Dynamic Green Products Inc.
Author Topic: 3-53 swap to silver 3-53T  (Read 2893 times)
Offline TravisMVL
    • Middle Valley Lumber
« on: January 01, 2011, 12:58:59 PM »
I was looking across the internet for detroit diesel 3-53 rebuilt engine prices, and discovered that there is a silver 3-53T which is apparently turbo charged and puts out  130 HP and 312 lb of torque, it's 5" taller but modifying the hood wouldn't be hard.
Anybody ever do this?
Offline doghunter
Re: 3-53 swap to silver 3-53T
« Reply #1 on: January 01, 2011, 02:20:10 PM »
careful there more hp means more heat u may need a bigger or thicker radiator
Offline Bobus2003
« Reply #2 on: January 01, 2011, 03:16:31 PM »
Swapped in a 130hp 4045T into my 440.. Big change from the original 70hp.. Cooling hasn't been an issue unless its a Hot Day(90's-100's) then it warms up a bit on hard pulls, traction on the other hand is.. It is very easy to spin the tires and break driveshafts/U-joints..
Offline snowstorm
« Reply #3 on: January 01, 2011, 06:20:18 PM »
the sliver was much improved over the green one
Offline Maine372
« Reply #4 on: January 01, 2011, 06:53:37 PM »
TJs are hard enough to see off of, do you really want to hood to be taller?
Offline madmari
« Reply #5 on: January 01, 2011, 08:29:20 PM »
Go for it- just mount the seat on the roof and move the hydro valves up there with you. The view is great and you can actually see where the blade is ;D
I know why dogs stick thier head out the car window.
Offline MaineLogger
« Reply #6 on: January 02, 2011, 05:40:52 AM »
Go for it.Just make sure the engine turns the right way and the governor,blower and exhaust matches yours.
380 Timberjack (cable)
230E Timberjack (cable)
648G Grapple
Husky 372's
Offline lumberjack48
  • 36 yrs ago, cutting Ash saw logs
« Reply #7 on: January 02, 2011, 02:17:08 PM »
If the price is right and it turns the right way i would absolutely go for it. Love those Detroit's even if your not doing anything it sure sounds like you are.
Bar and Chain swap
Started by TimberJacker66 on Chainsaws
Last post April 11, 2007, 07:39:23 AM
by SawTroll
Winch swap
Started by Upnorth on Forestry and Logging
Last post January 27, 2015, 03:53:23 PM
by coxy
swap meet
Started by coxy on Shows, Events and Places to meet
Last post April 28, 2017, 06:02:24 AM
by coxy
827 Blade swap
Started by dgdrls on Lucas Mill
Last post November 19, 2017, 04:39:09 PM
by dgdrls
