Author Topic: Huffing woodstove  (Read 11322 times)
Offline John Mc
Re: Huffing woodstove
« Reply #40 on: December 07, 2011, 10:34:13 AM »
Seems odd that they would say their Defiant model woodstove (rated at 75,000 BTU)  is for ambiance, not heating.
Offline Handy Andy
  • Location: right on the edge of the great american desert
  • I'm not new anymore
« Reply #41 on: December 25, 2011, 08:28:32 PM »
  John Mc, it's because it doesn't work right.  They are trying to avoid a class action lawsuit.  The company that bought out VC, probably thinks they bought only the assets, not the liabilities, so are trying to avoid any more sales to folks who want to heat with the non catalytic version.  Seems to me it would be simpler to redesign the smoke burner and make it available to people with problem stoves.  Jim
My name's Jim, I like wood.
Offline Ironwood
    • http://www.branchandburl.com
« Reply #42 on: December 25, 2011, 08:45:06 PM »
I have a 15-18 year old Defiance VC dual stove, run it without cat to start and engage it AFTER a large bed of coals is established, NEVER  EVER had to service the converter EVER. Love it, load it up, give it tiime to burn the new full load a bit then reengage the cat. Burns all night. It holds ALOT of wood. Also, to get her going dont be afaid to open the ash door a LITTLE but be careful she'll get raging quickly (dont leave it unattended that way). Our chimney is internally lined ( heavy flexible stainless, ost as much as the stove) old house chimney, so heats well, quickly and stays hot, yours may differ.  Heat the whole house as it is in the middle and on the first floor and it gravity feeds (convects) heat to the upstairs well.
Ironwood
Online beenthere
« Reply #43 on: December 25, 2011, 10:30:25 PM »
Same as Ironwood. Have used the Defiant VC for 10 years now and haven't ever had a problem with it. I will confess to having to clean off the fly ash from the top of the cat. conv.
I don't think this is a stove problem, but another example of having to learn what works and what doesn't work.  Hopefully can figure it out so the stove can be enjoyed.
Offline tyb525
  • Always learning.
« Reply #44 on: December 25, 2011, 11:47:44 PM »
Have a Dutchwest "Federal Airtight", dual mode stove. I can fill it as full of wood as I possibly can and it burns fine. Don't engage the cat til the stove is 500+ and has a good draft (doesn't work so well on a no-wind day). We do have a damper, but we never touch it, just regulate the fire by the ash box door and side load door vents. Using a damper can cause more creosote when your draft isn't the greatest.
Online beenthere
« Reply #45 on: December 26, 2011, 02:42:21 AM »
I'd be easily convinced that the "for ambiance" pitch is more to dodge the EPA bullets aimed at them. They would have to run the full gamut of tests to establish heat output as well as the emissions. These tests are very expensive and very tentative as to results. Likely (at least I would believe) that the company buying out VC simply can't recover these tests in sales income.  In the end, we the taxpayer and user end up with the bill, or see another USA business go under due to the overburden of regs. It is a sad outcome to an established business as well as new business adventures trying to get started.
Just my opinion.
Offline Ironwood
« Reply #46 on: December 26, 2011, 08:16:47 AM »
Also, you should be able to see the glow of the cat when it is operating properly, it is behind the woodbox up high behind the grate.
 Ironwood
Offline Handy Andy
« Reply #47 on: December 27, 2011, 10:20:02 PM »
  My non-catalytic version of the VC defiant does not have a catalytic converter.  It has a chamber that is supposed to burn the smoke. Problem is it is really touchy. I've been in contact with a tech from the company, he thinks I need a new part called the "fountain".  Says the stove sat in storage a couple of years, probably collected moisture in the"fountain".  It is made of a fiber material, think that is the problem.
Need a new woodstove
Started by Handy Andy on General Board
Last post July 09, 2008, 10:38:15 AM
by beenthere
woodstove ???
Started by Mr Mom on General Board
Last post September 02, 2009, 12:03:14 PM
by Mr Mom
crack in woodstove
Started by robmelby on Firewood and Wood Heating
Last post October 09, 2016, 10:38:40 AM
by Ox
Woodstove Brainpicking
Started by tcsmpsi on General Board
Last post February 01, 2009, 01:25:39 PM
by cheyenne
