When is best time to split wood?
Started by markkelly, August 09, 2011, 11:03:16 PM
upsnake
John MC- Why is that?
I have had a couple of pieces so far (not frozen) that have kind of "popped" apart when splitting, took one right in the gut. Ouch . Hahah
John Mc
"Popping apart" is one thing. Shooting 50 feet is quite another. Hydraulic fluid is not compressible, so once the log starts to give, the pressure should be off until the ram moves further forward into the log. Since most splitters move relatively slowly, it's the rare piece of wood that will get thrown from the splitter.
If you have air in the lines or cylinder, that will compress under load. If a log "lets go" the air expands, shooting the log out. The air acts like a spring under load. I've had it happen a couple of times on a friend's splitter. Topped off the oil, cycled the cylinder a few times and tightened up a loose hydraulic connection, and the problem went away.
shelbycharger400
i remember as a kid around 5 or 6, parents takin down a 4 ft dia red elm,  the trunk was cut into 16 in wide ,  basically the Wheels sat behind the woodpile for ?, til i was 18-19 then got torched whole at a buddys house. lol they were solid and heavy as u know what.
i run red elm through the splitter.  just have to take small bites at a time til its a lil bit smaller.    Maple is way harder than the red elm
upsnake
John  MC -- Makes sense. Thanks  8)
Busy Beaver Lumber
Nope, no air in the lines, just a piece of wood with a lot of tension in it that popped almost immediately when the ram touched it. That one log did it several times, but once the first piece shot off, I was more alert when it did it a second time and the second piece only went about 5 feet.
Woodmizer LT-10 10hp
6 x 10 dump trailer
Grizzly 6in Spiral Cut Joiner
Twister Firewood Bundler
Jet 10-20 Drum Sander
Jet Bandsaw
Save a tree...eat a beaver!
Busy, I know you split a mountain of wood. But, I've never seen wood fly off a splitter like that. Any I've split just drops to the ground. I suppose a piece could slip if the ends are cut on a slant by a dull saw. The knife on a splitter is usually canted toward the ram to reduce the chance of it popping up when rammed and to start the split easier. The one we use does not go at the wood piece fast just slow and easy. We don't have an automatic return, but to get around that all we did was use a chain with a spring on it. As soon as you release the handle the spring pulls back on the handle.
Al_Smith
That so called 35 ton Huskee splitter has a 5 inch cylinder .I've used one exactly like that and it's not fast .It does have some power but typicaly like most things marketed under that name the tonnage rating is exagerated just a wee bit .
I have a home built with a 5 inch and I'd put it at around 22-25 tons or about the same as Timber Wolf rates theirs .Mind you that's more than enough grunt .
Now I can't remember the praticulars on that Huskee but it should have a set of bleeders on the cylinder to allow the air to be vented .If that cylinder has a tendency to "spring " forward radidly I would suspect trapped air .
Busy Beaver Lumber
Swamp
You are correct about us splitting a ton of wood. We go through somewhere around 150 to 200 cords a year.
Frozen wood that pops off the splitter with a vengance is certainly not the norm, but it does happen enough that I am mindfull of the possibility that it can, and has occured. Logs with large knots are also something to watch out for, as I have had some knots shatter from the force of the splitter and throw pieces of the knots in various directions. When you split enough wood, sooner or later, some piece is going to behave in a manor you don't expect and suprise the daylights out of you. Of the tens of thousands of pieces I have split in my life, I would agree with you that 99.9% of them simply split as expected and fall to the ground, but the 0.1% that don't will definately pucker your butt.
I have split a log that was solid at both ends, only to find out it had a bee hive with about 50 unhappy bees still alive and very ticked off. After the bees cleared, it took some real looking to find their enterance in and out as it was behind a flap of bark. Another 20 inch diameter log had a metal electric box fully encased in the log.
There is no air in my hydraulic lines and the cylinder is not lunging foward.
So far as Al_Smith's comment that it is not a fast splitter, it has a 15 second cycle time, and that is if you let it go all the way back and all the way foward. For me that is fast enough. If I were looking to get a faster cycle time and increased output, I would buy a firewood processor. For a price of $1600 bucks, it is a pretty darn good splitter with all the power I have ever needed to split any log I presented to it.
6 x 10 dump trailer
Jet Bandsaw
John Mc
Quote from: Busy Beaver Lumber on August 17, 2011, 06:35:01 PM
It doesn't take much to start throwing logs, and the cylinder doesn't lunge forward very far (the one I had experience with was moving less than 1/2")
From what I've seen, if ti happens once, it usually happens several times, until the air bubble works its way out. So if yu are not seeing it all that often, then you may well be right... it may be something other than an air bubble. I've never had it happen when it was not an air bubble, but then I only split about 1/10 as much wood in a year as you do.
