: September 16, 2010, 05:03:12 PM »
I use either planer or saw chips to start my stove every time.  But I add a little kero or #2 to the can and let them sit awhile.
I'll fill one of those giant coffee cans and pack the chips in then add about one cup of diesel, #2 or kero and put the lid on.
Usually only takes about 2 cups or so to get the logs going and I don't use any small kindling, only the split logs and the saw/planer chips.
Offline John Mc
« Reply #12 on: September 16, 2010, 09:52:06 PM »
I had a relative who used to save old candle stubs and melt them into small (3 oz ?) paper cups full of chainsaw chips. (there may have been a wick in there too?) She'd sell them as camp fire starters. Worked rather well.
Offline Ron Scott
« Reply #13 on: September 18, 2010, 10:57:09 AM »
Yes, makes for a good fire starter.
~Ron
Online terrifictimbersllc
    • Terrific Timbers LLC
« Reply #14 on: September 19, 2010, 06:55:28 PM »
Probably depends what kind of stove you have but mine (Jotul F400) has an ash tray below the burning chamber floor.  I am finding buildup of wax deposits in the ash tray pan or worse around it.  Seems the wax will melt and run down below before burning.   THis is from putting candle leftovers directly in, not from making up a wax-permeated kindling mixture.
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide,  Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline John Mc
« Reply #15 on: September 19, 2010, 10:04:03 PM »
She was making them for camp fire starters, not for use in wood stoves, so any possible drippage was not an issue.  A bit off topic from what the OP was asking...
Offline bkellyvtme
« Reply #16 on: September 20, 2010, 04:27:22 PM »
I use chainsaw shavings to make the best fire starter in the world hands down. I melt some wax mix in the shavings and pour into those paper egg cartons. Rip one off and light the edge of the egg carton and off it goes. Lasts a while too.
Offline beenthere
« Reply #17 on: September 20, 2010, 06:42:53 PM »
How do you guys go about collecting chainsaw shavings? I'm curious.
Offline John Mc
« Reply #18 on: September 20, 2010, 07:15:27 PM »
If you are bucking up firewood in one spot, it doesn't take long for the chips to pile up...
Offline motif
« Reply #19 on: September 21, 2010, 03:52:48 AM »
my chainsaw although small is pretty efficient with chips and shavings  8)
can't imagine what a mess  bigger saws can do... ;D
So I put them with shovel on wheelbarrow to dry and then to big plastic bags.
The Best Wood for Kindling?
Started by ReggieT on Firewood and Wood Heating
Last post September 05, 2015, 10:45:51 PM
by WV Mountaineer
moved
MOVED: Bags for kindling and campfire wood
Started by Jeff on Firewood and Wood Heating
Last post February 09, 2014, 11:11:11 AM
by Jeff
Gas fireplace to wood burning...
Started by ManjiSann on Firewood and Wood Heating
Last post October 17, 2019, 12:19:41 PM
by Southside
wood chips and what used for
Started by JD_Kid on Forestry and Logging
Last post August 17, 2003, 05:43:57 AM
by Ron Wenrich
