Author Topic: Quick help please......LT40 Blade Drive Wheel Alignment  (Read 1480 times)
Offline CalebL
« on: March 01, 2012, 09:10:31 PM »
I am doing a complete alignment on my LT40.  I have taken the guide roller assemblies off and started to check the blade wheels for alignment.  The Drive side is a 1/4" off by checking it with the blade guide alignment tool.  The business end of the blade is higher than the back of the blade.  The manual says to adjust the vertical adjustment screws.  I loosened the bottom screw and tightened the top to tilt the wheel down but no matter how much I loosen the bottom adjustment screw and tighten the top one, the wheel wont move.
I am about to pull my hair out.
2005 LT40 HDD34
2000 Cat 226 Skid Loader
Offline CalebL
Re: Quick help please......LT40 Blade Drive Wheel Alignment
« Reply #1 on: March 01, 2012, 09:55:34 PM »
I don't know what the problem was but I tried to adjust the wheel up and when I did that it freed up.  I was then able to adjust the wheel down and get it to within a 1/32 of an inch.
2005 LT40 HDD34
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #2 on: March 01, 2012, 10:20:07 PM »
And you still have your hair.   ;D
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #3 on: March 02, 2012, 05:26:18 AM »
I've just started the alignment and blade guide replacement job on my mill, just take your time and go step-by-step.
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Bogue Chitto
« Reply #4 on: March 02, 2012, 09:09:37 AM »
Did you loosen one side  screw?
Offline CalebL
« Reply #5 on: March 02, 2012, 10:00:10 AM »
Yes.  That seemed to help also.  I don't know why but it wouldn't tilt the wheel down until I tilted it up and then back down.  Strange but it worked.
2005 LT40 HDD34
Offline CalebL
« Reply #6 on: March 02, 2012, 10:00:29 AM »
Not much on top but some on the sides.
2005 LT40 HDD34
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
« Reply #7 on: March 04, 2012, 12:11:10 AM »
A can of penetrating oil will help to free it up. Disassembling, and wire brushing the parts, then applying a light coat of oil will go a long way to make sure that you are accurate and that no wood fibers are holding it in place, as they will shift leaving you pulling your hair out again in just a short time.
Just get out the book and go thru it step by step and a good alignment will hold for quite a long time.
Blade Wheel Alignment-LT70
Started by oregonsawer on Sawmills and Milling
Last post February 06, 2010, 01:04:08 PM
by oregonsawer
help me understand wheel alignment & blade tracking
Started by bruce29 on Sawmills and Milling
Last post June 08, 2011, 06:21:40 AM
by bandmiller2
LT40 Rumbling noise around the drive wheel
Started by Tree Dan on Sawmills and Milling
Last post July 20, 2019, 09:11:09 PM
by Brucer
LT40 Blade guide alignment problem?
Started by AdamT on Sawmills and Milling
Last post August 23, 2013, 12:58:33 PM
by drobertson
