Author Topic: I bought a LT15 Electric today  (Read 3905 times)
Offline sst04
« on: May 27, 2011, 09:54:56 PM »
I made a post about wiring an electric mill the other day. Well, today I went to check one out and came home with it.
LT15 Electric 1 phase, One Extension so it will cut I think a little over 22 ft long, 8 new blades and 2 cant hooks.  Mill is 6 years old, but has not been used in the past couple of years.  Was told it had only been used around 100 hours.  It looks good, Faded just a little, and the paint is coming off some parts of the rails, but not too bad.
We started it up and it seemed to work well, as far as I could tell.  You could tell it has not been used for a while because of the rust on the blade.  The up down works good and the hand drive works good.
Now all I have to do is get a spot leveled up and some concrete poared, then have it wired and figure out how I am going to make the wire carrier.
Got it for 3300$, in your opinion is that a Good, bad or decent deal?
Offline Slingshot
Re: I bought a LT15 Electric today
« Reply #1 on: May 27, 2011, 10:11:16 PM »
       Sounds to me like you got a good deal.
___________________________
Charles
Offline fishpharmer
« Reply #2 on: May 27, 2011, 10:20:20 PM »
Congrats on the mill purchase sst04. The lt15 is a great mill.  What horsepower motor does it have?
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #3 on: May 27, 2011, 10:28:01 PM »
Yes, a very fine deal.
Offline sst04
« Reply #4 on: May 27, 2011, 10:29:23 PM »
It has the 10hp electric.
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #5 on: May 27, 2011, 10:43:32 PM »
I would say you have a great mill there at a great price.
Offline fishpharmer
« Reply #6 on: May 27, 2011, 10:45:46 PM »
I am looking forward to your report on on the 10 hp's performence.  Please keep us posted.
What are you planning to mill, species?
Offline BandsawWarrior
    • T&N Custom Sawmill - Specializing in Premium Fir Products
« Reply #7 on: May 27, 2011, 10:46:50 PM »
great deal!
Tyler Hart
T&N Custom Sawmill
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #8 on: May 27, 2011, 11:19:18 PM »
And congratulations are in order.   :) :)
Offline DouginUtah
  • You can't always have a tailwind, sometimes it's going to be a headwind.
    • Doug Sherwin's Homepage
« Reply #9 on: May 27, 2011, 11:56:41 PM »
Now the electrical-savvy guys can give you some advice on what size breaker you will need and what gauge of wire--if you tell us how long the run will be.  ;D
-Doug
When you hang around with good people, good things happen. -Darrell Waltrip
There is no need to say 'unleaded regular gas'. It's all unleaded. Just say 'regular gas'. It's not the 70s anymore. (At least that's what my wife tells me.)
Offline ladylake
« Reply #10 on: May 28, 2011, 05:09:05 AM »
 Sounds good, good price and a nice simple mill and even better with electric power .   Steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline mometal77
« Reply #11 on: May 28, 2011, 05:48:23 AM »
So after you bought/loaded it did you put the pedal to the floor board.   Like in a smokey the bandit movie? :D
Too many Assholes... not enough bullets...I might have become a millionaire, but I chose to become a tramp!
Offline Bibbyman
    • Warden Sawmill
« Reply #12 on: May 28, 2011, 06:07:08 AM »
Congratulations on the new to you mill!
Rust on a blade thats been used and then exposed to the elements will start to rust in a few days.   So I wouldnt let that be an indicator of the condition of the mill.   Make a few cuts with the blade and itll clean right up.
Sawing since '94
Offline bandmiller2
« Reply #13 on: May 28, 2011, 06:32:05 AM »
An electric motor is a real spoiler on a mill,  makes it hard to go back to engines.Mills love to have a roof over their heads especially the lectric ones. Good deal. Frank C.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #14 on: May 28, 2011, 07:09:55 AM »
Looks like you made a fine deal sst04!  8)
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline thecfarm
« Reply #15 on: May 28, 2011, 07:15:34 AM »
You will be happy with the sawmill. I was only around a electric wood splitter at a show. I loved it. Very quite. Seemed real odd to see it working but no loud noise of a gas motor.
Could WM help you out with the carrier? I would give them a call.
What's all the lumber going to be used for? Do you have trees to cut?
Good idea with the cement. May want to raise the mill up in the air too. Kinda get it at a good working height. Can you make the pad bigger than the mill too? Easy clean up,place to store,dry lumber with a roof.
Offline LPitt
« Reply #16 on: May 28, 2011, 07:27:52 AM »
Congratulations and welcome to the club. Where in Georgia are you located?
Linn Lumber 1900 hyd, Bobcat T190 with grapple ect., Kubota MX 5100, Ford 555E backhoe, Sthil ms460, home made wood splitter, and more projects than I can count.
Offline sst04
« Reply #17 on: May 28, 2011, 11:19:33 PM »
I checked out the Meterbase/Box that is mounted on the Pole next to my House(mobile home) and it is a 200amp disconnect with 4 slots for breakers and a Max of 150 amps for breakers in the box. 2 of the slots are used for the AC unit which is a 30amp breaker.  The mill came with around 30 to 35 feet of wire, I may end up having to get a little more but not much.
I am hoping that I will just be able to add a receptical (like a welder receptical) to the pole, using the other 2 available slots left in the breaker box. So I can unplug the mill when not in use or when I need to cut grass or whatever.
Maybe a 60 for the mill?
Offline sst04
« Reply #18 on: May 28, 2011, 11:26:23 PM »
The lumber will be used to eventually build a house, right now I am going to focus on building a Kiln and a few other things around the yard.
We have the land to cut trees off of.  Also, I helped a friend out today that does Lot clearing, they had someone getting the trees for them but he never got paid so he said he would give them to me.  At this lot, he said he cut the big pines up to 20ft and had enough to fill up his Mack dump truck 2 or 3 times.   He is supposed to get them loaded and bring them over next week.
As far as setting up the mill, I am going to think about it a few days, instead of just sticking it together.
Offline sst04
« Reply #19 on: May 28, 2011, 11:28:23 PM »
Milledgeville, about an hour east of Macon.
Thanks for all the compliments guys,  It makes me feel better knowing I got a great
deal 8)
Bought an LT15
Started by mdennisusa1 on Sawmills and Milling
Last post July 17, 2013, 09:07:27 PM
by mdennisusa1
cheesy
Help I Bought A WoodMizer LT15
Started by Hyrb on Sawmills and Milling
Last post February 25, 2019, 09:14:45 PM
by Hyrb
WM....LT15....... GAS OR ELECTRIC ???
Started by roger 4400 on Sawmills and Milling
Last post April 02, 2008, 08:35:33 PM
by roger 4400
Wanted lt15 electric
Started by sst04 on Wanted
Last post January 20, 2015, 02:10:00 PM
by sst04
