Author Topic: How to measure a log  (Read 3421 times)
Offline buzz
« on: January 31, 2004, 11:54:24 AM »
Hello all ,    would like to know how measure a log , searched archives had no luck , thanks in advance
Offline beenthere
Re: How to measure a log
« Reply #1 on: January 31, 2004, 12:37:34 PM »
Unless I am missing the point, try the calculators to the left of these messages. Go into log volume, and enter the diam. sm. end, and the length. Get three measures of board footage estimated in your log.
Or is it more in depth than that QA?
Offline Ron Scott
  • Forester
« Reply #2 on: January 31, 2004, 12:49:31 PM »
Use the calculator at the tool box to the left. Decide what log scale you want to use, Doyle, Scribner, Scribner Decimal C, or International 1/4.
Measure the log's length and diameter "inside bark" at the small end for gross scale. Deduct for any cull, defects, sweep etc for net scale.
The Forum Calculator does the work for you or use one of the appropriate scale sticks which may have the calculations on it.
~Ron
Offline Ron Wenrich
  • Forester
« Reply #3 on: February 01, 2004, 04:27:05 AM »
The only thing I would add is that sometimes your log isn't perfectly round.  You can either measure the wide way and the narrow way and average the two, or you can measure across the diagonal.  That will give you a pretty good diameter measurement.
Offline buzz
« Reply #4 on: February 01, 2004, 02:53:48 PM »
I think what i meant to say was what is the formula ,length x width x ?  should have been more specific , thanks
Offline beenthere
« Reply #5 on: February 01, 2004, 04:09:18 PM »
There are many different log rules - some with formulas and some where the boards were just drawn in the 'log' on paper to figure out the volume in board feet. If you want to know a lot about the different rules, there is a pretty good publication "A Collection of Log Rules" by Frank Freese
http://www.fpl.fs.fed.us/documnts/FPLGTR/fplgtr01.pdf
that would be good to read. Otherwise, could you be more specific about what it is you want beyond using the calculators on this site, where the scaling diameter and log length are provided, and the log volume in board feet from three 'log rules' are given. Apparently that calulator isn't meeting your needs.
Offline SwampDonkey
  • Forester
  • Large Tooth
« Reply #6 on: February 04, 2004, 07:56:10 PM »
@ Buzz
newton's formula for cubic feet
V=h (Ab + 4Am + Au)
        6
h = height
Ab = cross sectional area at base
Am = cross sectional area at middle
Au = cross sectional area at top
or for board footage
Doyle Rule for 16 foot logs
V=(D-4)2
D= diameter inside the bark
International Log Rule for 16 foot logs (more accurate)
V=0.88D2 - 1.52D - 1.36
Taken from  Forest Mensuration, Husch, Miller and Beers
Individual tree volumes are site and species specific.In New Brunswick we use standard volume tables based on site index. These can be localized by measuring just tree dbh on your site and using regression to plot the resulting curve for a range of DBH.
Move'n on.
How to Measure
Started by summerjob on Sawmills and Milling
Last post September 22, 2005, 10:41:42 PM
by pigman
Measure set
Started by bandmiller2 on Sawmills and Milling
Last post August 22, 2011, 08:18:13 AM
by paul case
Wood measure
Started by Logger003 on Ask The Forester
Last post June 21, 2015, 12:36:58 AM
by Logger003
now how's that unit of measure?
Started by IMERC on Sawmills and Milling
Last post July 25, 2006, 08:22:40 AM
by IMERC
