Author Topic: board and batten siding  (Read 10555 times)
Offline tat
« on: January 20, 2004, 09:36:35 AM »
Which would last longer when used as b&b siding, water oak or pine. Plan on leaving a natural color and spraying with a sealant. These 2 are really my only choices because this is the type of trees that I have. Finally building enough confidence at sawing to start with something other than my trash trees.
Tom Till
Offline DanG
Re: board and batten siding
« Reply #1 on: January 20, 2004, 11:24:19 AM »
I'd say go with the pine. My barn is over 60 years old, sided with pine lap siding, and never had a drop of paint or sealer on it. I have a pile of slabs and strips that has been laying out for about 2 years, some of is pine and some water oak. The oak is rotten and the pine that isn't touching the ground is still solid.
Offline slowzuki
  • Still learnin'
    • On the Farm
« Reply #2 on: January 20, 2004, 11:47:42 AM »
If it is in a dry ie sunny and breezy area, both should last a long time.  If it is long pieces, the pine would be lighter to install!
Offline shopteacher
  • Hiking Sedona, AZ.
« Reply #3 on: January 20, 2004, 01:21:43 PM »
I'm in the process of covering my barn with B&B.  It's mostly soft maple and I plan to paint it.  I was going to us a sealer, but haven't seen any that really hold up. The sitka seems to be the best on the market, but if you use the 3 coat product it'll cost you an arm and a leg. I'd have to buy it by the barrel to cover all the siding I have. Anyway what I started to say is I put a piece of galvanized angle(heavy sheet metal) from steel building at the bottom and raised the siding about 1/4" off it.  I'm going to run a bead of 100% silicon between the angle and the bottom of the siding.  I have also been treating the first few inches with cupinol or lumber last and trying to coat the end real good.
Offline Ron Wenrich
« Reply #4 on: January 20, 2004, 02:46:01 PM »
My house is over 150 yrs old, and they used white pine board and batten.  As long as you keep them off of the ground, they should last.
What type of pine are you using?  The design on my place used boards 10"+.  The battens are 2 1/2" wide and 3/4" thick.  Gives a nice look.
Offline tat
« Reply #5 on: January 20, 2004, 03:55:04 PM »
The pine is southern yellow pine and is probably an average of 20" to 30" dbh. The oak is smaller on average but there is a lot of it. Plan on using a lot of that for flooring.
Tom Till
Offline mitch
  • May your saws run true.
    • Shag bark farms
« Reply #6 on: January 20, 2004, 05:28:00 PM »
I use rough sawn board and batten (depot style) on all of my buildings. Usually 10"-12" boards and 2 3/4 inch batten from Southern short leaf pine.
http://shagbarkfarms.com/Photos/Shagbark-Pan.JPG
Mitch
Offline RMay
« Reply #7 on: January 20, 2004, 06:46:40 PM »
I cut all my bat & board siding out of southern pine , the boards is 10 and 12 in. by 1 in. the bats is 3 in. by 5/8 in.  ::)   I got the sizes from a old Church that is over 125 years old and the b&b siding is like new but the nails is rusting into  8)
RMay in Okolona Arkansas  Sawing since 2001 with a 2012 Wood-Miser LT40HDSD35-RA  with Command Control and Accuset .
Offline isawlogs
  • A smile is contagious ... Start an epidemic
« Reply #8 on: January 20, 2004, 06:54:17 PM »
I'd go with the pine . barn at dads is over 150 years old and the gable ends are pine and we only changed a few no sealer or paint was ever on them .
   Marcel
Offline slowzuki
  • Still learnin'
    • On the Farm
« Reply #9 on: January 20, 2004, 07:08:51 PM »
GOOD GOD MAN DON'T PAINT IT! :D
1. The wood doesn't need it
2. Can cause rot problems if the wood can get wet from behind or the bottom
3. Most important, ya gotta scrape and repaint the DanG thing every so often which is terrible work!
Offline Bro. Noble
« Reply #10 on: January 20, 2004, 07:46:27 PM »
There is an old house on our place with B&B SYP siding.  It's never been painted or coated with anything.  The places in the boards that have a lot of pitch and that are protected by the overhang still have some yellow color.  It looks good to me.
Offline Ron Wenrich
« Reply #11 on: January 22, 2004, 03:18:35 PM »
Here's a shot of my farmhouse.  It was when I was working on that part a couple of years ago.  I used 10" and wider boards.  They are random widths.
As you can see, my house is a 2 story house.  I have replaced the original pine with newer pine.  The old stuff was starting to crack pretty much.  Not bad for 150 year old wood.  The house was built probably in the 1850s.  It is the Gothic style, which was prevalent around that time.
There is additional trim around the windows.  It used a 3 1/2" piece of trim and a gingerbread style under the windows.  It helps set it off.  May not be correct style for the southern states.   :D
The house is post and beam.  The only place there are posts are on the corners and where there are windows and doors.  Heavy wind braces on all the corners.  The posts are only 4 x 4.
I made a bevel cut for the boards that were shorter than the run, so water wouldn't hang in.  I also caulked with a 50 yr caulk behind the battens.  Helps cut out the wind.
Offline tat
« Reply #12 on: January 22, 2004, 04:09:19 PM »
Thanks for all the replies. I guess ya'll made my mind up for me. Pine it will be. Thanks again for the input,pictures and links.
Tom Till
Offline UNCLEBUCK
  • Life out on the prairie !
