Dynamic Green Products Inc.
Author Topic: Newest Addition Dump Trailer -pics  (Read 9221 times)
Offline Busy Beaver Lumber
    • Busy Beaver Lumber
« on: September 29, 2010, 07:45:46 PM »
 Here is my newest addition to our equipment line-up, a 6 x 10 dump trailer with 10,000 capacity. I bought this particular one because you can fold the side down to load logs with ramps or so that you can load and unload lumber using a forklift or tractor with a forklift attachment.
Have been wanting one of these for the longest time and finally found a dealer in Michigan that cut me a deal that I could not pass up, plus he took a small utility trailer as a trade and gave me darn near what I paid for it 7 years ago.
Will use it to deliver lumber, deliver bundled firewood, pick up free logs and firewood, and to transport some of the rustic log furniture we make to and from shows and local dealers that carry our items.
One suggestion if you get one, get an adjustable hitch that you can change the ball height on easily by just moving two pins as opposed to the ones you need to take bolts out to adjust, because your friends will want to borrow it and almost every truck sits at a different height. My 1988 one ton c3500 sits up mich higher than just about every other 2 wheel drive truck I have ever seen. Having an easy to adjust hitch height simplifies things greatly and has the trailer tow at the proper angle.
Woodmizer LT-10 10hp
6 x 10 dump trailer
Grizzly 6in Spiral Cut Joiner
Twister Firewood Bundler
Jet 10-20 Drum Sander
Jet Bandsaw
Save a tree...eat a beaver!
Offline Buck
  • Another "traveling man"
Re: Newest Addition Dump Trailer -pics
« Reply #1 on: September 29, 2010, 08:13:25 PM »
I just made a deal on a 6 x 12 gooseneck. it is small but after only a month I dont know how i ever made it without it.
Respect is earned. Honesty is appreciated. Trust is gained. Loyalty is returned.
Live....like someone left the gate open
« Reply #2 on: September 29, 2010, 08:29:00 PM »
I'm with you on that thought Buck. I haul approximately 6 to 10 cords of firewood a week. Nice part is that the Amish fellow I buy most of it from loads the wood in the trailer for free, but then when I get to the shop or make a delivery directly to a customer, it takes a half hour a trailer load to unload the trailer I was using. Lots of wasted time. Now I just back up and push the button and dump it in 30 seconds and don't wear myself out. At almost 50 years old, and with 3 spine surgeries and 2 shoulder surgeries, anything I can do to save some back pains is well worth it as far as I am concerned. I really like the fold down side. It makes it a breeze to load with forklift or by using a couple simple ramps and a winch to load logs.
6 x 10 dump trailer
Jet Bandsaw
Offline fred in montana
    • log dovetail jig plans
« Reply #3 on: September 29, 2010, 09:22:07 PM »
Very nice. How much does one cost if I can ask?
woodmizer lt15, mf 65 tractor
logdovetailjig.com
« Reply #4 on: September 29, 2010, 09:33:23 PM »
Trailer as you see it ran $4300. Spare tire and rim, plus spare tire mount on front of the trailer added $125, and I had him add 4 heavy duty D rings to tie things down with and to use with my winch to load logs which ran me another $100, so all total $4525
You can find cheaper, but be sure you know what you are getting. This has Dexter 5200 pound quick lube axles, brand new tires, brakes on both axles, dual cylinders to lift the bed, sealed Led tailights, built in extensions so you can add a 2 x 12 board to both sides, a tailgate that opens like barn doors or can be used as a spreader like the gate on a dump truck and interstate deep cycling marine battery
6 x 10 dump trailer
Jet Bandsaw
Offline Buck
« Reply #5 on: September 29, 2010, 10:57:28 PM »
Im gradually putting a real firewood business together.  The only item left on the wish list is the bundler. Your posts are a real inspiration. Keep em coming. I will be bending your ear I'm quite sure.
Offline paul case
  • Original wearer of the PCM.
« Reply #6 on: September 29, 2010, 11:05:59 PM »
hey b b,
looks like maybe you need to update the list of toystools at the bottom of your posts?  pc
pc
Offline ladylake
« Reply #7 on: September 30, 2010, 04:08:54 AM »
I want one, might go shopping today.  Anyone know of any good buys in MN or close by.   Steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline gunman63
« Reply #8 on: September 30, 2010, 09:29:21 AM »
Steve, I just  bought a new one a month ago, big tex brand, 14', 14000 lb.GVW, 3 way gate, LED lights, D rings inside, ramps for the skid steer, $6300,plus fees and taxes. PJ's are a little less,  but a little lighter built, but are still a ok trailer, buddy sells big tex trailers, dont mind spending a little more there, always get a lot  of freebies thru he year from him.  Bought a used load king a couple years  back, same  size, for $4000, used it for 2 years, sold it for $4000 before i bought this one , was time for tires , in my mind anyways, it was a no brainer to update. On this new one, put on 2 foot sides, and a gate in the  middle so i can  dump 2 cords of firewood at one place, or  dump  1 cord at 2 places, works slick.
