Author Topic: English walnut trees        (Read 2328 times)
Offline Left_Coast_Rich
  • Lumber hugger from Ca.
« on: January 16, 2004, 02:13:41 PM »
I have access to a walnut orchard that is being taken out by its owner.  some of these trees are about 20" dbh. and have sound wood  My question is the wood of these english walnut trees any good for lumberother than  bowl turning.
I know more today than yesterday less than tomorrow.
Online beenthere
Re: English walnut trees
« Reply #1 on: January 16, 2004, 02:54:56 PM »
Could you post some pictures of the logs? Have you seen any of the wood from the logs when opened up? Or a cross-section of a log that has a fresh cut?  Any use for, or market for, wood in your area that you are familiar with?  Do you have to take all the trees available or can you just take what you want? Any firewood markets available to you? Any pictures of the bowls turned from this wood?
Offline Buzz-sawyer
  • To see it is to saw it....
« Reply #2 on: January 16, 2004, 03:47:55 PM »
Rich your in the money Bro! You have got a real gold mine if you are getting these cheap or free...there is a real demand for this for everything from high end furniture to gun stocks congrats.....Take a look at this !!!
http://www.sarasotarockers.com/TheStoryofanEnglishWalnutC/23.html
    HEAR THAT BLADE SING!
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #3 on: January 16, 2004, 04:11:09 PM »
 :o
Look at page 22  of the February 2004 issue of Fine Woodworking.  One BIG English Walnut, over 6000 BD foot, some selling for $100 BD foot.
Dining room set made fron the tree valued over $40,000.
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40 Super- Wide HDG38
Lucas Dedicated 60" Slabber
Offline SawInIt CA
  • I need to eat sawdust
    • Logs to Lumber
« Reply #4 on: January 21, 2004, 09:41:45 AM »
Rich they need to be close to 36" to make gunstocks of get fiddle back. The smaller ones do make great lumber though.
The other left coast walnut sawyer
Online beenthere
« Reply #5 on: January 21, 2004, 12:35:19 PM »
Are you meaning 36" in diameter?  or length of bolt?  Or does fiddleback not occur in these english walnut bolts until the growth reaches 36" diameter? Can you fill us in a bit as it sounds from your handle you may have the answers. :)
Rich's logs were 20" dbh but seems sawing out gunstock blanks might work, if avoiding the pith center. Keeping the blanks stable after inletting to a gun action and barrel might be a trick.
Offline D._Frederick
« Reply #6 on: January 21, 2004, 03:50:53 PM »
Rich,
I see that you are from california, so I suppose that the walnut trees you have are not to different from what we have. The english walnut that we have is a very white colored wood that has about the same hardness as local pine. It sure is not like walnut that is grown in eastern US. It is not a wood that I would use to make furniture out of. The biggest tree that I have cut are no larger than 18-20inches, so maybe the large trees you have have different gain pattern.
PTO circle mill  Good or Bad  ?
Started by WV_hillbilly on Sawmills and Milling
Last post January 08, 2005, 11:43:56 AM
by Buzz-sawyer
question
Nyle  -  -  Powered Vents or Not ???
Started by DR_Buck on Drying and Processing
Last post February 21, 2005, 01:27:34 PM
by Mike_Doolittle
Wood-Mizer  4 deg  blades  ?
Started by Ohio_Bill on Sawmills and Milling
Last post January 11, 2003, 07:56:47 PM
by Bro. Noble
???Tanaka  2 stroke oil
Started by Flapjack on Chainsaws
Last post April 01, 2004, 10:32:35 PM
by Duane_Moore
