Author Topic: brown oak  (Read 1903 times)
Offline qbilder
  • lil helper
brown oak
« on: November 23, 2010, 08:18:09 PM »
Has anybody ever cut an oak that had dark brown wood? I cut a small log this weekend that had chocolate brown wood with very bold medullary rays that were nearly black. It was stunning quarter sawn wood. I have never seen anything like it but would love to have a load for myself. I'm in the mountains of southern NM and oak isn't uncommon but it's always just the typical sandy blond colored stuff. I grew up in the Appalachian mountains & we cut several varieties of oak but I have never seen anything that was dark brown. It wasn't bacteria or mineral stained. It was consistent dark brown with a thin white sap ring. I wish I had pics. But I was grinning every cut, amazed & awed with it. It was like walnut stained white oak but natural.
Is this a species of tree I can identify & target? I'd love to have a load. Thanks
God bless our troops
Offline paul case
  • Original wearer of the PCM.
Re: brown oak
« Reply #1 on: November 23, 2010, 08:22:43 PM »
sounds like post oak to me. real hard. pc
pc
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: brown oak
« Reply #2 on: November 23, 2010, 08:31:57 PM »
I immediately thought Post Oak, but my book doesn't show it that far West.  Some of our Foresters probably can help.  Leave and bark samples would help.
Offline qbilder
  • lil helper
Re: brown oak
« Reply #3 on: November 23, 2010, 08:43:33 PM »
The bark doesn't seem any noticeably different than other oaks around here. And the leaves are miniature. They are only a couple inches long by maybe an inch wide. I won't know til spring exactly what different varieties we have because there's no leaves right now. But I have noted some with sharp lobs & some with rounded lobes. None get very large or straight so they're not a commercially cut tree. The largest I have seen are pushing 24"x8' before branching. I'm not native here & don't know the trees well enough yet. But I have seen lots of the local oak & this is the first time I seen dark brown.
I have found 2 types of hard maple growing here, plus a tree that is strikingly similar to cherry in every way except instead of the sweet cherry smell, the lumber has an almost citric smell. Even the leaves & bark look the same as cherry. None of the trees get large or abundant enough for commercial logging/milling so there's not much info about them. The conifers are quite popular for milling around here while the scrubby little hardwoods are ignored.....except for firewood.
I appreciate the lead on post oak. I'll look into it. Many thanks.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: brown oak
« Reply #4 on: November 23, 2010, 09:00:15 PM »
Your leaf description eliminates Post Oak.  It had already been eliminated by geography.  Canyon Live Oak is a possibility.  It's leaves are one-third enclosed and it loses it's leaves yearly.  It's found in Southwestern US.
Offline bandmiller2
Re: brown oak
« Reply #5 on: November 23, 2010, 09:09:50 PM »
May not be the same but I've cut oak with that brown coloration that had a cavity where a branch had broken off and the pocket held water. Frank C.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: brown oak
« Reply #6 on: November 23, 2010, 09:52:44 PM »
In my limited experience, the white oak group produces more of a brown heartwood while the red oak group produces heartwood that has more red in it and less brown.  However, that may not apply out West.  Therefore, when I read your description, I suspected a white oak of some sort.
Offline tyb525
  • Always learning.
Re: brown oak
« Reply #7 on: November 23, 2010, 10:01:51 PM »
I've cut some white oak that had real dark heart with distinct rays.
Offline qbilder
  • lil helper
Re: brown oak
« Reply #8 on: November 23, 2010, 11:54:22 PM »
It does have white oak characteristics such as the bold rays. The other oaks here seem to be like a red oak with finer rays and lighter color. It's not brown from a rotten branch. This is uniform & consistent color throughout the log from base to top, and distinct line between heart & sap. I appreciate the help, fellas. I think I have some leads to look into.
Offline LeeB
Re: brown oak
« Reply #9 on: November 24, 2010, 12:31:35 AM »
I vote for live oak. How hard was it? Didi it gum up your blades real bad?. Leaf shape oblong and rounded with a small point on the end, about 1 1/2" long and 1/2" wide? Sounds like something similar to a live oak in central Texas called scrub oak.
Offline qbilder
  • lil helper
Re: brown oak
« Reply #10 on: November 24, 2010, 09:07:16 AM »
That maybe sounds like our culprit. Muchos gracias
Brown (Brown Out) tree paint
Started by KBforester on Ask The Forester
Last post July 28, 2015, 01:53:18 PM
by Ron Scott
brown
Started by tule peak timber on General Woodworking
Last post December 22, 2019, 04:22:29 PM
by tule peak timber
NH brown poplar
Started by woodmills1 on Sawmills and Milling
Last post January 30, 2003, 05:15:51 PM
by woodmills1
Brown trout !
Started by isawlogs on FOOD! FOOD! FOOD!
Last post April 28, 2011, 02:12:43 PM
by Raider Bill
