Author Topic: Which Swingblade mill should I buy??  (Read 9722 times)
Offline acco1840
    • facebook
« on: February 05, 2012, 09:23:02 PM »
G'day. am in Australia and am looking at buying a swingblade mill. I used a Lucas 8-30 for 3 months and it was good, but used another and it was a problem child. I have seen Peterson portable sawmills ASM and used it, but sadly, my budget is not that good. Anyone had experience with ther Peterson ATS??
Not too keen on band mills as am milling big hardwoods and have tried CSMing. That is just hard work!!
 (I have my CSM for sale!!)
I will be cutting mostly 4" x 8" Sleepers from 7 feet long.
Offline woodcrazy
  • retired sawyer --- much dried lumber to sell
Re: Which Swingblade mill should I buy??
« Reply #1 on: February 05, 2012, 09:31:05 PM »
You might check out the MOBILE DIMENSION MILL before you decide, ask for their free video.     WOODCRAZY
I miss the milling -- may try planeing -- or developing my Minnesota lakeshore
Offline acco1840
    • facebook
« Reply #2 on: February 05, 2012, 09:44:11 PM »
never heard of one.....will have a look.
Ok, just had a look. THAT is a mill!!
http://www.mobilemfg.com/
Offline Ron Wenrich
« Reply #3 on: February 06, 2012, 07:24:52 PM »
Mahoe is in New Zealand, and makes a double cut mill.  You might want to take a look at them, as well.  The minimax is their smaller mill.
http://www.sawmills.co.nz/minimax.html
Offline Silver_Eagle
« Reply #4 on: February 07, 2012, 10:38:16 PM »
Here is a current price list on the Mahoe mill's I had emailed on request fyi. Seem's to be a very very nice mill imho.
Sawmills New Zealand Ltd            1st May2011
PO Box 510                  09 4059 708
Kerikeri 0245                  www.sawmills.co.nz
Price List
The Mahoe range of sawmills are all robust and strongly built. They are lever operated and return the finished board to the operator. The Mahoe sawmills are easy to set up, easy to load logs into the mill and easy to operate, requiring the minimum of labour.  Fine kerf blades are available.
Mahoe Minimax 12 x 8
Briggs and Stratton 35hp petrol            $32,000.00
Khola 40hp petrol                  $33,500.00
Optional Extras
Extra set of weld on tipped blades            $ 1,200.00
Fine kerf blade with collars               $ 1,000.00
761mm inserted tooth blade               $ 1,497.00
560mm inserted tooth blade               $ 1,085.00
Trailer   with dura torques                $ 3,200.00
Light Board                     $    200.00
Set of Log Dogs                  $    800.00
Supermill 12 x 8 with hydraulic rise and fall
Kubota 42hp turbo diesel               $60,000.00
Supermill 12 x 8 with manual rise and fall
Kubota 42hp turbo diesel               $48,000.00
Optional Extras
Trailer with suspension               $ 3,200.00
Light board                     $    200.00
All the sawmills come with one set of weld on tipped blades, jockey grinder for sharpening and Cut to Taper.
Slabbing Attachment
The Slabber is power fed; you can set the feed speed which leaves you free to wedge the slab.                        $ 3,000.00
Packaging and freight to Port of Auckland (for export)       $ 1,800.00
Insurance (for export)                     $    300.00
A 20% deposit confirms order. Balance due ex our yard. All prices quoted are + GST
Offline logboy
« Reply #5 on: February 08, 2012, 09:07:54 PM »
Here is a Mahoe video I just found.  They look like a great mill.
I like Lucas Mills and big wood.  www.logboy.com
Offline logboy
« Reply #6 on: February 08, 2012, 09:13:29 PM »
Here is another one.  I was told by David Bolstad (before he unfortunately passed) that its easier to saw by yourself with one of these than with a typical swingblade mill. Its also a lot less work.
Offline acco1840
    • facebook
« Reply #7 on: February 16, 2012, 04:12:53 PM »
A mate has a swingblade mill for sale. Just found out last night. It is mounted on a tandem axle trailer. It has an Isuzu 4 cylinder diesel engine and the saw is driven by a hydraulic motor. I have not seen it yet, but it sounds promising. So does the price of $3000 8). Will get pictures soon. Anyone used a hydraulic powered swingmill before??
Offline acco1840
    • facebook
« Reply #8 on: February 23, 2012, 12:04:15 AM »
Sadly, I was a bit late and missed it............bugger :'(
Offline Okrafarmer
  • Location: upcountry SC-- Sweetgum capital of the world!
  • Exiled from Sawdust Land--plotting a return
« Reply #9 on: February 23, 2012, 12:06:18 AM »
So sad. You will surely find another.....
No matter how conventional wisdom may fly in the face of radical thought, it's still the most popular type.
Reduced to Uber Driver and a broken MS290 Stihl
Genesis Hardwood Lumber
Offline LOGDOG
« Reply #10 on: February 23, 2012, 08:44:23 AM »
That Mahoe mill looks an awful lot like the Turb-o-saw or vice versa. Doesn't it?
Anyone building a swingblade mill ?
Started by plantman on Sawmills and Milling
Last post October 30, 2017, 01:36:56 PM
by plantman
Chainsaw Powered swingblade mill.
Started by acco1840 on Sawmills and Milling
Last post February 29, 2012, 11:06:14 PM
by acco1840
Has anybody mounted a laser on a swingblade mill?
Started by scsmith42 on Sawmills and Milling
Last post February 17, 2006, 01:48:14 AM
by scsmith42
Has anyone built a swingblade mill from scratch?
Started by Dangerous_Dan on Sawmills and Milling
Last post September 03, 2011, 12:08:24 PM
by tjhammer
