OWB winter shutdown
Started by doctorb, January 25, 2012, 05:47:24 AM
Dean186
Doctorb,
Sorry to hear your back is bothering you.
My thoughts have always been; If the pump is left running, it would take many days before freezing is a concern in an OWB.
Good post, I will be monitoring your posted information.
Dean
doctorb
gspren-
Maybe it's due to state taxes, a torture at which we are really experienced here in Maryland, but the average price for heating oil in Md. was $3.97/gal on 1/23/12.  Found a state web site with that figure and called my supplier for verification. I may be moving to Pa!  Having driven north through Pennsylvania and New York to Canada countless times, I can assure you that Pa. gas prices are ALWAYS significantly lower than Md. prices.  So i'll bet that the difference between what you paid and what I would have to pay per gallon is state tax related.
gspren
Doctorb,
  I live close to the MD line and just recently retired from Aberdeen Proving Ground so for over 26 years I drove through Maryland 5 days a week and the prices have bounced back and forth as to where its lower, I think its a crime but our gas went up 0.10 yesterday. A lot of people move from MD to PA when they retire to escape the state income tax on pensions. I hope your back heals quick but I have antifreeze in mine because like your wife mine won't touch the OWB. When I go to the hunting camp I shut down till I get back. Good luck!
doctorb
Day #4:
OWB water temp:  86 degrees
AM outside temperature:  31.5 degrees.  (Oh my!  below freezing!)
Expected high temp today:  50 degrees
So the decrease in temp with the circulating pumps off is relatively minor compared to the loss of at least 20 degrees per day with them running.  I let the pumps run for about five minutes and shut them off again.
upsnake
Doc B, you are referring to the circ pump from the owb to the house and back right?
If so are you concerned with the water freezing at inside the pex, or at the fittings at the back of the owb etc.
(i know with 50 degree days it is not a big concern but if the weather was colder)
doctorb
Upsnake-
Yes, I think the area of biggest freezing potential is where the pipes exit the ground at the back of the stove.  Interestingly, I just removed the back panel, and I had forgotten that I had installed temp gauges on both the inflow and outflow lines.
The OWB temp is:  85 degrees
The outflow temp is:  78 degrees
The inflow temp is:  72 degrees
So the temp of the stove readout is not truly equal to the temps of the lines as the enter and exit the stove.  Now we don't know the calibration of all these thermometers, but I think it shows you have to be thinking line temperature in addition to OWB water temp.
And yes, I am referring to the pump at the back of the stove that sends the water from the OWB to my house and back.
doctorb
Day #5:
OWB water temp:  82 degrees
Outside AM temp:  32 degrees
Expected highs today in the 40's
Temps at back of stove:
     Outflow:  76 degrees
     Inflow:  52 degrees
Flipped the pump on for five minutes or so to increase the temp in the lines.  Pump off again for another day.
I think one can certainly conclude that the OWB is well insulated and, withou circulation, maintains temp very, very well.  Without the pump running the OWB temp has only fallen 9 degrees in 48 hours.
boilerman101
Hey Doc, hope the back is getting better and you will be back chuck'n wood and saving money again soon.
Before firing up again, you may want to check out CB's Eclassic initial start up video:   http://www.youtube.com/centralboilerinc#p/u/0/Cea9CV4kdHY
I took my E2400 water from 50 degrees backup to 185 in less than 2 1/2 hours, by following this method.
Would be interesting to see if it would take more or less time with your E2300.
Either way, I found this a great method to rebuild a coal bed fast!
doctorb
Day#6:
OWB water temp:  76 degrees
Outside AM temp:  28 degrees with a dusting of snow!
Expected high temp:  42 degrees
I flipped the pump on this morning because of that below freezing temp.  The rest of the week is predicted to be warm, so I'll turn it off tonight or tomorrow, dependent upon the temperature.
