Our operation is underway!
Started by OlJarhead, March 07, 2011, 12:00:49 AM
Way to go!  It is very awesome to have capability that most people never dreamed of having.
And I can't wait for some more pictures!!! Glad to see the boys helping too. It's great to have family close by.
I love to see a plan coming together.  Especially with the family.   :)
OlJarhead
Thanks all :)  Ya the boys do a lot of work but the old man has to keep ahead of them!!!  After all, my days of out working them are probably numbered ;) but that's ok.
OlJarhead
Geez I'm behind on posting some pics I see!  I'll get some more uploaded but here are a few from the period before we began nailing up interior walls!
This is a windfall blue stained pine we milled up a few weeks ago :)  Was pretty awesome watching it become something usable and well, artistic.
My son running the mill.  He and my step-son both like to run the mill and only need me if they have a problem clamping a log onto it or rolling one up -- which is pretty much never.  Heck, the last log they just picked up and put on the mill!!!
We have discovered that small logs are hard to keep clamped flat on the mill so we only mill them if we are desperate for something to make sawdust with.....
OlJarhead
The new stickers are awesome too :)  I can't wait to pick some more up!
We have a lot of wood to mill and I expect will mill as long as the weather will allow and we can air dry, but what a mess we're making!  I have to have a bonfire party soon :)
Quote from: OlJarhead on May 03, 2011, 10:08:27 AM
Bonfires are just part of the family fun.
What did you ever do without a sawmill??
OlJarhead
Quote from: Magicman on May 03, 2011, 10:15:03 AM
I don't know!!!  lol love having one!
ely
what do you use the solar panel for.? can you give a few specs on it, like price,what it powers? etc.
ive been wanting to get some of those but have no idea by looking online.
Peter Drouin
nice job you and the boys did  8) 8) and that wm cuts nice too 8) 8) have fun cutting :D ;)
A&P saw Mill LLC.
License NH softwood grader.
OlJarhead
Quote from: ely on May 03, 2011, 10:46:09 AM
Our cabin is 100% off grid :)  The solar power is a 615 watt system which charges 6 golf cart batteries (soon to be 8) which in turn provide the power for a 2500 watt inverter.  We use the power to run the lights, a freezer (soon fridge too) and will be using it for a ceiling fan, composter fan, radio and whatever else we want to run.  We also use it in the winter for the heat tape which keeps the sewer line to the composting toilet from freezing up on us :)
The system:
3 Sun 205 watt panels in series (from Sunelec)
Midnight Solar combiner box and disco box
Morningstar 60amp MPPT controller (converts the solar panel power to charging power
6 Costco Golf Cart Batteries (660ah)
AIM 2500 watt Modified Sine Wave inverter (peaks at 5000watts)
Iota 750 watt charger (to charge off a generator if the sun isn't cooperating).
Total cost is around $3500 including panel rack mount which I designed and my neighbor made for $300
We bought from a few different sources after much searching the net and discussion with the guys on countryplans.com forum (they have an excellent thread on off grid power systems).
I love being able to 'flick' on the lights when we get to the cabin :)
I would also think that the new LED lights designed for recreational vehicles would be a lighting option.  They use virtually no power
http://www.starlightsinc.com/shop/pc/home.asp
http://www.jclampstand.com/
ely
thanks for that info, i will have to investigate that further.
OlJarhead
Quote from: Magicman on May 03, 2011, 02:11:04 PM
Thanks for the links!  Those look like pretty cool options.  I guess I'd have to look for the type of light socket they use but I like the motion lights and some of the others a lot!  With my 660ah battery bank I could run them NO PROBLEM ;)  But an added benefit is that they don't need the inverter either....hmmmm
OlJarhead
Quote from: ely on May 03, 2011, 04:47:41 PM
No problem.  A good place to go is countryplans.com and in their forum is a thread for off grid power that is worth participating in.  Another is sunelec.com as well as (I think) aims.com (Or search for American Inverter Store) and I have some others floating around.
Your efficiency is probably only about 75-80% with the inverter.  I would only use it for stuff that absolutely has to have 120vac.  Those LED's are pricey, but they last forever and only sip the juice from your batteries.
