Dynamic Green Products Inc.
Author Topic: Stihl 090 has squeak in engine.  (Read 3121 times)
Offline acco1840
    • facebook
« on: July 05, 2011, 02:27:34 AM »
My old 090 has developed an internal squeak that gets worse with engine revs, but doesnt go away on idle. Have taken off clutch to tryu that, and made no different. Tried the same with the starter. Any ideas?? I took off the muffler, and it (the squeak) became louder.....
Offline ladylake
Re: Stihl 090 has squeak in engine.
« Reply #1 on: July 05, 2011, 06:40:20 AM »
 Could be a bearing going out, time to pull the jug and look.    steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline clww
  • Oh yeah? Watch this!
« Reply #2 on: July 05, 2011, 08:51:06 AM »
I would guess a bearing, too. Especially since you pulled the muffler and it got louder.
Many Stihl Saws-16"-60"
18-Wheeler Driver for Crete
Offline SwampDonkey
  • Forester
  • Large Tooth
« Reply #3 on: July 05, 2011, 04:01:49 PM »
Bearing, it'll soon make a nice rattle. :D
Move'n on.
Offline acco1840
    • facebook
« Reply #4 on: July 16, 2011, 02:40:26 AM »
Found out what it was.........She broke a piston. :(
Offline ladylake
« Reply #5 on: July 16, 2011, 05:43:59 AM »
 Good to find that out before it grenaded, check those bearings while you have it apart.  Also make sure there's no broken piston parts hiding in the crankcase.    Steve
Offline SwampDonkey
  • Forester
  • Large Tooth
« Reply #6 on: July 16, 2011, 05:54:08 AM »
Just speculative here, but musta been a bad ring(s) or bearing to eh?
Move'n on.
Offline acco1840
    • facebook
« Reply #7 on: July 17, 2011, 04:28:26 AM »
yeah, rings were loose in the groove.
Offline acco1840
    • facebook
« Reply #8 on: July 31, 2011, 03:58:16 AM »
Pulled her down and discovered it had let go the big end bearing that holds the Conrod to the crank and it drove bits of it through the piston. Not happy. Luckily, the conrod is the old un-Boltable type, but sadly, it buggered the crankshaft. Am in the process of bolting all of my bits (Coil, clutch, Carb, Handles etc), to another 070. Got new set of genuine 070 rings from local Stihl dealer- $28 each!!
Will be firing her up tomorrow.
Offline SwampDonkey
  • Forester
  • Large Tooth
« Reply #9 on: July 31, 2011, 06:55:54 AM »
Figured a bearing went. ;D
Move'n on.
Offline sharkey
« Reply #10 on: August 02, 2011, 07:07:00 PM »
>>Got new set of genuine 070 rings from local Stihl dealer- $28 each!!<<
Wowie!  Gold plated?
question
LT40 Engine Pivot SQUEAK!
Started by Ga Mtn Man on Sawmills and Milling
Last post October 10, 2017, 09:34:51 PM
by 4x4American
LT40 voltage drop engine bog alternator belt squeak
Started by jovol on Sawmills and Milling
Last post January 13, 2019, 07:09:00 PM
by POSTON WIDEHEAD
A squeak, then a squeal!
Started by crowhill on Sawmills and Milling
Last post October 23, 2017, 07:00:27 AM
by Chuck White
Brake Squeak - Super 70 Question
Started by YellowHammer on Sawmills and Milling
Last post June 02, 2019, 06:24:45 PM
by Percy
