my log arch with pics
Started by kevinlt15, December 09, 2011, 12:30:29 PM
kevinlt15
   well here I amlooking at all the homeade arches and thought I would try building one.I had the axels,tires an hubs some of the steel needed so it should be low cost.  well I got 75 bucks in to the added steel and 40 in to the other stuff.
since my arch was old boat trailer supports Ihad to notch around the tubing
you ever notice the only weld posted are nice ones :D ;D
well this is where it is  it needs A reciever hitch(where i am goin next) And A wench-lifting design. A ny one got any ideas ???
DeepWoods
Try starting here.
https://forestryforum.com/board/index.php/topic,49642.0.html
I built my arch last spring and have used it several times since it was completed.  I find it works well, and am very glad that I took my time with it and used information from this forum to gain ideas from other members.  If you have any questions  pm me.  Looks like you are off to a good start  8)
Norwood LM2000 with 23 HP Briggs and 21 foot track, Hand Built Logging Arch, Cooks Cat Claw Sharpener and Setter. 48" Xtreme Duty Logrite Cant Hook.
losttheplot
I mounted the winch on the vertical post above the wheel.
The cable goes under the log and gets hooked onto the other side of the arch.
This does away with the need for a block hanging down, and allows the log to be winched right up tight to the top of the arch.
The diagonal braces, from the arch to the backbone, hold the log in plaice.
The winch is closer when your working at getting the cable under the log.
If you put a bigger mounting plate on the post you can put the winch on the inside. There it is more protected.
However big you build it, its never big enough.
DON'T BELIEVE EVERYTHING YOU THINK !
kevinlt15
I like that idea of puting it there. now to figure out how to use the winch to lift one end of the log up and chain it,  then lift the other end and secure it.
Can you haul that arch down the road loaded Losttheplot?
Slingshot
  You just need you a big dog to jump up on the rear end for
a counterweight.  smiley_bounce
sling_shot
losttheplot
Quote from: kevinlt15 on December 09, 2011, 09:28:02 PM
After a couple of logs its pretty easy to guesstimate the balance point of the log.
If its butt heavy the front hits the back bone then the butt comes up off the ground.
If its front heavy I just put a bit of rope around it to keep it off the ground.
The winch behind the arch can make it light on the tongue. Next time I will put the hooks for the cable on the front of the arch, that way the center of gravity would be in the center of the arch.
Yes I can haul it down the road......but the dog gets a bit freaked out  :D
We are off the radar here so as long as no one gets hurt............ If that's what your asking
I hung a chain, from the extra hook points on the arch, then backed off the winch. But I dont bother anymore. I am going to put safety chains on the hitch though.
If you haven't already I recommend watching the log-rite  videos on their site.
JP135
Old Hilly
(quote)
"DOG-wood tree?
...sorry. Couldn't help myself."
Certainly is, you can tell from it's "bark". :-[
[It gets worse, don't worry!]
Kevin,what are you going to pull that with?
terrifictimbersllc
kevinlt15
 Well I hope to pull it with A 4wheeler, tractor, 1010 crawler,truck, and 2 young boys :D ;D.
thanks for the heads up on logrite
bill m
Quote from: kevinlt15 on December 10, 2011, 06:11:39 PM
In that exact order or one at a time? ;D
When you are pulling something that is heavier that what your are pulling with, things can get dicey and even dangerous, especially going downhill.   :o
r.man
I know most are using arches to keep the logs clean but in the case of a large log, a steep hill and a machine that is outweighed the log could be let down on the back to provide braking and stability.
kevinlt15
    Oh ya I know I need to be aware of the weight of my load compaired to what I am hauling it with.
I have got nothing But hills, and now with snow on the ground I have got little to no traction.
    hopefully this week I can try it out. ;D
mrcaptainbob
One of the biggest dog logs I've ever seen!How much does that weigh? The arch and tires don't appear to be over worked at all....
losttheplot
26 inch average diameter x 12ft doug fir = 1600lbs  plus 60lbs for the dog.
I have had pretty close to 2000lbs on it.
The spindles are 2000lbs with 13inch trailer tyres.
I think the legal limit for a trailer with no brakes is around 2000lbs and I pull it with a full size 3/4 ton truck. Traction would be the weakest link.
All the weight is straight down through the arch.
If the wheels get caught on a stump etc... the back bone will flex.
I used 2.5 x 2.5 x 1/4inch steel. I would go with something heavier for the back bone next time.
I may get around to making the back bone into a truss one day.
kevinlt15
    Hey Bill M.  I use the 4wheeler until it snows, then the tractor till it's deep snow, then the crawler, after that when it is colder than
A @#$%@!^&& well you know thats when we bundle my boys up like  the little brother in A christmas story to help out.
Just kiding  :D ;D 8)   Mery Christmas everyone You are all like brothers and sisters to me :'(
