Author Topic: Making 3068 Rough Sawn Barn Doors  (Read 5012 times)
Offline Planman1954
« on: February 24, 2011, 07:15:09 PM »
Hey everyone. As I'd said in earlier posts, I'm trying to chronicle the building of my goat barn all along the way. I guess ya'll remember the wood shingle thread, and just recently the 4 board fence thread. Well, since I finished the fence last week, it's time to take on the barn doors. I've got 15 to make. They'll all be made the same to save time.
I decided to use 1 1/2" Rough Sawn stock straight from the Norwood, and 3/4" Panels straight from it as well. Each door will have one lower panel 42" high and 26" wide, and an upper safety glass insert 18" high x 26" wide:
Anyway, like I said, I began about 4 months back by cutting a number of logs into 1 1/2" x 5 1/2" stock. I cut a few boards 1 1/2" x 12" wide, some, 1 1/2" x 4", and a number of pieces 1" thick x 4" wide. Then I cut some really wide boards from the center of some logs to about 13" wide x 3/4" thick.
After they air dried (then until now), I began ripping only one side of the 1 1/2" x 5 1/2" stock to a finished width of 5" on my table saw. Then I ripped the 12" wide stock to 11 1/2" wide, and the 1 1/2" x 4" stock to 3 1/2" wide.
Next step was to cut the stock to length. The doors are 80" tall (standard size) and 36" wide. So the 1 1/2" x 5" wide sides were cut to 80" long:
Then I cut the rails 26" long. This gives the finished width of 36". The top rail is 1 1/2" x 5" x 26" long, the rail under the upper glass is 1 1/2" x 3 1/2" x 26" long, and the bottom rail is 1 1/2" x 11 1/2" x 26" long.
Here's all the pieces ready to be put together. (BTW, I'm not worried about the thickness of all the parts being perfect. These are for a barn, and a rustic look goes well. When I built my house, I used surfaced material and raised panels for all my doors assembled with dadoes and dowels...a lot more work than what I'm showing here.)
The next step was to drill for dowels at all the butt joints of the stiles and rails. I used my 30 year old Stanley doweling jig...it still works perfectly. I began by making the points to drill with the jig and each intersection:
Then I used a 1/2" Drill bit and made the holes:
Here's a photo of the pieces with all the holes drilled, ready for assembly:
I began the glue up of the frame:
Here's the frame glued up:
Then I glued up the 26" wide x 42" high lower panels out of the wide 3/4" stock. I used3 biscuilts at the joint between the two wide boards instead of just a butt joint for good strength. (Also one other thing. The reason the lower panel is so tall is because the barn is for goats, and I don't think it would be a good idea to have them bouncing off of the glass in the top part of the door.):
The next step was to use 1/2" x 3/8" strips nailed and glued around the upper and lower openings. After nailing it on one side, I flipped the door over, inserted the lower 26"x42"x3/4" thick panel, and placed the strips on the other side to hold it in place....It seemed to work fine...very sturdy. Here you can see them up close. (Of course, since the safety glass is not in the door yet, the little trim piece is only on one side for now. After I get some glass cut, I'll lay it in over silicone caulking, the nail in the little strip on the other side.):
The next step is to make the jamb from the 1"x4" stock. I've already ripped it to 3 1/2" wide for the casing as well as the trim inside and out. My siding will butt the door trim on the outside and the inside, so that's why the jamb is only 3 1/2" wide.
I guess that's all for now. 4 down...11 to go!
Norwood Lumbermate 2000 / Solar Dry Kiln /1943 Ford 9n tractor
Offline Jasperfield
Re: Making 3068 Rough Sawn Barn Doors
« Reply #1 on: February 24, 2011, 07:53:15 PM »
Well, it looks good and you're making progress. Looks like a door factory.
Are you going to build an assembly table before or after you make all the doors?
Offline clww
  • Oh yeah? Watch this!
« Reply #2 on: February 24, 2011, 08:08:28 PM »
Looks rustic! 8) 8)
Many Stihl Saws-16"-60"
18-Wheeler Driver for Crete
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #3 on: February 24, 2011, 08:18:25 PM »
I read the titles as "Making 3,068 Rough Sawn Doors" :D
Offline Planman1954
« Reply #4 on: February 24, 2011, 08:52:04 PM »
Ha, ha! 15 is bad enough!. The reason I did it that way is so that anybody reading it would not think it was about making large roller type barn doors...just standard 3'x 6'-8" doors.
And, oh, what is an assembly table for? :D I always use what's handy...in this case, my table saw! 8)
Offline Mooseherder
« Reply #5 on: February 24, 2011, 09:13:42 PM »
I love your Doors Planman. :)
Looks like a great project and saving a lot of money too!
Lane Circle Mill
Homemade Bandmill
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #6 on: February 24, 2011, 09:41:21 PM »
I thought the table saw was an assembly table  :D.  Mine is too, sometimes.  Nice post on those doors.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #7 on: February 26, 2011, 09:31:16 AM »
Your project should be an inspiration for others.  You can't complete them unless you tackle them.
Offline Planman1954
« Reply #8 on: February 26, 2011, 11:59:16 PM »
Thanks Magic. Kind of excited since I bought 4 of the 8 windows I need for the barn today. Wanted to go ahead and get them so that I can finish off the back area of the barn with the doors and siding so the animals will be protected. The place backs up to some woods and a creek where all kinds of rough critters live...not the nice kind like Ellee Mae had! Be great to see some finished walls..BTW, I'm looking forward to watching your addition progress.
Offline Burlkraft
  • Professional survivor......Still a wooodturner
« Reply #9 on: February 27, 2011, 07:53:09 AM »
Looks good P.M.    8) 8)
Your goats are gonna have a pretty nice home.
Why not just 1 pain free day?
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #10 on: February 27, 2011, 11:39:24 AM »
Nice looking doors there Planman!  ;)
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Doc Hickory
« Reply #11 on: February 27, 2011, 07:57:53 PM »
I'm thinking about auditioning to be one of your goats...
Feed a fire, starve a termite...
Offline fishpharmer
« Reply #12 on: February 27, 2011, 08:03:35 PM »
More great reasons to own a sawmill!  Nice work Planman, thanks for showing all the pics. 8)
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Making rough sawn texture on planed wood with the mill
Started by Brad_bb on Sawmills and Milling
Last post December 19, 2016, 12:44:44 AM
by Brad_bb
How rough is rough sawn lumber
Started by warren46 on Sawmills and Milling
Last post July 27, 2015, 11:24:42 PM
by scleigh
old barn/new doors
Started by giant splinter on General Board
Last post June 12, 2012, 09:42:41 PM
by shelbycharger400
Pole barn doors
Started by John_Haylow on General Board
Last post August 28, 2013, 09:09:44 PM
by shinnlinger
