Dynamic Green Products Inc.
Author Topic: ? for magicman and others  (Read 4184 times)
Offline albirk
« on: March 15, 2011, 05:44:48 AM »
magicman you talk about hack and squirt ? is how do you hack and what do you squirt with the reason i ask i clean alot of fence rows for a farmer for my firewood he bought some brand x brush killer and the stumps looked like you planted 10 shrubs around them the fence row looks great in the spring but in the fall it is a bigger mess then before you start just would like to no what others spray the stumps with
thanks alan
Offline customsawyer
    • The Custom Sawyer
Re: ? for magicman and others
« Reply #1 on: March 15, 2011, 05:54:06 AM »
Read the label and see if the tree you are trying to kill is on there.
Two LT70s, Nyle L200 kiln, 4 head planer, 30" double surface planer, Lucus dedicated slaber, Slabmizer, and enough rolling stock and chainsaws to keep it all running.
www.thecustomsawyer.com
Offline ely
« Reply #2 on: March 15, 2011, 09:12:15 AM »
use a 50% mix of glyphosate and water it should treat cut stumps on just about every species except two.  locust and mesquite are tough to kill but it gets em most times.
if its an area thats not wet typically you can also do well with a strong mixture of diesel and pichloram? thats not the spelling sorry.
also if you are spraying cut stumps in the spring when the sap is rising it will throw off alot of the herbicide.
Offline sandhills
« Reply #3 on: March 15, 2011, 11:01:37 AM »
We primarily use Tordon on fresh cut stumps here, I have a buddy that uses a cordless drill and drills down at an angle in the stump, then puts it in the whole to kill the tree before its cut down.  Basically same principle as MM's hack and squirt.
Offline RPF2509
« Reply #4 on: March 15, 2011, 12:13:19 PM »
A good idea would be to consult with your county agricultural agent about what works and what is legal.  I agree that spring is a poor time for hack and squirt.  Usually late summer, fall and even winter if things don't freeze solid are the most effective time.  Diluting glyphosate may or may not be more effective.  Imazapyr (Arsenal trademark) can be very effective but can translocate through the soil or root grafts and damage other nearby species.  Again consult with local experts and be sure to read the product label before using.
Offline Brad_bb
« Reply #5 on: March 15, 2011, 12:28:01 PM »
I use Toradon(sp?) here on my farm.  I cut and then paint with a brush.  Works great.  Mulberry is my primary problem.  They are very resilient if you don't systemically kill them.  I just cleaned my fence rows of small ones last week.
Offline CX3
« Reply #6 on: March 15, 2011, 03:11:46 PM »
Tordon is mean stuff.  Be careful with it, they say wherever it touches the ground that nothing will grow there for 20+ years.  Or so I've heard
John 3:16
You Better Believe It!
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #7 on: March 15, 2011, 09:34:09 PM »
Tordon is soil active, so don't slop it all over the place.  It is what I use.  When treating a stump or tree, the only part that is important to coat is the cambium which is between the inner bark and the solid wood.  Painting the entire stump instead of just the cambial ring is of no value, takes longer, and wastes herbicide.  Same hold true for hack-n-squirt.  The hack does not need to be deep as long as you penetrate to the cambium.
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Offline clww
  • Oh yeah? Watch this!
« Reply #8 on: March 16, 2011, 10:38:55 AM »
Where would I go to buy some of this "Tordon" stuff?
Many Stihl Saws-16"-60"
18-Wheeler Driver for Crete
Offline Texas Ranger
  • Texan, by God and by choice.
« Reply #9 on: March 16, 2011, 10:50:54 AM »
Danny, it has been 25 years since I used any Tordon, but I seem to remember that soil contact broke down Tordon.  Do I remember wrong?  Getting old, ya know.
    • The Custom Sawyer
« Reply #10 on: March 16, 2011, 05:27:53 PM »
Tordon is very soil active. I use it treating kudzu and the like but if you are putting out a high rate per acre you have to be careful of what is down stream.
Tordon is also a restricted use pesticide and you have to have a applicators license to buy.
Offline Norm
« Reply #11 on: March 16, 2011, 05:31:41 PM »
You can buy tordon RTU at most farm supply stores. You do not need an applicators license to buy it or use it.
