We have contest winners!
I had a job yesterday where I used not one, but two tricks I learned from Magicman here on the Forestry Forum.The customer had one large log from a tree taken down in the front yard just the day before I arrived with my mill. The front yard was not large, and on the whole was not even close to level, but there was one spot right along the front of the house that was level enough to set the mill up on. Of course, that's not quite where the log was. It was about 20 feet away downhill. --Peter
Nice milling job for sure, I was curious how do you charge customers so that you are able to make it profitable for you to go and mill up one log like that?
Quote from: northwoods1 on April 04, 2011, 08:44:07 AMNice milling job for sure, I was curious how do you charge customers so that you are able to make it profitable for you to go and mill up one log like that?My pricing structure is $1.00 per mile one-way to bring the mill to the logs, $60.00 per hour for labor, whether milling, moving logs, stacking lumber or whatever, and $25.00 for each blade damaged by foreign objects. I charge for the time it takes to set up the mill at the start of the job (usually about 15 minutes), but not for the time to pack it up at the end.--Peter
Started by albirk on General Board
Started by Ga Mtn Man on Sawmills and Milling
Started by paul case on Sawmills and Milling
Started by Magicman on Shows, Events and Places to meet
