Dynamic Green Products Inc.
Author Topic: Compression 041  (Read 1747 times)
Offline kenskip1
  • Stihl Looking for the fountain of middle age.
Compression 041
« on: February 08, 2004, 11:33:21 AM »
First off I would like to thank the forum members. I have picked up much usefull knowledge.
Can anyone tell me what the compression should be on my 041? It runs great however the resistance pulling the rope is very hard. Also what RPM is this saw supposed to turn?  This saw fits me well and is well balanced. I keep it in perfect working order.She is a real screamer. (The saw) Also does this saw have points or electronic ignition? I think it was made in 1974. Any other 041 users out their?
Stihl The One
Stihl Going Strong
Stihl Looking For The Fountain of Middle Age
Online beenthere
Re: Compression 041
« Reply #1 on: February 08, 2004, 11:46:20 AM »
Mine is still running strong after buying it new in 1975.  If it ever hiccups, I think I will buy a new one. Has been 'old faithful' for a lot of wood cutting every year. 20" Windsor bar is original, and survived a few 'bad' pinches. Been jointed twice. Grease the roller in the tip occasionally. Flip the bar between each chain change. Run two chains to one drive sprocket. When the chains are worn out, get two new and a new sprocket. Great saw. To my recollection, the saw has never needed carburetor adjustment. Was told not to expect that if I bought a second, smaller saw. So I have stuck with the powerful 041 Farm Boss. 3-4 pulls when cold, starts after that on idle with one pull (when not forgetting to switch to 'on') ;D
Offline jokers
  • Chainsaw Freak
Re: Compression 041
« Reply #2 on: February 09, 2004, 02:45:45 AM »
041s are known for longevity with a small amount of care, don`t let yours be spoiled by air leaks. Check all your hoses and connections regularly.
I don`t know what the factory spec for compression is on this saw, but I know that one in good shape that I sold a couple of years ago pumped up to 175psi. I was surprised because that`s pretty high for a saw. Max no load rpm is around 11k, not a real screamer by todays standards but a good cutting saw just the same.
Russ
Offline Blue9R
Re: Compression 041
« Reply #3 on: February 09, 2004, 10:52:19 PM »
- the resistence pulling the rope is very hard -
Recently,I ran across a posting on another forum for the same problem. It turns out the pull cord was too short, only partially filling the pulley.  What happens is that the mechanical advantage is lost, as a proper length pull start cord winds up in the pulley & provides a larger diameter or "gear ratio", that is easier to pull.
I had to chuckle, as I never paid any attention to starter rope length. But the principle is about as basic as "water always flows downhill".
The full cord length for a Stihl 044 is listed as 37 3/4" before the knots are tied, so I would just guess that approx. 30" of cord should pull out of an 041 recoil starter.
Just a suggestion for you to check out.  Good luck!
Mike
Saw compression
Started by Timbercruiser on Chainsaws
Last post March 19, 2018, 05:24:55 AM
by Al_Smith
272 compression?
Started by dutchman on Chainsaws
Last post February 06, 2013, 11:05:07 AM
by Al_Smith
Low compression?
Started by 421Altered on Chainsaws
Last post November 12, 2019, 07:35:49 PM
by Al_Smith
Compression
Started by Lnewman on Chainsaws
Last post July 08, 2013, 07:43:51 PM
by nixon
