Author Topic: cleaning saw blades  (Read 966 times)
Offline mooleycow
cleaning saw blades
« on: November 22, 2011, 06:14:06 PM »
get metal tub, sink. large bucket.  put blades in.  fill with hot sink water and boil water also.  put in  powdered wash detergent.  let soak about 20 minutes.  raise the blade up with a stick and brush rosin off with tooth brush.  don't get caught in the kitchen sink with the wifes tooth brush!
Offline CHARLIE
  • Don't wait 'til both feet are in hot water before you decide to put your best foot forward.
    • Coulee Region Woodturners
Re: cleaning saw blades
« Reply #1 on: November 22, 2011, 06:19:51 PM »
Yeah, some wimmin would complain about anything.  :D
Charlie
Offline Cardius
« Reply #2 on: November 23, 2011, 09:54:08 PM »
I dont mess up the sink, just use up all the oven cleaner.
Offline DouginUtah
  • You can't always have a tailwind, sometimes it's going to be a headwind.
    • Doug Sherwin's Homepage
« Reply #3 on: November 23, 2011, 10:17:04 PM »
I've heard that you should not use oven cleaner on carbide-toothed blades.
-Doug
When you hang around with good people, good things happen. -Darrell Waltrip
There is no need to say 'unleaded regular gas'. It's all unleaded. Just say 'regular gas'. It's not the 70s anymore. (At least that's what my wife tells me.)
Offline caveman
  • In the land of the blind the one eyed man is king
« Reply #4 on: December 22, 2011, 08:06:03 PM »
For cleaning 93 1/2" band saw blades or a 10" table saw blade, I put them in the bottom of a five gallon bucket and soak over night in simple green  or a citrus based cleaner.  The blades wipe clean and the liquid cleaner is poured back into the storage container.  On larger bandsaw blades like those used on a 20" bandsaw, the blades are coiled and put into the bottom of a clean garbage can just as the smaller ones are put in a bucket.  There is very little waste.  I have used oven cleaner when in a hurry.  Caveman
Caveman
Offline D._Frederick
« Reply #5 on: December 25, 2011, 03:34:09 PM »
DouginUtah
I have a Freud combination blade that was dull that I decided was not worth the sharpening cost. I took a spray can type oven cleaner and sprayed it till covered, then wired brushed it off while rinsing with water. It took off all the printing on blade down to bare metal. It is 100% clean. It only took about a couple minutes per side, I can not see any visible  damage, but before using it would put it under a microscope. Should be able to see any etching I would think. I don't know if carbite is porous enough to absorb the lye and cause damage.
Cleaning saw blades
Started by D._Frederick on General Woodworking
Last post November 02, 2009, 05:43:08 PM
by johnjbc
Cleaning Blades
Started by Jacar on Sawmills and Milling
Last post February 23, 2003, 06:50:52 AM
by solidwoods
Cleaning blades
Started by Rambjor on Sawmills and Milling
Last post February 10, 2020, 10:17:46 AM
by DDW_OR
Cleaning Blades
Started by MrMoo on Sawmills and Milling
Last post November 05, 2003, 01:27:41 PM
by bull
