New Home For My Wood-Mizer LT15
Started by WDH, September 29, 2011, 08:04:37 PM
POSTON WIDEHEAD
Wow Danny.....somebody's been busy.....REAL busy.
Did you run the power from the house? Underground?
This is a nice setup......I'm impressed!  smiley_thumbsup
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
Ga Mtn Man
Wow! You have been a busy boy.  Last time I was there it was nothin but grass.  Looks like a first-class setup.
Larry
WDH isn't giving the grass a chance to grow under his feet. ;D
Quote from: POSTONLT40HD on March 12, 2014, 02:02:21 PM
I bet he did it with a PowerBox. :D
In any case its a impressive and neat setup.
YellowHammer
You have really been busy.  That sure looks nice!!  First class for sure. Have you tried the cyclone yet?
YH
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Red Clay Hound
Nice setup Danny!  I don't know how you find the time to get all this done.  I work all the time but don't seem to get much accomplished! :-\
2007 Wood-Mizer LT40 Super Hydraulic with 51 hp. Cat; 2007 Wood-Mizer EG200 Twin Blade Edger; Woodmaster 718 Molder/Planer; Stihl MS460 and MS362 Chainsaws; 2011 John Deere 5065 with JD 553 Loader
Mooseherder
I know you have been busy Danny and that is really something to be proud of. :)
Thanks for all the kind words.  After seeing Red Oaks Lumber's set-up, I am a little embarrassed to post this  :-[.
David, I rented a trencher and ran 2-2-2-4 cable from the old house to a panel box in the planer room.  Renting that trencher was the best $125 that I have spent in a long time  :D.  Now I don't need a POWERBOX, but I still need a FAN.
Fish, it is a 20" planer.  It is a little beast.
YH, the cyclone set-up that we discussed is working very well.  The distribution of the planer shavings in the shavings box is really pretty good, but it is only about 1/4 full so far, so I have a ways to go yet to see how it will do as the box gets full.  I was lazy and did not put in any baffles yet, (too eager to plane wood) but it won't be long before the box is getting full and I can always go back in and add the baffles.  As background, there is a pretty short run of pipe, and the Penn State 2 HP blower is very powerful, so when I had the pipe just pointed into the middle of the shavings box, it just blew all the shavings out of the box :-\.  So, the box had to have a lid, and Robert, (Yellowhammer), and I discussed how to orient the inlet pipe in the top left side of the box with an exhaust port on the matching side but opposite on the top right on the lid of the box.  Therefore, the theory is that the shavings blow into the long axis on the top left side, and then the air swirls around in the box (the box has a lid), the heavier than air shavings drop out of the air stream, and the air exits out the exhaust port.  We talked about 45 degree baffles in the corners of the box to direct the air flow in a cyclone pattern, and that will surely help even more to get good shavings distribution in the box without blowing shavings all over creation.  Working according to plan so far.
The sides of the planer room were mostly green pine, so it is shrinking a bit, and I will need to come back in and add some battens over the cracks.  No problem with that, it will make it look even more old-timey (old saying).  However, I did kiln dry the lumber for the doors, then planed them and v-grooved them, so they will not need battens.  I love the blue from the bluestain from the beetle killed pine.
Yes, the doors are wide, but being able to fully open up both ends will make material handling (boards) much easier.  I ordered some heavy duty cart wheels so that I can make a lumber cart to move wood after one pass through the planer back to the front for the second pass thru the planer.  The goal is two-pass-skip-planing from 1 1/8" rough to 15/16" skip planed.  It is amazing how much it helps customers to see the beauty in the planed wood versus just looking a a rough sawn board.  Beauty sells  :).
This should last as long as I do.  After that, not sure that it really matters.
customsawyer
www.thecustomsawyer.com
47sawdust
Beautiful building.I know you have been busy and have not got around to it,but those doors will sag without a diagonal brace or an adjustable turnbuckle arrangement.I miss flat land.
Great job,
Mick
Mick
Peter Drouin
So you're going to skip plane all the wood for now on before it's for sale?
A&P saw Mill LLC.
Nomad
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Peter,
Yes, most of the hardwood when it come out of the kiln, but only the good grade.  The lower grade will not be kilned dried or planed, just air dried and sold rough sawn.  I do not plan to plane pine.  Not enough value in the wood.
Also, I want to cut more slabs, and the 20" planer will make it easier to dress them up nice.
POSTON WIDEHEAD
This should boost your slab sales up to a least $300.00. ;D
Yes, all I have to do is sell one of your slabs  :D.
hackberry jake
Too bad we arent neighbors. I would let you use that jointer all you wanted for some space in that kiln every once in a while...
Raider Bill
My advice on aging gracefully... ride fast bikes and date faster women, drink good tequila, practice your draw daily, be honest and fair in your dealings, but suffer not fools. Eat a hearty breakfast, and remember, ALL politicians are crooks.
CalebL
Quote from: hackberry jake on March 13, 2014, 09:01:12 AM
Jake, I'm getting everything together for my kiln now.
2005 LT40 HDD34
2000 Cat 226 Skid Loader
Peter Drouin
Quote from: WDH on March 13, 2014, 07:54:43 AM
Peter,
smiley_thumbsup
A&P saw Mill LLC.
hackberry jake
Quote from: CalebL on March 13, 2014, 12:17:08 PM
Sweet! And I even get the neighbor discount!  8)
red
It will look so nice with Sheetrock   ;D
I have swore off the two S's.  Sweetgum and Sheetrock  :-\.
OneWithWood
One With Wood
Dodgy Loner
Awesome. That room looks too clean though. Needs some clutter to make it feel homey. I have some clutter you can borrow, if you want ;D