Offline DGK
« Reply #9 on: September 30, 2010, 09:42:32 AM »
3 loose cord/10,000 lb capacity.
Doug
Yukon, Canada
LT40G38 modified to dual pumped hydraulic plus, HR120 Resaw, EG200 Edger, Bobcat S185,Bobcat S590, Logosol PH260M3, Sthil MS660's, MS460,MS362's MS260, Trailtech dump trailer, F350, F700 Tilt-Deck log/Lumber Hauler, JD440B Skidder, Naarva S23C Processor
Offline Ironwood
    • http://www.branchandburl.com
« Reply #10 on: September 30, 2010, 09:57:08 AM »
You folks may want to think about Goodyear "G" series full steel cased tires for these trailers when the time comes. They are the smallest (16") tire available with steel all the way around like tractor trailer tires. I just put two more on one of my Butler single axle tilt beds, the last trialer in my fleet which did not have them.  So, I must be running, two single tilt beds, one tandem deck over , and one or two log arch/ brindles w/ these AWSOME tires. I get them from local commercial tire shop. If the are "local" trialers I run retreads ($100 ea), if over the road, then new ($250 ea). I use 225-16's as they keep the decks closer to the ground.
 Ironwood
Offline nas
  • Measure twice and cut aw DanG
    • Traditional forest products
« Reply #11 on: September 30, 2010, 10:02:04 AM »
After searching for a couple of months I just bought a 6x12' 12,000lb dump trailer from a friends father in law.  It needs a little work, but the axles, tires, and hydraulic system is good.  The price was even better. $500 8)
Nick
Better to sit in silence and have everyone think me a fool, than to open my mouth and remove all doubt - Napoleon.
Indecision is the key to flexibility.
2002 WM LT40HDG25
stihl 066
Husky 365
1 wife
6 Kids
Offline gunman63
« Reply #12 on: September 30, 2010, 11:47:34 AM »
3 loose cord, and only 10,000 lbs, 3 cords here in the states,  is 13-15000 lbs more or less, never make it with the DOT.  I like the sides  but the frame is awful close to the  ground if its soft or have snow. or the pic could be decieving
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #13 on: September 30, 2010, 12:04:24 PM »
Beware of rectangular tube frames with these trailers especially if you live in road salt country.  My first dump trailer's frame rotted from the inside out and broke at 2 1/2 years of age.
Offline paul case
« Reply #14 on: September 30, 2010, 02:21:43 PM »
nick,
you didnt buy it you stole it. the hydraulic pump unit and cylinders probably cost more than that.  pc
pc
Offline Ironwood
« Reply #15 on: September 30, 2010, 05:50:11 PM »
I like a heavy load LOW. For instance I hate putting an 8000 lbs forklift on a deckover, I'd rather borrow my buddies equipment trailer and keep it low. So, for me just keep it up a foot or two and I am good.
 I was going to build my own out of a duece body and hoist from an old 5 ton truck, but decided to build a smaller unit out of a M-105. I put a whole new channel frame under it. Built it low for ease of loading w/ my FEL.
Offline Slingshot
« Reply #16 on: September 30, 2010, 08:41:57 PM »
     Good looking trailers you guys have.
   I'm planning to use the dump hoist off this former grain wagon to make a
   dump trailer. Don't know what it is rated at but when it had the sides on it
    I could haul and dump a large load of dirt with it.
        I also have a smaller dump hoist like this unit.
________________________
Charles   sling_shot
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #17 on: October 01, 2010, 08:39:45 AM »
 sling_shot   I like your dump wagon, but a load of slabs into an open field??  You gonna have a wiener/marshmellow  roast  ???
Offline Slingshot
« Reply #18 on: October 01, 2010, 08:57:14 AM »
    No wiener/marshmellow roast :).    That area is back out of my way down over a little hillside in
  a rather rough area. And out of sight of neighbors  ;D.
    Also where I can burn them or let em' rot.  teeter_totter
Charles  sling_shot
Offline DGK
« Reply #19 on: October 01, 2010, 10:16:02 AM »
3 loose cords of dry beetle killed spruce approximately 8300 pounds. We have hauled over 3.5 million pounds of wood in the past 2 1/2 years without a problem with the height of the trailer. The trailer jack foot can scrape the ground if backing up a steep drive from a level surface though.
Doug
Yukon, Canada
The Newest Vehicle Addition
Started by tcsmpsi on General Board
Last post September 06, 2012, 03:56:36 PM
by Delawhere Jack
Newest addition to my collection
Started by Radar67 on Sawmills and Milling
Last post October 06, 2005, 10:22:31 PM
by Dan_Shade
Newest Addition Updated!
Last post August 14, 2012, 09:09:12 AM
by tcsmpsi
Kaufman Trailerís Deluxe Light Duty 10000 GVWR Dump Trailer
Started by submarinesailor on General Board
Last post November 28, 2016, 11:07:02 PM
by submarinesailor
