Author Topic: log wizard de-barking tool  (Read 2884 times)
Offline T.J.
« on: September 17, 2011, 08:52:53 PM »
i'm not shure if i need to put this here or on the chainsaw board,but here goes :
i searched this topic and 2 posts came up one from 2002 and one from 2003.what are y'alls thoughts on them?i know most of y'all either use a pressure washer or have one on your mill but,what do you do if you are some where you cant hook up your pressure washer? would the log wizard not be a handy tool?
also would the Stihl MS170 do alright with one attached to it?
any advice will be appreciated.
thanks,
T.J.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: log wizard de-barking tool
« Reply #1 on: September 17, 2011, 09:10:22 PM »
When I first started sawing we had a couple of Wizards. We ran them on Husky 55s. They work well, but take a little time. I would only open up enough for a slab and a board or two down one side. I don't know how big a 170, but the 55s ran it with ease. Sometimes after I got a log opened up I could take a bark spud and loosen up the remaining bark in big pieces. It really saves the bands if the logs are dirty.
Offline T.J.
« Reply #2 on: September 17, 2011, 10:16:50 PM »
Dave,
thanks for the reply.i appreciate it.
on the Stihl site it says the following about the 170 :
occasional use saw
30.1cc 1.8 cu in
1.7 bhp
8.6 lbs
i think they cost around $200
does anyone know what size the saw needs to be for the log wizard?
thanks,
T.J.
Offline zopi
« Reply #3 on: September 17, 2011, 10:20:20 PM »
One seventy is a little light...200 might be better...
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
Offline Brad_S.
« Reply #4 on: September 18, 2011, 12:22:55 AM »
I bought one to try and remove some frozen mud from a customers logs. It was totally worthless for that so I sold it very shortly after. Frozen mud is an extreme material to try and remove, but I can't imagine it would do much better on dry mud either. If all you want to do is remove clean bark, it may be a useful tool but as a log cleaner, it isn't very effective, IMO.
Offline bandmiller2
« Reply #5 on: September 18, 2011, 06:46:20 AM »
TJ,I think the wizard is aimed more at rough furnature and post and beam builders than sawyers.What would dull the band would dull the small plainer blades on the wizard.Unless you have a mounted debarker its wire brush ,spud,or axe.An axe sharpened one way, like some hatchets, is quite effective at muddy bark removal.  Frank C.
Offline VT-Woodchuck
« Reply #6 on: September 18, 2011, 07:39:16 AM »
I use mine on a Husky 136. Seems to work for me. It creates a lot of dust and you should wear long pants. It has done what I have asked of it. I do sharpen the blades every once in a while. I did buy a drive chain for it - no cutters.
    • My homepage
« Reply #7 on: September 18, 2011, 08:32:55 AM »
If you set the blades out a little bit more, it will reduce the entire log to shavings. I didn't want to suggest that, as it takes more power, and is more abusive to the drive chain. It will take off frozen mud this way, and anything else in the way. It does really throw the stuff, so I always tried to have my chainsaw chaps on when using it.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #8 on: September 19, 2011, 09:05:04 AM »
I used a Log Wizzard on a Poulan chain saw quite a few years ago and it seems to me that it does a good job for what it was intended.
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline isawlogs
  • A smile is contagious ... Start an epidemic
« Reply #9 on: September 19, 2011, 09:29:49 AM »
 I have one here and have had it since 93 when I bought my mill. I have used you it in all or about all situations, it does take frozen mud off a log, one needs to pull the cutters out a tad bit, enough for them to bite. Only bark it will not clean up is that of cedar, it being stringy and will wrap itself around the barrel of the wizzard.
 As for that 170, it aint big enough or have the torque and speed to reve up for the wizzard to be effecient, I have mine on an 034 , it was on a 026 but as I said , it needs the rpm and torque to be effecient. The knives dull fast but are easy enough to change to resharpen I used a hand grinder, no need to have them cutting or balanced as a planer, they're going to get messed up quick anyways.
 I put one on a Poulan and cleaned up some  logs that where sawed 8" thick with bark left on two sides that where to be used on a dovetail house,. I killed the saw before the job was over, it was way over worked for what it was doing. Those Poulans are good little saws, like the 170, just not cut out to do that type of work.
    ( That Poulan was a new saw, I did not bring it back as I new I had abused it over and above what it was built for)
  The weight of the Wizzard on the end of the 170 would also be above what the antivibe could take. Even on the bigger saws I have shortened the blade on it.
   Marcel
Offline reride82
« Reply #10 on: September 19, 2011, 02:06:58 PM »
What type of trees will you be using it on? I've used one on Lodgepole Pine and it works great, but on Ponderosa Pine where the bark is thicker a bar or hatchet as described earlier works faster. Although I've found that the log wizard works better around knots and uneven areas. I use mine on a husky 455 and I added a handle where the wizard bolts to the bar plus a few guards around the drive chain. This makes it so I have better control of the head and can manage the torque of the saw with more precision.
'Do it once, do it right'
'First we shape our buildings, then our buildings shape us'
Living life on the Continental Divide in Montana
Offline T.J.
« Reply #11 on: September 19, 2011, 10:43:25 PM »
thanks to everyone for all the help & advice.i really appreciate it.
i guess the MS170 is out then. do y'all think a Husky 353 would be alright to use with it?
i have a variety of trees to mill - SYP,yellow poplar,soft maple,red & white oak,ERC (glad isawlogs warned me on that one).
again thanks for the help.
T.J.
Timber Tuff TMW-58 Log Peeler VS Log Wizard Debarking Tool, Model# LogW-4000
Started by redmcc on Timber Framing/Log construction
Last post February 15, 2020, 07:36:30 PM
by Edvantage
De-Barking plank
Started by Upper on General Woodworking
Last post December 05, 2015, 10:47:14 PM
by Upper
Talk about barking mad!
Started by Satamax on Sawmills and Milling
Last post July 29, 2012, 02:39:08 PM
by Satamax
De-barking eastern red cedar help???
Started by Logger615 on Timber Framing/Log construction
Last post January 22, 2015, 09:07:57 AM
by Logger615
