Author Topic: HELP on ford diesel tractor  (Read 31651 times)
Offline dovetails
« on: April 08, 2011, 11:02:05 AM »
Hi. My tractor just decided it don't want to start anymore! Parked it under the shelter sat,after using it for an hour or so,went to use it tuesday, and it will not start.Turns over good,but will not fire up.Also sounds like it don't have compression it should. I changed the fuel filter,had maybe a teaspoon full of water in it.Bleed the injector lines, getting fuel there ok.        When it's cold out,40's or lower, I just give it a wiff of starting fluid, it'll turn maybe twice and fire up.(saves wear and tear on the starter and battery) If I got a little to much either in it, it would either lock it up, or knock bad for a min,then run fine. Now I can squirt the either to it, and it don't do nothing,no knocking, no lock up, just keeps spinning over like I had not sprayed it at all. It's a 300 ford 3 cylinder. Friend says it has timeing gears, not chain so can't jump timeing,Pulled valve cover everything is moving ok,don't look like a stuck valve or bent pushrod.  You can feel it sucking air into the intake, and blowing out the exhust,so why won't it fire up, or lock up with either????? Battery fully charged, even tryed with jumpers off my truck, no difference  Any ideas??
1984 wm lt30,ford 3000 w/frt lift,several chain saws, 1953 model 30 Vermeer stump grinder,full wood working shop, log home in the woods what more ya need?
Offline red oaks lumber
Re: HELP on ford diesel tractor
« Reply #1 on: April 08, 2011, 11:13:24 AM »
not trying for the smart*** award but, is the kill pull pushed in ? if your using that much eather you might have done serious motor damage. you never want to dry sseize your motor.your rings mightr be gone leaving no compression to fire with.
Offline dovetails
« Reply #2 on: April 08, 2011, 11:23:34 AM »
Yes, was first thing I checked, have tryed to start it with it out before.Even tryed pushing on the levr itself in case it wasn't moving far enough with the cable. I understand about not using to much either,thats why I just spray a little at the intake when using it. No way it could lose the rings that fast,setting for a couple days after running great a couple days before. Also too much should just make it bind up and not turn over,it keeps turning fine,like it is not getting into the cylinders. If it was a gas engine I would say it was not getting fire to the plugs....
Offline beenthere
« Reply #3 on: April 08, 2011, 11:34:59 AM »
Do you have a fuel shutoff solenoid on that engine, or is it done with the kill lever?
Offline dovetails
« Reply #4 on: April 08, 2011, 11:40:30 AM »
cable pulls a lever on the injector pump,stopping the fuel..
in fact the generator don't charge,so after starting I just turn the key off,till next time I start it again,so the battery don't run down.Only thing that uses power is the starter itself.
Offline iffy
« Reply #5 on: April 08, 2011, 12:32:46 PM »
If you crack one of the fittings where the fuel line attaches to one of the injectors as if you were going to bleed it and then crank it does it squirt any fuel out?
Offline scsmith42
    • Whispering Pines Farm
« Reply #6 on: April 08, 2011, 12:52:40 PM »
The fact that it's not hitting even with ether makes me suspect compression.  However, it would be odd for all cylinders to lose compression at the same time, unless there is a compression release valve that is stuck open, or the timing gear wore to the extent that it jumped time.
Tom's 3638D Baker band mill
Offline dovetails
« Reply #7 on: April 08, 2011, 12:59:19 PM »
Yes, all 3 squirt fuel when I tryed it.
Offline dovetails
« Reply #8 on: April 08, 2011, 01:10:46 PM »
Even with low compression, wouldn't it fire the ether? Also all the valves seem to be working properly,just a little slack on pushrod when rocker arm is at top,go up and down fine. If out of timming,wouldn't it blow back through the intake,like a gas engine does? No blow back, steady pull into the intake manifold.Also it ran fine the other day,plenty of power,no funny noise ect.  As I said, I parked it and shut it down as I always do,now this problem.    The cable I pull to stop it moves a small lever on the injector pump, that would be a shutoff valve right,stopping the fuel flow,to kill the engine.  Also have tryed1/4 throtle, and full throtle, same results.
Online thecfarm
« Reply #9 on: April 08, 2011, 01:14:39 PM »
What do I know. I had a Ford truck with a fiber gear that got chewed up somehow.Something has to give on the front of the motor,I would think.Be it a timing chin or a fiber gear.With the gas motor the cam for the distributor cap was  not turning.But I was going down the road when this happened.
Offline dovetails
« Reply #10 on: April 08, 2011, 01:33:23 PM »
if the gear striped,or a chain broke, the cam does not turn to make the lifters go up and down, mines opening and closing the valves,  also no way all cylinders can have open valves at the same time to lose all compression at once.   (I've had a couple of those plastic timming gears come apart in the past also,replaced with steel gears!)