Offline Brad_bb
« Reply #12 on: March 16, 2011, 06:57:21 PM »
Yes there are a lot of warnings with Tordon.  There are limits as to how much can be used per acre etc. and how it can be.  Use it sparingly!  I use it mostly on small Mulberry from pencil size up to about 4 inches.  Using it on heartwood would not be effective, but mulberry doesn't have much heartwood unless it is big.  You want it to be drawn into the trees circulation system.  I obtained some from a farmer with license, but I am  very careful with the stuff, both in it's application, and my personal safety. I've learned alot about this stuff and other fungicides and pesticides (through my grape growing) . Many herbicides will go inert after a period of time.  I can't remember on Tordon unless I read the info again.  I apply it with a small paint brush and don't slop it around. I've had very good success with it killing the small mulberry trees after I've cut them, but thankfully don't have to use very much.  The same bottle has lasted for years.  Whatever you do, read and understand all the manufacturer information.
Offline JV
  • Live - love - laugh a lot today.
« Reply #13 on: March 16, 2011, 07:42:14 PM »
Has anyone used Garlon or Remedy?  Looks like Garlon runs $300-$350 for a minimum of 2.5 gallons.  If I read the online label right, it mixes 50:l with water.  Remedy runs $100 + a gallon and mixes 3:1 with diesel fuel or kerosene.  I don't believe they are restricted use.  I let my applicators license lapse years ago and haven't kept up.
John
'05 Wood-mizer LT40HDG28-RA, Lucas 613 Swing Mill, Stihl 170, 260 Pro, 660, 084 w/56" Alaskan Mill, 041 w/Lewis Winch, Case 970 w/Farmi Winch, Case 850 Crawler Loader, Case 90XT Skidloader, Logrite tools
Offline WDH
« Reply #14 on: March 16, 2011, 08:47:45 PM »
Garlon is great.  I use it as the preferred foliar spray in a 3% solution.  Mix in 3% roundup and you have a mix that will kill broadleaf hardwoods and grasses.  Neither is soil active, but this mix will kill most anything that you get it on.
Offline CX3
« Reply #15 on: March 16, 2011, 10:48:12 PM »
I get tordon at any local farm supply.  I think you do need a applicators license if buying it in bulk jugs, but I am not certain about that.  You can buy it over the counter in the little bottles without a license
John 3:16
Offline WDH
« Reply #16 on: March 16, 2011, 11:19:27 PM »
I am not sure if the small bottles are full strength or not.
I think that Remedy is the generic for Garlon 4.
Offline Don_Papenburg
  • I need money
« Reply #17 on: March 17, 2011, 12:01:04 AM »
I use generic glyphosate straight up ,applied with a brush to the mulberry stump .  Just paint it on wet with fullcoverage. tree quits growing.
Offline WildDog
« Reply #18 on: March 17, 2011, 04:04:05 AM »
WDH hit the nail on the head, just paint the cambian layer.
Not sure how relevant it is for you guys on that side of the world. Down here I use Tordon or straight roundup for stem injection, some of the generic glysophates are very thin and I have found some regrowth on our eucalyptus, for honey locusts and in riparian zones I basal bark with a mix of diesel and starane (picloram should do it) just use a backpack and spray the trunk for a couple of feet.
If you start feeling "Blue" ...breath    JD 5510 86hp 4WD loader Lucas 827, Pair of Husky's 372xp, 261 & Stihl 029
Offline Norm
« Reply #19 on: March 17, 2011, 06:51:03 AM »
They've dropped the price of the real roundup so much you can buy it for what they sell the generic for. Be careful of what you buy labeled as roundup because some of the extended use kinds have soil active additives with it. I have well water so I do not like using anything that persists. The tordon rtu has a popup top and you can use just a tiny bit around the stump edge like Danny says. Never had one come back from that.
Magicman's Get Together
Started by Magicman on Shows, Events and Places to meet
Last post April 04, 2010, 10:29:40 PM
by Magicman
Thank You Magicman
Started by paul case on Sawmills and Milling
Last post March 08, 2013, 04:50:26 PM
by thecfarm
Thanks to Magicman
Started by pnyberg on Sawmills and Milling
Last post April 05, 2011, 12:11:29 AM
by captain_crunch
Magicman has Some new help
Started by Radar67 on General Board
Last post January 15, 2011, 09:47:14 PM
by Magicman
