Author Topic: Simple Question  (Read 1751 times)
Offline grassfed
    • Kingdom Hill Farm
Simple Question
« on: April 06, 2011, 08:02:54 AM »
I have tried to use the Tool Box Calculator but it I cannot find a good way to get the answer to this question. How much do green balsam fir saw logs weigh? I need to know how many bf I can load on a truck that can haul 10 tons.
Mike
Offline Autocar
Re: Simple Question
« Reply #1 on: April 06, 2011, 08:11:33 AM »
If you don't get the answer from this forum , I would throw a average size log that you cut in your area and haul it to a feedmill or junk yard and get it weighed on there scale then just deduct the truck weight.
Bill
Offline DanG
  • DanG, The Official ForestryForum Cussword
Re: Simple Question
« Reply #2 on: April 06, 2011, 08:37:03 AM »
I didn't have any trouble finding a weight for a Balsam Fir log using the Forum Calculator.  To get your answer in board feet, you would need to first find the weight by log size, then convert to bf. ;)
Offline Gary_C
  • Sunrise on the Prairie
Re: Simple Question
« Reply #3 on: April 06, 2011, 08:38:45 AM »
I believe the standard conversion used here in MN is 4700 lbs per cord, same as white pine and red pine. I have been hauling balsam to a pulp mill and it is being stick scaled and from what I can guess of the weights of the truck loads, I would guess it is weighing somewhere between 4200 lbs and 4500 lbs. per cord.
If it's in logs, you do not want to go by wt per bd ft.
Offline barbender
Re: Simple Question
« Reply #4 on: April 06, 2011, 10:31:22 AM »
Balsam can vary a lot, I would go with around 4700 like Gary said, to be safe. It all depends on how wet the wood is, and that varies from job to job.
Offline Rick Alger
Re: Simple Question
« Reply #5 on: April 06, 2011, 04:23:13 PM »
Around 8500 pounds per thousand board feet. It does vary quite a bit. If you speak French, you could get some good info from the scaler at Lauzon's.
Offline g_man
Re: Simple Question
« Reply #6 on: April 06, 2011, 07:33:24 PM »
For rough figuring on balsam saw logs I use 500 BF per cord and 2 ton plus per cord which gives a little over 8000 lb MBF like Rick said
Offline snowstorm
Re: Simple Question
« Reply #7 on: April 06, 2011, 07:43:11 PM »
in maine most pulp mills used 4100 to the cd so 8200. the fir will almost always weight more than spruce. so the fir may weight a bit more depending on where it grew
Offline barbender
Re: Simple Question
« Reply #8 on: April 07, 2011, 01:03:22 AM »
If you watch trucks around here, you will notice they are stacked about 2' higher when hauling spruce. Our spruce is a good bit lighter than balsam (green)
Offline Ron Scott
  • Forester
Re: Simple Question
« Reply #9 on: April 07, 2011, 07:47:46 PM »
Average weight of Balsam fir logs 12 to 24 inches in diameter per 1000 feet on basis of Doyle Log Scale rule is:
7,900 lbs. green
4,400 lbs. dry
~Ron
Simple question.
Started by hackberry jake on Sawmills and Milling
Last post March 11, 2012, 03:21:18 PM
by jim blodgett
LT40 Simple Set Question
Started by Poquo on Sawmills and Milling
Last post September 15, 2019, 05:51:26 PM
by Poquo
Simple heartwood question
Started by Mortice on Timber Framing/Log construction
Last post March 06, 2008, 07:36:54 PM
by ohsoloco
Question about Simple Set on my LT35
Started by Ruffneck on Sawmills and Milling
Last post April 12, 2013, 04:43:36 PM
by Ruffneck
