Author Topic: shear head or chainsaw?  (Read 2747 times)
Offline treefarmer87
« on: January 25, 2012, 06:55:07 PM »
which is faster for cutting pulpwood a cutter with the shear, or a chainsaw?
1990 Ford F-800
1974 Ford L 9000 Self Loader
2004 Tigercat 718
1998 Barko 225
1999 John Deere 748G
FEC 1000 slasher
FEC 1550 slasher
Danzco Delimber
Sthil 461
Sthil 250
Offline nhlogga
Re: shear head or chainsaw?
« Reply #1 on: January 25, 2012, 06:56:40 PM »
It all depends on the machine.
Jonsered 2260
Husky 562xp
Offline snowstorm
« Reply #2 on: January 25, 2012, 08:08:21 PM »
had a morbark rapid buncher on a tracked machine years ago. 4 trees a min. no one will buy sheared logs. there for a shear isnt worth much up here
Offline snowstorm
« Reply #3 on: January 25, 2012, 08:16:39 PM »
you asking about a bar and chain head like a timco?
Offline Side loader
« Reply #4 on: January 25, 2012, 08:34:08 PM »
For syp plantation thinning, a shear fellerbuncher works fine for me with a grapple skidder.  If I were hand felling and/or on rough hilly ground I figure the chainsaw with a cable skidder would be the way to go.  Putting down 5 or 6 (25 to 30 ton loads) a day in good wood is no problem for a good operator. I sent a load of chip 'n saw to the mill today cut with the shear. The knives are pretty straight. However, when I cut light poles I do have to trim the butts super smooth. But it's worth the trouble.
Side loader log truck w/492 Detroit, bell super T feller buncher, Barko 160 with JD power, Kubota M4900 with brush raker grapple on front and shop built bunching grapple on back. JD 350B Dozer; JD 548D skidder;  and a couple of saws.
« Reply #5 on: January 26, 2012, 08:50:25 PM »
i would use the shear for pulpwood only. I would hand fell the logs. Would it be practial to lay bunches with the shear and drag with a cable machine
1990 Ford F-800
2004 Tigercat 718
1998 Barko 225
FEC 1000 slasher
FEC 1550 slasher
Danzco Delimber
Sthil 461
Sthil 250
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« Reply #6 on: January 26, 2012, 08:56:32 PM »
If you plan on cutting any sawlogs, a shear may severely limit your markets.
Offline saltydog
« Reply #7 on: January 26, 2012, 10:01:53 PM »
I worked behind several shears we put down over 50 cord a day limbed and bucked with saws works great.I wouldnt use it in logs .We mostly cut jack pine not many logs there but sold alot of bolts and they knew they were sheared.Jeffs right it will limit outlets.
Proud to be a self employed logger.just me my Treefarmer forwader Ford f600 truck 2186 Jonsereds 385 and 390 husky and several 372s a couple 2171s one 2156  one stihl 066  Hudson bandmill Farquhar 56"cat powered mill.and five kids one wife.
Offline jd540b
« Reply #8 on: January 27, 2012, 07:23:15 AM »
Cut lots of spruce logs with my shear-just have to trim the butts back a little.  The production more than makes up for it.  Also, with a shear you don't have to worry about rocks, etc so much-especially driving the head down into the snow in the winter.  Shear is pretty maintenance free in comparison to saw as well.  Definately practical to make bunches for a cable machine-I did it that way for a couple years till I got a grapple.  Saves pulling cable and greatly improves production.  I used a few long chain chokers.
Offline semologger
« Reply #9 on: January 27, 2012, 09:36:15 AM »
i like the shear for small pine. ive only replaced a few blades in 10 years. i am looking for a shear head 4 a cutter i found.
Offline Jeff
  • Fearless Leader
« Reply #10 on: January 27, 2012, 12:57:00 PM »
The first mill I worked in simply quit accepting sheared wood after the end of a sheared beech log exploded on the headsaw, blowing a chunk of wood through supposedly bullet proof glass into my face knocking me unconscious and sending me to the hospital with a concussion. I came back and finished the load we were working on and then went home. Was out of work for the next two days until the swelling went down in both eyes so I could see to saw. There was no back up sawyer.  The second mill I worked at, already had a no sheared wood policy when I went to work there.
« Reply #11 on: January 27, 2012, 09:03:34 PM »
i would like to have one for stuff under 12'', anything that would be log quality i would use the chainsaw. i would like a shear, but that means another piece of equipment in the woods to service and worry about ( here i am talking about a cutter and i havent even got my new skidder yet :D) a few more weeks and i should be able to go pick it up :)
1990 Ford F-800
2004 Tigercat 718
1998 Barko 225
FEC 1000 slasher
FEC 1550 slasher
Danzco Delimber
Sthil 461
Sthil 250
Offline semologger
« Reply #12 on: February 18, 2012, 03:30:58 PM »
treefarmer did you buy a bell? I thought i seen a post on here about it?
« Reply #13 on: February 18, 2012, 04:06:31 PM »
no not yet i am picking a new log truck tomm. And i am trying to find another skidder
1990 Ford F-800
2004 Tigercat 718
1998 Barko 225
FEC 1000 slasher
FEC 1550 slasher
Danzco Delimber
Sthil 461
Sthil 250
Offline lumberjack48
  • 36 yrs ago, cutting Ash saw logs
« Reply #14 on: February 18, 2012, 08:14:20 PM »
I bought a new 450 JD with a Visco 15" shear head back in 76. I was running 2 skidders, i sheared all the junk wood and pulpwood, it really worked out good. Back then i had a hard time selling saw bolts just because i had a shear on the job. I had to sell my self and promise that i wouldn't send any sheared wood in.
« Reply #15 on: February 19, 2012, 08:16:40 PM »
i bet that was a neat rig. It was a 450 dozer ? with a shear
1990 Ford F-800
2004 Tigercat 718
1998 Barko 225
FEC 1000 slasher
FEC 1550 slasher
Danzco Delimber
Sthil 461
Sthil 250
thinking of putting a shear head on my old 740-d
Started by logger t on Forestry and Logging
Last post January 06, 2012, 06:13:52 PM
by lumberjack48
Hydro-ax shear head. where do I buy knives?
Started by Sam Strom on Forestry and Logging
Last post February 28, 2020, 09:12:49 PM
by timbco68
Chainsaw head unit
Started by dustintheblood on Firewood and Wood Heating
Last post December 19, 2016, 03:48:09 PM
by hedgerow
STIHL Chainsaw has Carbon on Cylinder Head.
Started by johndrew98 on Chainsaws
Last post November 22, 2019, 04:23:44 PM
by 630red
