Author Topic: New Tanaka won't stay running  (Read 1438 times)
Offline aquacanis
  • Too young to worry, too old to care
« on: December 05, 2011, 08:55:07 AM »
My new 32 cc Tanaka starts well cold.  If you shut it off and restart it immediately it will start again.  If you run it for half a tank then shut it off and leave it for 10 minutes, it won't start period.  I got spark and fuel and it still won't start.  Getting real frustrated.  If I refuel it while it is idling it will continue to run. A bad
thing to do.  If it runs out of gas and you refill it, it is also done for the day.   Won't restart.
Any suggestions?
Offline Kevin
Re: New Tanaka won't stay running
« Reply #1 on: December 05, 2011, 09:17:34 AM »
If it has fuel and spark and won't start I would try different starting options like applying the brake and holding the trigger.
Maybe it's flooding, usually they need a prime after ten minutes but no choke.
Could be choke for one pull then off.
Offline aquacanis
« Reply #2 on: December 05, 2011, 11:53:33 AM »
Thanks for the reply Kevin,  I will try this tomorrow and let you know if it works.
Offline isawlogs
  • A smile is contagious ... Start an epidemic
« Reply #3 on: December 05, 2011, 12:28:32 PM »
 I think that your motor needs a valve adjustment. When hot they don't open enough.  :P
   Marcel
Offline aquacanis
« Reply #4 on: December 05, 2011, 02:36:19 PM »
Thanks isawlogs,  Never adjusted a valve on this kind of two cycle.  Do they shim them?  I assume they are a reed valve.  Can you tell me how to accomplish this?
Or check it at least?
Offline isawlogs
« Reply #5 on: December 05, 2011, 08:07:21 PM »
For some reason I thought it was a four stroke, sorry,  :-\  in your case it could be a timing issue. Coil to fly wheel distance could be off a little, might want to check what the distance should be on that engin. Once the engin warms up the gap is too small to fire properly , once it cools it fires up.
   Marcel
Offline lumberjack48
  • 36 yrs ago, cutting Ash saw logs
« Reply #6 on: December 05, 2011, 08:42:31 PM »
 Turn the low jet about 1/4 turn counter clockwise, after doing this you might have to turn your idle screw up a little. just a thought
Offline John Mc
« Reply #7 on: December 05, 2011, 09:54:03 PM »
Any chance the saw is vapor locked? You could check for this by letting the saw idle to cool down before shutting it off. If that makes a difference, there are some things you can do to help your saw run cooler and avoid this.
Offline thecfarm
« Reply #8 on: December 06, 2011, 06:25:45 AM »
You say new,how new? Can you return it?
Saw won't stay running
Started by JohnnyF on Chainsaws
Last post October 21, 2006, 08:36:24 PM
by PineNut
029 Super won't stay running
Started by demulsion on Chainsaws
Last post March 14, 2017, 12:44:51 PM
by dougand3
MS200T Won't stay running.......
Started by Bark Buster on Chainsaws
Last post February 18, 2006, 04:38:36 PM
by ehp
Husky 350 won't stay running
Started by DR_Buck on Chainsaws
Last post September 12, 2014, 01:20:40 AM
by JB Griffin
