Author Topic: Black Pineleaf Scale  (Read 1093 times)
Offline DouginUtah
  • You can't always have a tailwind, sometimes it's going to be a headwind.
    • Doug Sherwin's Homepage
« on: June 26, 2011, 11:52:15 PM »
Just saw a story on the local news about a beetle called Black Pineleaf Scale. Salt Lake and Davis counties have been fighting it for several years and it is worse this year, but they are cutting the infected trees down and hope to get a handle on it.
I'm confused as to the word Scale: Is it the name of the insect or the result of it producing a scale on the needles?
Genus: Dynaspidiotus
Species: californica
Scientific Name
Dynaspidiotus californica
Scientific Name Synonym (I'm ignorant about synonyms having a different Genus name.  :-\  I've never even heard of synonyms.  :D)
Nuculaspis californicus
Nuculaspis californica
-Doug
When you hang around with good people, good things happen. -Darrell Waltrip
There is no need to say 'unleaded regular gas'. It's all unleaded. Just say 'regular gas'. It's not the 70s anymore. (At least that's what my wife tells me.)
Offline JimTwoSticks
  • Killed a grouse with two sticks once
Re: Black Pineleaf Scale
« Reply #1 on: June 27, 2011, 11:19:00 AM »
Quote
Both :)
Insects and diseases are often named for what they appear to cause or how they appear to the individual observing them (oak wilt, red oak borer, redheaded sawfly, etc.). In the case of black pineleaf scale you would see somewhat hardened black bumps on the pine needle (thus you get "black pine leaf scale").
The "scale insects" are a group within the class Insecta that feed on plant sap (there could be scales that feed on other things, I just don't know of any).
Synonyms of scientific names are important - but only a little in practical application. It helps you if you are looking at older literature or discussing the issue with someone who has been around for a while. Basically, scientists change the name for one reason or another.
For example. Hypoxylon canker of aspen caused by a fungus named Hypoxylon mammatum has more recently been described as Entoleuca mammata (there are also other synonyms for this fungus). Depending on who you were talking to they may only recognize it as Hypoxylon mammatum and if you only knew it as Entoleuca mammata it would be beneficial to know the synonyms to realize that you both were talking about the same organism...generally discussions like this will only occur in the scientific community, all others would just refer to it as Hypoxylon canker and all would be fine...very confusing  :)
question
LT40 SW UP/ DOWN OUT OF SYNCHY WITH SCALE RULER SCALE
Started by Daniel on Sawmills and Milling
Last post March 02, 2012, 10:32:26 AM
by Magic Smoke
Log Scale/Board Scale question
Started by Ugly Tree on Sawmills and Milling
Last post October 29, 2015, 07:11:50 PM
by Peter Drouin
question
Black Tupelo-- Black Gum-- Sour Gum--
Started by Okrafarmer on Sawmills and Milling
Last post April 26, 2012, 09:23:31 AM
by Okrafarmer
Black bear in Missouri black bear on my farm??
Started by Bibbyman on The Outdoor Board
Last post May 25, 2015, 07:51:17 PM
by Shotgun