John Mc
lumberjake
I used to split about 350 to 400 cords a year with a comercial log splitter from iron and oak. The cycle time was around 8-10 seconds and was a faster than average splittler with a lift arm and a adjustable 4 way wedge.  I too had some frozen wood "pop" pretty crazy off the splitter, usually the smaller straight grain wood pops faster but some times when i got into some crotch pieces they exploded pretty fiercely. But as for splitting green or dry, i prefer green because now that we have a processor and we're around 800 cords a year, it's less mess at the machine. Green wood holds bark better than logs that have laid for a few months. We usually split the logs as soon as they get into our yard except the dead logs or logs with the bark pretty much off we stock pile. I would split it as fast as you can so it dries faster unless you have a kiln then it doesnt really matter.
LeeB
My favorite time is whenever I have enough extra cash on hand to get someone else to do it.  :D
Al_Smith
Now don't get me wrong I didn't say it was slow as a snail .It basically runs at the same speed as a standard 4 inch cylinder splitter .Of course with the larger cylinder and larger volume pump the speed remains the same and the tonnage is higher .
FWIW my homebuilt has a 5 inch cylinder 11 HP engine and 16 gpm pump .The engine is set for 2800 RPM the relief at 1800.It runs the same speed as my buddys so called 28 ton Huskie splitter with a 4 inch and 8HP engine running at 3600 .Splits more uses less fuel and at the end of the day you could fry an egg on my buddys cylinder while mine is just warm to the touch .
Randy88
Whenever the kids get on my nerves and I send them out to split some wood, today I ran the skid steer and splitter some to get what was piled up out of my way that and it was raining out and I didn't want to do anything else so I ran the skid steer in the rain all afternoon splitting wood while sitting in the cab, otherwise its whenever we have time to do it, no matter the weather.
hisliptree3
i recently fell an oak tree. i split it and hauled it right away. i also covered it for quick use, when im ready for it.
doctorb
Don't cover it completely.  It holds the moisture in and delays drying.  Let air get to it.
mkjones32
I have one of the 22 Ton Speeco's and am very happy with it.  Another word of caution if your a taller person some of the smaller logs can split apart with force and you could take a shot in the privates  >:(  Time for a break after that.
Al_Smith
Well geeze you have to get out of the line of fire unless you want to sing soprano .I prefer bass myself .I sing  solo,so low people can't hear me . ;D
CRThomas
Quote from: Ianab on August 10, 2011, 01:23:44 AM
Some species split much easier when green, others seem to split easier when dry.
If it's easy to split when green, then do it then, and the smaller pieces will dry faster.
I split and bag as soon as I can. But I am always behind but all my wood is in chucks 16 inch long so it drys good in one hot dry summer. Ash will beat you to death when it's dry. My grand daughter won't split ash she said hurt her. But I work with my wood 24 7's because that's all I do. I have about 3 years supply. With out gathering any more but I will. I have three storage places. The good wood at home and the other places the oak walnut pecan. My fruit woods were I can keep and eye on it. The stealing should start any day now. Dave said they already got a couple truck loads will he was a way on the week hot wire his loader. That something we live with in this area. CRT
King of the woods
I have found red oak splits quite well in fall or winter.Since oak tends to hold it's moisture for a long time it really splits easy when it is frozen! I dropped a 60 ft oak over a year ago and just began to buck it, it is so full of moisture it is difficult to get the rounds out of the woods by hand!
garret
Time to split is when there's nothing better to do or when wife giving me an earful.  Can't hear her over the log splitter engine.
IMO, when hand splitting, green woods split easiest.  This is certainly the case for ash, red oak, locust, maple.  Sycamore has my vote for toughest.  Grain like plywood.  Best to just let it lay.
E-Classic 2400 comfortably heating 4,200 sq.ft. and unlimited DHW, Off-grid, Photovoltaic-powered pumps in gloomy SW PA , 34 t splitter, numerous Husky chainsaws
I would prefer to have a pile of am. elm to burn over all others. It burns like coal but its an SOB to split the large chunks. Large chunks you cut cookies. I haul when I can get wood, and split when I can. Any hyd. splitter will launch an occasional piece just don't get down range. If you heat with wood you deserve a decent splitter, the savings in oil will pay for it quickly, same with a good saw.  Frank C.
36 coupe
Splitting wood does not help drying.....Wood drys from the ends.
QuoteSplitting wood does not help drying.....Wood drys from the ends.
Somewhat close to right.
Wood does dry from the ends, but it also dries from the surface (just more slowly than from the ends). The drying is slower from the surface if the bark is on, vs. a split face without bark.
So splitting has to help drying, as there is more surface area exposed to the air for any given block of wood split vs. unsplit.
timberlinetree
Best time to split wood is when the kids are around to help :D
I've met Vets who have lived but still lost their lives... Thank a Vet
Family man and loving it :)
Woodcutter_Mo
I had some really hard splitting black jack a while back I decided to try later, the other day was in the single digit temps and pretty much 1 whack with the maul and it just blew apart. Really frozen wood splits best a lot of times.
-WoodMizer LT25
-592XP full wrap, 372XP, 550XP, 455 Rancher, RedMax GZ3500T
-Fixer-uppers/projects:
024AV, MS260, MS361, MS460, Shindaiwa 488, 394XPG
