Dynamic Green Products Inc.
Author Topic: powered vent for kiln  (Read 974 times)
Offline stevareno
« on: February 27, 2012, 01:18:52 AM »
We're building a 20,000 bdft kiln.  Everything is completed except the vent.  I would like to use a powered vent so I can create a slight negative pressure in the chamber which will be controlled by a humidity/temp controller.  Is there a formula to figure how much ventilation I would need for a kiln this size?
Offline Ga_Boy
  • Been rode hard and hung up wet; more than once.
Re: powered vent for kiln
« Reply #1 on: February 27, 2012, 11:10:22 AM »
Check with Den (board Mod) at PC Speciality.  If he does not have a powered vent instock he should be able to point you to where you can find one.
Offline Den Socling
  • just wondering
« Reply #2 on: February 27, 2012, 01:50:03 PM »
Well this is cool. You're both PCS customers.
Steve,
I can't answer you. Getting a negative pressure would depend on how tight your chamber turns out to be. How much air you want to move would depend on what you are drying. I have seen big, power vents run constantly with soft maple and I have seen small vents run intermittently with oak.
We don't stock much for conventional kilns. We are pretty much limited to vacuum kilns except for control systems. McMaster-Carr is as good of source as any. They have a lot of vents with louvers. Some are corrosion resistant.
Thanks guys.
Den
Help with the l200/kd250 powered vent kit
Started by Hot Shot Rob on Drying and Processing
Last post June 27, 2018, 08:32:09 AM
by K-Guy
Solar Kiln Vent Questions
Started by Joel Eisner on Drying and Processing
Last post February 09, 2006, 09:06:51 AM
by Snag
Vent question solar kiln
Started by Turkeyeyes on Drying and Processing
Last post September 06, 2016, 04:30:57 PM
by GeneWengert-WoodDoc
Kiln Intake and Exaust Vent Instillation Question
Started by Ga_Boy on Drying and Processing
Last post August 22, 2005, 07:28:59 AM
by Den Socling