OlJarhead
Quote from: Magicman on May 05, 2011, 10:01:29 PM
And when the inverter dies they will still work :)
ljmathias
Very nice, Jarhead- wish I could get my offspring interested in helping, but they do other stuff, which is fine.
One thought on your siding: why not put your coating on laying down?  Soaks in better, easier on the neck and back and it doesn't run off?  I did the outside siding on my son's house that way- easy, fast and saved a lot of stain/sealer in the end.  I also was able to do both sides so that it had the same moisture pick up and loss.  Poly is touch to work with though if you do it that way- have you thought of oil finish?  Easier to handle, put it up wet and do a wipe coat after it's up... just a thought, as I haven't actually done interior work this way (yet).
Lj
LT40, Long tractor with FEL and backhoe, lots of TF tools, beautiful wife of 50 years plus 4 kids, 5 grandsons AND TWO GRANDDAUGHTERS all healthy plus too many ideas and plans and not enough time and energy
Good suggestion Lj.  I also do all painting, staining, and sealing on sawhorses before nailing it up.  Then maybe a bit of caulking and touchup.
OlJarhead
Quote from: ljmathias on May 09, 2011, 07:05:19 AM
Lj
I thought about doing it before putting it up but decided to put it up and then do it instead as I felt that would be easier and cleaner (lots of dust at our cabin site).
Guess I'll have to see how it goes but figured I could put it on really light and do it in coats in hopes of keeping it from dripping.
OlJarhead
No milling this last trip but do plan on doing so over memorial weekend :)  I even dropped another pine for the weekends festivities and have a bucket of end sealer ready for it :)
This last weekend we burned a big pile of slash (and I dropped the nearest pine because it was in the way of the solar panels anyway) which will make the 'yard' in front of the cabin much nicer.  We have so much to clean up, however, that I think it may take YEARS to get there....but hey, we're living the dream :)
That pile was probably 20 feet in diameter and full of rotten wood from years before.  We've got several of them and I plan to buy a Bailey's fire starter (forget what they are called) so I can burn them next winter.
Once we were set up we got right to work.  Had to pull out the temp insulation, wire the walls in the 'living' room and frame the wall behind the wood stove for the hardy board -- then put the insulation back and tack it down...that was Friday.
The Hardy board isn't actually needed back there but I felt better with it and it's not expensive.  I'm going to cover it with brick also...figure it will be functional and look nice too :)
Still learning a lot about milling your own lumber but am VERY happy!  I don't think we've lost more then 10% and that includes losses in making the Tongue and Groove :)  We've also managed to use a LOT of wood I might have passed up before.  For example, sometimes we have a pretty wavy piece of pine but once the T&G is done it seems to hold to the wall just fine so it gets nailed down and we keep moving along :)  I think using 1/2" paneling is the key maybe.
I love the look and well, all of you know (or you wouldn't be here right) that milling your own, as I'm learning, is well, priceless :)
The only real problem I have now is that I want to be there and working on the cabin and not at work making money so I can go to work on the cabin!!! hahahaha
Maybe some day I'll get a bigger mill and do it for a living instead of this boring Telecom stuff ;)
Raider Bill
Quote from: OlJarhead on May 17, 2011, 10:29:35 AM
Man that sure is the truth! I'm the same way.
The First 72 years of childhood is always the hardest.
My advice on aging gracefully... ride fast bikes and date faster women, drink good tequila, practice your draw daily, be honest and fair in your dealings, but suffer not fools. Eat a hearty breakfast, and remember, ALL politicians are crooks.
OlJarhead
Quote from: Raider Bill on May 17, 2011, 10:47:27 AM
Sucks to have to work so much! haha...my last job I had 4 weeks vacation a year which I used all of at the cabin....not I have just one week, but I can take a lot of Fridays.
Raider Bill
I can take my work to the woods with me with my laptop and blackberry tethered to a point but my woods are 600 miles away. Still....not being in the office watching the help or able to grab phone calls right away hurts business.
For the 18 months I was building my house in Tenn. it was once again proved that while the cat's away the mice will play. I was gone from the business more than I was there having got caught up in the building process 600 miles away. Work suffered but I blame it on the recession, George Bush and BP oil and not that I neglected things :D
customsawyer
www.thecustomsawyer.com
