Whoa, I might have bit off more than I can chew: BIG BIG logs
Started by MotorSeven, August 02, 2011, 05:00:54 PM
Bibbyman
Tamiam,  I know where you're coming from.
We sale fencing lumber to a lumber yard/farm supply place some 20 miles away.  They get an order for oak fencing lumber and leave us a message with specs and quantity, etc.  We come in and respond with when we can deliver and do.  They write us a check and we're gone.  They've spent the time dealing with each customer and making the final delivery, collecting, etc.  We can saw.  That's what we do best.
I had a load go to them early in July.  Got to the office to pick up the check and they were talking about getting it on the truck to deliver.  They mentioned it was going back almost to our mill.  Turned out it was going to one of our old customers.  We had sawn for him a number of times but he was awful bad about making appointments at off times to pick his stuff up and then not showing up.  He quit ordering from us and went to our "competition".  I'm sure he thinks he's getting a better product now that he's paying the middle man.
Sawing since '94
MotorSeven
The Mega Hook arrived yesterday...that was fast. The name is fitting and looking at this monolith I am wondering if my puny 6'4" 230 lb self is enough to get it moving .......maybe I should eat more BonBon's :D
WoodMizer LT15 27' bed
paul case
congrats on the new purchase. i never wanted one of those. still dont. good to know how to get one but if its bigger than my 48'' logrite can turn, i use other methods.
my little forklift is a big help but i rarely turn a log with it. just pick up the pieces and reload. i was wondering if you were trying to make multiple 5''x10'' beams out of one log? even if you were it makes more sense to me with a manual mill to make some cuts and slide them off to the side to reload and edge after the log is all cut. this greatly decreases the size of the log and it is considerably easier to turn. i usually only turn 1/4 each time so there is less turning altogether. my mill has a hand winch with a cant hook on it to aid in turning the  biguns and it gets some use, but i usually turn with my 48'' logrite. it works great. i bought mine from my mill manufacturer at a farm show and avoided shipping completely.
Tammy,
thats a great set of tools youall make. no mill is complete without one.  here is my logrite when it was new.
the last 2 pics are my log turner set up on the ez boardwalk 40. i have turned serveral 26'' to 34'' logs with it.  good luck. pc
pc
MotorSeven
Paul that log turner is not a bad idea. I picked up a HF manual winch set up with a short boom like the ones that go in the bed of a truck. It was missing a few things but it was ony $20 at the flea market so fabbing that up should be pretty easy. If I can't get 'em turned with the two Logrites than I will look into this.
MotorSeven
Well, y'all were right, they are "doable". I had some help so we tackled some of the biggest logs. This one was 24" after we trimmed off the flair and the 55 horse tractor could not pick the whole thing up, so I had to drag & roll it to the mill, then lift one end up at a time. We used the chain method to turn it and it actually works quite well, you just have to go slow and easy. This log turned out 4 - 5"x10"x24' rafters:
MotorSeven
MotorSeven
Quote from: Jeff on September 08, 2011, 10:01:23 AM
Nice!  Working right next to the pond eh? ;)
Ha, yes, we got pummeled with 36 hrs of straight rain from TS Lee. It was drizzling all day yesterday while we sawed....it's nice to have a roof over the mill!
zopi
Nice! A solution I came up with for you guys on a manual mill, I set up a tripod over the mill...made out of fout by fours...has a rigging ring hanging from it...hang a portable electric winch from it or a chain fall...wrap the log and dog the chain to it...slow, but hey.
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
Looks good. Any longer and you'll have to have an extension.
MotorSeven
Quote from: thecfarm on September 09, 2011, 08:38:37 AM
...and a bigger tractor...and a bigger mill shed...and...... :D
MotorSeven
Update:
Well, with help I milled the whole whack of Hemlock....THE 78" Lorgite Cant Hook Rules! I have 19 5x10x23' rafters.....5 short :'(  I called my logger last night and he promised to help me find a few more trees. My log walls are almost done..lacking one row. I am cutting and peeling Poplars tomorrow for the tie poles. I set the loft beam today that I milled out of SYP...5x10x30(two sections). So until the Hemlock arrives I will be milling the loft floor joists out of SYP....3x6x16'.
I can't wait to get the roof on...this cool spell has me worried that winter is coming on hard and fast :o.
5quarter
Very nice place indeed. I'm not a timber framer, but it seems that the beam on the left in the photo needs a second post. enough load and it might split along its length. Please correct me if I'm wrong.
Blue Harbor Refinishing
A log cabin bunkhouse is in my future.  Thanks for sharing your pictures.
MotorSeven
5Q it is going to have a 8" pocket screw in it from underneath....just haven't got to that yet. You are right the "L" notching leaves a weaker side(ok for lighter stuff) so fo my ridge rafter it will be a 60 degree slant joint...no notch.
MotorSeven
I want to thank everyone here that helped me on these big logs...they are now all up living as rafters in my house:
I start decking the roof tomorrow.............!
clww
Very impressive work and photos, too! 8) Please keep updating us.
Many Stihl Saws-16"-60"
18-Wheeler Driver
Where was that sky hook when I needed it  ???
I love the building.  Really, I'm jealous.   ;D
ljmathias
Very nice work, Motor- looks like you're going to have a 2nd floor or loft in the house?  Pretty wood- you going to stain or seal it?
Lj
LT40, Long tractor with FEL and backhoe, lots of TF tools, beautiful wife of 50 years plus 4 kids, 5 grandsons AND TWO GRANDDAUGHTERS all healthy plus too many ideas and plans and not enough time and energy
MotorSeven
Yes the skyhook was a life saver, it only took us 5 hrs to hang 24 rafters and the two section ridge beam. It was $600 bucks well spent.
Lj, pressure wash and seal on the outside, 40 grit disc sander on the inside(my shoulders ache just thinking about that).
I looked high and low for some air dried sawmill 4 quarter to deck the roof, but the prices for 2100 sq ft were around $2K for Pine and Hemlock. I ended up with kiln dried finished SYP 2x10's from {cough}Lowe's....$1400.
Marc Thornton
Looks real nice.  I'm jealous too.
Just a thought, should you be staggering the joints on those roof boards?