Offline snowstorm
« Reply #11 on: April 08, 2011, 07:11:45 PM »
ok how many times did you either lock it????you say it only knocks for a min??too much either bends rods and breaks rings. more often breaks rings. first sign of lock up stop let it sit for at least 5min
Offline isawlogs
  • A smile is contagious ... Start an epidemic
« Reply #12 on: April 08, 2011, 07:31:55 PM »
I would guess that the timing is out. You probably have striped a tooth and now it aint where it should be.
   Marcel
Offline snowstorm
« Reply #13 on: April 08, 2011, 07:42:08 PM »
had a case that the valve keepers came off valve droped into the piston fixed that 2yrs later happened again. pull the valve cover see if a valve is stuck.
Offline chevytaHOE5674
« Reply #14 on: April 08, 2011, 08:12:13 PM »
Sounds like you may have killed it with either. If you are using enough either to get the motor to lock up or knock you have done damage. You should only be spraying ether while the motor is spinning and only a little shot to get it going (I try not to use it on my ford diesel tractor at all)
Instead of ether use WD-40 from now on. Its less volatile and easier on the motor.
Offline lumberjack48
  • 36 yrs ago, cutting Ash saw logs
« Reply #15 on: April 08, 2011, 08:15:08 PM »
I think its flooded, hold the shout off out on till it starts to fire, than push it in real slow, should take off
Just a thought
Offline dovetails
« Reply #16 on: April 08, 2011, 08:32:02 PM »
ok how many times did you either lock it????----over the 15 years I have been running it, maybe 5 times total,all of them after running out of fuel and getting it restarted again,  if I give it just a bit too much on normal start up, it goes  knock,knock 3-5 times then is running fine, I don't just drownd it in ether every time I start it...  as I said, I've been doing this for 15 years with this tractor,and it gets used all the time, summer and winter. Never sets more than a week at the longest.
I would guess that the timing is out. You probably have striped a tooth and now it aint where it should be.------Thats the next thing I plan to check, have friend with the book on it,going to give me a hand.He also is trying to borrow a compresion checker to test that also.
had a case that the valve keepers came off valve droped into the piston fixed that 2yrs later happened again. pull the valve cover see if a valve is stuck----------valve cover is off, all valves look to be working properly,but could be out of timeing I suspose.  in 15 years of hard use, this is the first problem other than water in fuel a couple of times,even then it would try to start with ether. It even got rained on once and was blowing water out the exhust stack when I fired it up.Thats why it goes under the shelter when parked since then. Hope to be checking timming and compresion sat.sometime, will see what that tells me.
Sounds like you may have killed it with either. If you are using enough either to get the motor to lock up or knock you have done damage. You should only be spraying ether while the motor is spinning ------YES
and only a little shot to get it going----again YES
When it would not start on it's on, with temp about 70 degrees, then I tryed the ether...no change.
I think its flooded, hold the shut off out on till it starts to fire, than push it in real slow, should take off
Has set over night, same thing next morning so not flooded   if the shut off is pulled out,it gets no fuel,and can't fire on an empty cylinder.
« Reply #17 on: April 08, 2011, 08:47:37 PM »
 T he reason i said this was because it happened to me, i worked on it 4 days and couldn't get it started, than a guy told me to hold the shut off out on till it started blowing white smoke or started to fire, than push it in real slow, it started right up. Its sure worth a try
Offline snowstorm
« Reply #18 on: April 08, 2011, 08:48:41 PM »
you asked for help i wont sugar coat it. i have been working on this stuff since 1975 even got a degree in diesel tech somewhere. too much either it fires while the piston is coming up sumpin s gotta give. a diesel is compression ingiton it compresses the air in the cyl till it gets so hot it explodes at that time fuel is injected
« Reply #19 on: April 08, 2011, 08:50:23 PM »
Get a compression gauge and check compression. These fords do not like ether much at all and are known for holes blowing in pistons when ether is used too much. (Thus why I recommend WD-40.)
In the last 5 years I can only remember using ether on my ford 5000 1 or 2 times. And I too use is all the time.
MF135 Diesel Tractor --- Diesel leaking into crankcase
Started by Left Coast Chris on General Board
Last post May 25, 2008, 08:29:56 AM
by zopi
FORD 860 Tractor 6V or 12V & Other tractor Questions
Started by Gilman on General Board
Last post November 13, 2005, 06:25:25 AM
by Lud
Ford Diesel
Started by Slabs on General Board
Last post June 30, 2012, 12:57:36 AM
by Bobus2003
7.3 Ford Diesel
Started by Corley5 on General Board
Last post May 29, 2014, 08:37:54 PM
by snowstorm