« Reply #13 on: January 22, 2004, 07:48:18 PM »
nice house Ron, here is my first attempt at b&b siding last spring trying to cover up the saw shack with some free spruce logs I sawed. They went through the sawblade and right onto the wall dripping green and I used sheetrock screws and screwed each side then screwed the battens on and in about 3 months every board has a few long cracks up and down , after finishing it all then I read the book on how to do it ,  :D  especially 16 or 18 inch wide boards, but at the time I didnt care because I was having fun and just wanted to close off the strong northwest winds  :D  maybe someone can share their experience putting on green stuff .good luck tat !
Offline UNCLEBUCK
« Reply #14 on: January 22, 2004, 08:15:38 PM »
 hey Mitch , what kind of stain did you put on your b&b and did you let the boards dry for awhile before you fastened them on . also did you just fasten one side of each board and then fasten the batten through the middle, and and and did you fasten the b&b directly to the stud framework . I like looking at that picture and just recently in my Gurneys seed catalog I seen shagbark hickory trees, I never knew how you got the name shagbark, now I do. a shagbark tree ! what kind of trees are in that picture?  sorry for all the questions but its a great picture of your house and it all came from your sawmill, very cool !
Offline IndyIan
  • Weekend Woodsman.
« Reply #15 on: January 23, 2004, 06:51:38 AM »
What's the narrowest boards people would recommend for the boards?  I'm going to be building a garage this summer 28'x32' and I'd like to use our white cedar.  Problem is that most of the cedar is around 9", some 12" on the small end of a 10' log.
Would random widths 5 to 9" look silly?  I've looked around here and most peope use equal width, 8 to 12" boards.  Bigger buildings using wider boards.
Is my sawyer going to go insane flipping logs and edging all these little boards?  He's got an WM L17 I believe, manual.
Thanks,
Offline Ron Wenrich
« Reply #16 on: January 23, 2004, 08:40:25 AM »
The biggest problem is going to be the reveal left after you put up your batten.  If you are using 2 1'2" battens, a 5" board is only going to have a 2 1/2" reveal.  It doesn't look good to my eye.
The same goes with too small of a batten.  I've seen some 2" battens, and they just don't look good.
Boards all the same width look too manufactured, something like T-111.  Its also a lot easier to cover up flaws with random widths.
I've used some that are narrower than 10".  The smallest is about 8".  I wouldn't go any smaller than that.
To get the widest board, just skim one side of the log, turn 180 and skim the other side.  Then lay on the side and live saw.  The boards in the middle will be the widest.  The stuff on the outside with little width can be made into battens.  More edging, but wider boards.
« Reply #17 on: January 23, 2004, 11:15:06 AM »
I mostly cut 3" bats to go on 8" or larger boards for my customers.  I also cut the bats thinner than the boards.  If I know the boards are going for a wall then cut it 7/8".  I cut the bats 5/8" so they don't stick out from the wall so far.  The only reason for cutting the wall boards a shy 1 inch is to take weight off of the wall but leave enough thickness for weathering and strength against penetration.
I love board and batten construction mostly because it can be repaired with any width of board or boards that will fill the hole. If you use only one size for uniformity, you lose that ability without changing the look.  I agree with Ron. Use any size that happens to get in your hand.  Patterns are neat but not necessary.
Horizontal siding  must all be the same width.  At least each run must be the same width.  When you need to replace a board, you have to put one back just like the one you took down.  That's ok if you can buy the board but not if you can't.  There's been a lot of folks around here that were stymied when they couldn't get the right width of novelty siding(clapboard) for their house.
If you're a mind, you can put up board on board.  I don't like so much because it's more difficult and I don't think as sturdy.   It's when you separate the bottom boards by a distance of about 2 inches less than the width of the board that will cover the gap.  Then you nail a board across the gap which could be called a batten.  It can't be as weather proof since the bottom boards aren't butted up against one another but it saves you from having to cut battens. :)
Oh!  All our walls are usually Southern Yellow Pine or Cypress.  That's probably because that is the most that we have.   I don't know of anybody who builds with hardwood down here except chicken farmers. They'll use anything. :D
Our hardwoods go for interior paneling and cabinets.
Offline shopteacher
« Reply #18 on: January 23, 2004, 01:25:11 PM »
Hey Tom,
  I hope you ain't insinuating that old Butch and I are chicken farmers.  >:( Why we don't even have a chicken on the place.  Now we do have a few fine, pedigree yard pimps strutting around but they ain't no chicken. :D
   I find that I get about as much soft maple as I do pine.  Those little silver leaf maple that grow so easy are left by home owners till there about 36" in dia. and close to the house and the wind and rain start to drop 10" dia limbs or splits onto their roofs then it's get that tree out of here.  Have one right now to pickup 36" X 22'.  Hope to get it home over the weekend, if the weather will co-operate 8)
Offline IndyIan
  • Weekend Woodsman.
« Reply #19 on: January 23, 2004, 02:00:13 PM »
Thanks for the info guys, I'll have to look into Tom's board on board suggestion as well.  That might be the practical option.
Board and Batten siding
Started by Don P on Timber Framing/Log construction
Last post December 21, 2019, 08:59:57 AM
by Bruno of NH
Lap siding or board and batten???
Started by Deere80 on Sawmills and Milling
Last post June 01, 2017, 04:27:19 PM
by Deese
Board and batten siding green or dry?
Started by Rob in NC on Sawmills and Milling
Last post April 20, 2019, 08:54:39 AM
by Bearpau
Using Cottonwood For Board and Batten Siding
Started by calb on Sawmills and Milling
Last post January 01, 2017, 03:41:31 PM
by AlaskaLes
