Author Topic: hydraulic hose  (Read 937 times)
Offline bedway
hydraulic hose
« on: September 23, 2011, 10:32:30 AM »
My Kubota B7200 needs hoses replaced. Having virtually no experience in this area could someone explain to me the differences between one and multiple braiding in the hose. Bottom line, im trying to determine which i need.
Offline BrothersMule
    • John Woodie Enterprises, Inc
Re: hydraulic hose
« Reply #1 on: September 23, 2011, 11:12:41 AM »
You can get Hydraulic hoses in 1,2,4,6, and 8 wire. I assume this what you are referring to when you say braiding. The more wire it has the higher the PSI rating. If you look at the end of the hose with no fitting you can sometimes count the layers of wire. Most any hydraulic shop that makes hoses should be able to identify the hose if you can take it with you. This will also help them to match the fittings. 2 and 4 wire are the most common with 6 and 8 being rare. I believe 2 wire is usually 3,000 or 3,500 PSI but don't hold me to it. If i had to guess with out seeing it you probably have 2 wire. I would have a hydraulic shop verify if you are unsure. Also some machines do have more then one size on them so if you have multiple don't assume they are the same. You may be able to call a Kubota dealer and tell them what you have and they may be able to tell you what you need. Hope this helps.
Offline pineywoods
Re: hydraulic hose
« Reply #2 on: September 23, 2011, 11:15:36 AM »
By all means take the old hose with you. The fittings will likely be metric.
Offline maple flats
  • Life is what you make it!
Re: hydraulic hose
« Reply #3 on: September 25, 2011, 12:20:07 PM »
Do you have the owner's manual? It may give the PSI of the pump. Be sure to get hose rated at least that high. If no manual you will need info from a dealer. But then you will likely do better buying elsewhere. Dealers are generally too proud of their parts and hoses are an area where you can stray. Does the hose have a pressure printed on it, either PSI or I think metric is Kbar or something like that.
Hydraulic hose
Started by Bruno of NH on Sawmills and Milling
Last post August 10, 2018, 10:18:17 PM
by mike_belben
Hydraulic hose's.
Started by BargeMonkey on Forestry and Logging
Last post January 25, 2016, 02:31:26 PM
by xalexjx
Hydraulic hose replacement
Started by Magicman on Sawmills and Milling
Last post October 07, 2012, 02:41:47 AM
by Woodchuck53
Ruptured hydraulic hose.
Last post August 12, 2009, 09:27:26 PM
by Magicman
