Dynamic Green Products Inc.
Author Topic: moisture meter  (Read 1522 times)
Offline waj256
moisture meter
« on: October 18, 2010, 11:28:44 PM »
I have a sawmill and a kiln and I am looking for the best moisture meter to use when checking the lumber.
Offline scsmith42
    • Whispering Pines Farm
Re: moisture meter
« Reply #1 on: October 19, 2010, 05:45:31 AM »
Delmhorst meters are pretty much the standard for pin-type meters.  I also have a Merlin pinless meter that I like a lot.
Tom's 3638D Baker band mill
Offline jdtuttle
  • If it's worth doin, it's worth doin right
Re: moisture meter
« Reply #2 on: October 19, 2010, 06:17:39 AM »
I just bought the Lignomat Meter with probes to run in the kiln. Still on the first load but seems to work well.
jim
Have a great day
Offline ahlkey
Re: moisture meter
« Reply #3 on: October 19, 2010, 09:30:44 AM »
If you want to go with a pinless meter I have a Wagner MMC 220 and I found it as a good around moisture meter.
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: moisture meter
« Reply #4 on: October 19, 2010, 02:59:03 PM »
I have the Lignomat pin and pinless kit with the auxiliary hammer probe which has different length pins.  Having both is great, you can check them against each other or first measure with the pin one then check the reading with the pinless one, then go off scanning wherever with the pinless one so as not to make a lot of holes everywhere.
Offline waj256
Re: moisture meter
« Reply #5 on: October 19, 2010, 09:39:40 PM »
Thanks for the help
Offline poolman
Re: moisture meter
« Reply #6 on: October 19, 2010, 09:43:39 PM »
I have a pinless wagner from 1994 and it works great today.It was 300 dollars and state of the art in 94.I am glad i dont need to buy another one.It is nice to not buy the same thing twice.    brian
Moisture Meter
Started by woodsdog2015 on Firewood and Wood Heating
Last post April 08, 2018, 04:11:14 PM
by woodsdog2015
Moisture meter
Started by rbarshaw on Drying and Processing
Last post August 16, 2004, 08:32:01 PM
by rbarshaw
What moisture meter
Started by welderskelter on Drying and Processing
Last post November 20, 2020, 11:14:41 PM
by GeneWengert-WoodDoc
Moisture Meter
Started by Doghouse on Sawmills and Milling
Last post June 06, 2003, 07:28:57 AM
by Ron Wenrich
