Author Topic: WM legs  (Read 2374 times)
Offline Peter Drouin
    • A&P Saw mill LLC
WM legs
« on: October 01, 2010, 01:57:05 PM »
The new legs are great for leveling up the mill, but one problem that they overlooked is that they loosen because of vibration.  This is what I did to fix that problem.
8)
    • A&P Saw mill LLC
Re: WM legs
« Reply #1 on: October 01, 2010, 02:10:56 PM »
This is for the back leg.  I had to put it upside down for it to fit and cut a small notch in the square hole for the point of the nut.
    • A&P Saw mill LLC
Re: WM legs
« Reply #2 on: October 01, 2010, 02:13:47 PM »
One day working on snow and ice I loaded a log on the mill and mill, log and I slide about 6' and scared the devil out of me. So I fixed that by welding two nuts on the bottom of the legs.
Offline ljmathias
  • Been sawing part-time almost 27 years now
    • Polymer Science Learning Center
Re: WM legs
« Reply #3 on: October 02, 2010, 12:33:04 AM »
Wow, a slip-n-slide Wood master!  Does that mean you can mill while sliding down a snow and ice covered hill, slide the lumber off, pull the mill back up to the top and do it all over again?  sounds like fun   :D :D
Lj
LT40, Long tractor with FEL and backhoe, lots of TF tools, beautiful wife of 50 years plus 4 kids, 5 grandsons AND TWO GRANDDAUGHTERS all healthy plus too many ideas and plans and not enough time and energy
Offline Chuck White
  • Sawing Mobile since 2005
Re: WM legs
« Reply #4 on: October 02, 2010, 06:54:27 AM »
I've had my mill move like that a couple of times too, but only about 6-8 inches or so.
Your fix gave me an idea, and I think I'll drill a couple of holes in the jack plates and screw "inch" bolts into them.
This way, they're easily removed too.
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: WM legs
« Reply #5 on: October 02, 2010, 07:26:12 AM »
Not after they're smashed a few times.....what about setting up on concrete or asphalt?
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide,  Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Online Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
Re: WM legs
« Reply #6 on: October 02, 2010, 07:31:34 AM »
you could always take 6 boards with you with holes drilled in the boards in the right locations.
I try to avoid setting up on concrete or asphalt, but if I do, I put boards under the outriggers anyways,
lots of dull bands and chains
    • A&P Saw mill LLC
Re: WM legs
« Reply #7 on: October 02, 2010, 06:55:57 PM »
Hi guys I all ways put boards down . and the weight will mash the 2 nuts down I will cut a log or two then check all the legs then im good for the day :) :) :)
Offline Chuck White
Re: WM legs
« Reply #8 on: October 03, 2010, 06:48:28 AM »
I've never had the chance to set up on concrete or asphalt!
The closest I've come to that was setting up on a "Seasonal limited use gravel road".
~Chuck~
Re: WM legs
« Reply #9 on: October 03, 2010, 06:52:06 AM »
Don't like setting up on concrete or asphalt nothing gives and you have to shim or be unsupported.
Offline customsawyer
    • The Custom Sawyer
Re: WM legs
« Reply #10 on: October 03, 2010, 09:28:37 PM »
I have cut one time on concrete and had shin splints so bad that could not hardly walk next day, won't be doing that again. It might have been better if my boots were made for walking on concrete.
Two LT70s and to much other support equipment to mention.
www.thecustomsawyer.com
Offline woodmills1
  • the truth shall set you free
Re: WM legs
« Reply #11 on: October 12, 2010, 08:58:31 PM »
my 70 walks forward and the front legs end up slipping.  I put blocks under the tounge so she doesnt fall down
Hot Legs
Started by luvmexfood on FOOD! FOOD! FOOD!
Last post April 12, 2014, 06:28:01 PM
by Yoopersaw
well it had four legs
Started by Den Socling on The Outdoor Board
Last post May 21, 2016, 09:13:28 PM
by sandhills
Not Just Legs
Started by Tam-i-am on LogRite Tools and Rite Leg Co
Last post July 15, 2016, 11:08:13 AM
by Tam-i-am
four new legs
Started by runmca on LogRite Tools and Rite Leg Co
Last post August 14, 2018, 10:58:53 PM
by samandothers