Boilerman - thanks for the heads up on the video.  I have not done it exactly like that before, and will give it a try on my restart.  My back is better, thanks, but it still pulls a bit.  I don't think that I'm being a wimp about it, I just think I should feel pretty normal before loading wood twice a day.  The great thing has been our very mild winter.  Yes, I'm burning oil now, but it could have been a lot worse.
mrwood
Boy dr b. sorry to hear about your pain and I hope you feel better soon. This would be a trie hurt for me. First the physical pain. Second the wallet pain for the oil. And third the emotional pain for not being aloud to "play" with my stove. All on my friends laugh at me because of how excited I get about my stove but after all of my hard work over the summer and great savings on heat, the stove is very rewarding and exciting. But I too have fuel oil and I think I would roll out there in a wheel chair before I had to pay for oil again. Yuck. I was glad to kiss that bill goodbye
doctorb
Day #7:
OWB water temp:  66 degrees
Outside AM temp:  34 degrees
Expected high near 60 degrees today!
Pump ran for 24 hours until this AM, when I shut it off.
I have a 300 foot run from my shed to my house.  I wonder if the ground temp would warm the pipes a little once the temp in the circulating water approached 50 degrees.  If true, this fact would support the idea that the OWB, or it's pipes, would not freeze if the circulating pump was left running.  Of course, this also assumes that the pipes be buried deep enough to be "protected" by the inherent temp of the earth, i.e., be below the freeze line.
doctorb
Day#8:
OWB temp this AM:  65 degrees
Outdoor temp this AM:  51 degrees!
I wont continue to bore you guys with this.  Without subfreezing temps, all this info lacks significance.  I did learn a few things from this exercise, though.  Hope to be up and burning again soon.
petefrom bearswamp
doc
How deep are your lines?
Back in 94 I had a Taylor with a 125 foot run from the furnace to my house with the lines only about 1 1/2 ft deep.
I lost 7 to 9 degrees from the furnace to the house and the snow always melted over the lines even with 2 to 3 ft of snow.
I sold this after 3 years and burned oil until 2005 when I installed my classic.
I now have a run of only 30 ft or so and the heat loss is negligible, even with the lines only 1 ft deep.
I usually have at least 2 feet of snow over the line area almost all winter.
This warm winter is sure easy on the wood pile.
Hope you are better.
Pete
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
doctorb
My lines are about 3 feet down.  That was not my decision, but the decision of my dealer.  In my 300 foot run from my shed to the house I lose about 6-7 degrees each way.  I do not get snowmelt over the lines as the snow falls and the snow "sticks" evenly across the lawn .  As the snow pack ebbs, over the lines is the first to go, but the melting over my lines is not dramatic, and the rest of the lawn has pretty thin snow cover by the time the grass over the lines shows through.  So I realize I have heat loss, as do we all, but for my situation i think it's acceptable.
By the calculations from Dean186's thread I linked to earlier, I am sure that, over the course of a full winter's heating, I am donating a cord or more of firewood to heat the ground.  If I knew then what I know now, I would spend the extra time and $ to do it by Dean's method.  however, I have no plans to rip up my lines anytime soon. :)
DBRACKETT
Personally I have enjoyed the stats it's that be prepared thing for me. Even though you've had almost ideal weather for a mid winter shutdown the temp readings have still given us something to go by especially in the first few days. No matter what weather conditions you have there will be a ton of differences between stove setups, even if it's as simple as the length of the pipe run. For instance your 300 ft is going to loose more heat than my 80 ft run just saying.
Dan
doctorb
DBRACKETT-
I think it's given me a handle on how the stove behaves without a fire.  I am much more confident now that, even with cold winter temps, if you leave the circulation pump running, it's going to take quite a few days to freeze, if ever.
And I agree that our individual set-ups play a role in the way each system will behave.
doctorb
Well, my back is still tight, but this weekend is forecast to actually feel like winter,  so I decided to start the OWB up this afternoon.  I followed some of the suggestions I saw on a CB video that was linked in an email or PM I was sent, which I can't find at the moment.
Anyway, the start up went great. In 2.5 hours I went from56 degrees to 152 degrees.  Gassifying well.  I loaded it up and came in for the night.  I'll check the water temp coming into my basement from the stove in an hour or so.  When it reaches 180 degrees, I'll open the loops to my two basements and stop burning oil!
