Walnut question
Started by 123maxbars, March 28, 2011, 10:54:29 PM
123maxbars
Hello new to the forum and hope to get my first sawmill this summer if finances are good, I have a walnut tree in my back yard that I recently dropped, two days ago. I want to save the tree for my sawmill when I get it this summer. My question is how long can I store the log  before I mill it? Also i assume it needs to be stored off the ground, but does it need to be covered from weather? thanks for any suggestions,
Sawyer/Woodworker/Timber Harvester
Woodmizer LT70 Super Wide, Nyle L53 and 200 kiln, too many other machines to list.
outofthewoods
Youtube page
Out of the
terrifictimbersllc
Get the freshly trimmed ends heavily coated with Anchorseal and keep it on the ground.  Walnut lasts a long time and in my opinion drying out is the worst danger, simply because of cracking. Even so it is pretty resilient to that anyway.   Wet walnut might lose some of the sapwood to certain insects but they don't go for the heartwood.  I've cut walnut that was half buried in the ground for and covered with vegetation which was quite beautiful even after 3-4 years.  Somewhere I read once that burying walnut logs in a barnyard for years gives great color.   Shouldn't be any problem sawing those logs this summer.
Left Coast Chris
Since it will warm up pretty soon you should also keep the logs out of the sun.  If you have no anchor seal you can use latex paint but give it several coats on the ends.  Another thought is find someone with a sawmill and see if they will teach you how to saw it on thier mill.   It is good to get the air drying of the boards going before the heat hits also.
Home built cantilever head, 24 HP honda mill, Case 580D, MF 135 and one Squirel Dog Jack Russel Mix -- Crickett
First, Welcome 123maxbars, to the Forestry Forum.  Good luck with your upcoming sawmill purchase.
Get the logs off of the ground.  Sealing the ends will help also, but I wouldn't worry about the rain.