I find it interesting that my stove only got down to 56 degrees being off for 2 weeks in winter.  I
selected some days to shut the circulating pump down, but for the last 4-5 days I've left it on 24/7.  The system holds heat very well IMO, especially when the temperature gradients between the stove and the ground are small.  From this experiment, even though our temps have been mild, I am confident that I can leave the stove off and run the circ. Pump without fear of freezing for over a week or more.
trapper
We regulary leave the pump run when we go on vacation in the winter for two weeks with the gas furnace set at 50 degrees. The water in the OWB is normaly about 50 degrees when we get home.
Marv
mrwood
This has definetly been good info to know as I do not plan winter vacations it is nice to know that if something happens it should be ok. I know that for this process to work correctly for me I would have to bypass my thermostatic valve to allow my original furnace to add a little heat to my water. Thanks for the write up dr b
Dean186
Quote from: doctorb on February 01, 2012, 09:40:09 PM
doctorb, Thanks for sharing this important information.  I am sure it will help many OWB owners.
The results you observed echos my thoughts I have posted in the past.  With the pump running, the likely event of the water freezing is slim and there is very little reason to add anti-freeze to the water. IMO
Glad to hear your back is better,
Dean
Jack72
Hey Doc
Im glad your back is better and stays that way.      This may sound dumb but    I know with this mild winter we are having in most area's             if it was much colder out and you were worried about it freezing       if you could run a electric cord through the reaction chamber and put a little heater (box heater w/fan and a thermostat)
in the firebox if that would help keep it much warmer just curious.          My wife is a school teacher and we never take winter vacations but if we ever did around christmas I would not want to bother my neighbor to keep it running.      Its either that or put 200 gals of glycol in the stove$$$$    Id rather not but it sounds like it made it along time for you.             Jack
13 Chevy Duramax
Stihl 046 036 009
Northern 25 Ton Splitter
doctorb
I would not add antifreeze to this system as it would take quite a few gallons to protect this volume of water, and my understanding is that, when that level of protection is reached, heat exchange is somewhat inhibited by the glycol.  (I don't know why that is, but I have read it in serveral different locations).
From this test, certainly a long winter weekend or more with no OWB fire should not be enough to threaten freezing of this system unless severe cold is present.  I think that just leaving the pump running keeps the areas in the system that are in jeopardy of freezing (pipes exiting and entering the ground at the back of the stove) from doing so.  I am pretty confident that these well insulated OWB's with high water volumes handle this situation pretty well.  My only change in my currrent practice will be to insulate the area of the stove where these pipes are located.
Running the OWB water through the heat exchanger will return some heat from the oil furnace to the OWB, but it appears mostly unnecessary to do this as a prevention of freezing.  To emphasize, I did NOT do this during this test.  If you use this method, the amount of heat draw from your oil furnace is substantial, and you will burn a bunch of oil which is probably a waste of that fuel, as the OWB is unlikely to freeze over several day span.
After this test, I have no plans to add any supplemental heater, as you suggested, to the system.
r.man
A friend of mine runs his air to air heat pump at both ends of the winter to conserve wood. His water rad is out of the furnace while the heat pump is running but he leaves his circulating pump on all the time. The air to air will keep up until about 10 degrees F so he will burn a bit of cardboard if his water temp gets close to 32. If I remember right he only has to do that every few days if it is quite cold.
upsnake
So question on leaving for a couple days with the OWB.
Through Doc B's experiment, I am worried about going out of town for a few days. My question though is for ppl that have forced air furnaces with two tstats.
I have my owb tstat set for 70, and then my propane tstat set for 50.
The problem is when the fuel is used up in the owb, the owb tstat is going to tell the furnace blower to stay on until the house is 70, but since the propane tstat is going to only heat the house to 50, the blower motor will stay on the whole time.
What i was thinking of doing is filling the owb up and then turning off the owb tstat and let the house just fall to 50 and let the propane furnace take over.
Anybody else go through this or have any better ideas?
Jay
doctorb
Is your propane back-up heat for the OWB or do you have a propane fired hot air furnace separate from the OWB in your basement?
