when you have too much wood, do you sell your saw?
Started by opticsguy, March 04, 2012, 09:06:31 AM
opticsguy
OK, so I have run out of places to store and dry wood.  What do I do now? Sell my saw? Seems like life will come to an end if I cant cut more wood.    :-)
The real question is;  When you run out of storage, what do you do?
TK 1220 band mill,  1952 Ford F-2, 1925 Dodge touring, too many telescopes.
Corley5
POSTON WIDEHEAD
If you can't cut more wood.......yes life will come to an end.  :D You will feel yourself wilting away little by little. The lights will start to get dim and you will see a bright light at the end. Then your memories of saw dust are gone. They will put you in a special home where you sit there and chew your tongue. You will have flash backs when you see a tooth pick on your dinner tray. Vey sad!  :'(
Are you advertising your wood for sale or are you secretly hoarding it?
Not being able to be portable apparently has it's disadvantages.  How about doing some custom sawing where the customer brings the logs to you or maybe sawing some specialty stuff like burls?
There are niche markets.
terrifictimbersllc
Chuck White
Stack it outdoors (up off the ground) and cover it.
Start making stuff with some of it.
Being a portable sawyer myself, I only have around 200 bf of lumber on hand.
shelbycharger400
sell...sell....sell..   the wood that is!
i have the opposite problem right now,  lots and lots of logs /firewood too to go get,  last storm dumped 8-12 inches of Snow and it isnt melting very fast.  dosnt help i have a 2 wd one wheel wonder either!
saw logs are at the farm!
if you cant sell,  find more places to stash the stash!
kderby
I tell prospective sawmillers they will eventually mill more lumber than they can ever use.  I suggest two things:
First buy a used mill.  When you are buried in lumber you can sell the mill to the next guy.
Second, realize that commercial sawmills lose money on the majority of what they mill.  The way they stay in business is to be carefully tuned to the tiny sliver of high value production.  The rest is just volume to get rid of.
Lumber is like any other product.  It is worth what someone is willing to pay.  If you are spending money to store and handle worthless material (and I am certain that you are)....your mistake.
I have the affliction as well.  I store lots of lumber (worthless included).  I like lumber wrap for outdoor storage.  Lumber is shelf stable to a point.  I also know that I will end up drowning in junk if I keep it around.
Bottom line:  As Mr. Shelbycharger says..."Sell! Sell! Sell!"  It is a step forward in the process of becoming a sawyer to realize where the value is and where it is not!
Respectfully submitted.
Kderby
Left Coast Chris
I have had a similar experience.   I did build more storage area but eventually that filled.  I then started high grading.  Realizing that the warped hardwood is not likely to sell, look for a friend that builds jewlery boxes or small items and give to him or trade for labor etc.   You could also cut the warped stuff into straight smaller pieces and put on Craigs list.    It is good to join a local wood working club.  Many woodworkers are frugal and would not take time to buy wood off of craigs list.   But they get interested if you bring some to club and they see it.
Also, what kind of wood do you have and are there any upcoming projects planned?   It will supprise you how much wood a project will take if there is some loss due to warpage and defects.
Stopping sawing is probably not a good option if you are like the rest of us where we "found our purpose" (Forest Gump) in sawmilling. :) :)
Home built cantilever head, 24 HP honda mill, Case 580D, MF 135 and one Squirel Dog Jack Russel Mix -- Crickett
Actually your inventory situation is what put me into the portable sawing business.  I either had too much, not enough, wrong species, wrong length, wrong dimension, etc.
Tree Feller
I can see how having too much lumber can easily become a problem. I don't even have a mill (yet) and I'm covered up with Walnut, Cherry, ERC and Pine lumber. I have more beetle-killed Pine to cut on my place and one large dead Hickory. In addition, a good friend has offered some of his dead Red Oaks and Post Oaks (drought casualties) and I'm going Tuesday to saw and fetch them.
I just can't stand to see good trees rot away when they can be sawn into something useful. I'm currently using up the Pine lumber on a 10 x 20 storage building and I'll eventually get around to the Walnut and Cherry for furniture projects. Like you, however, storage is the big problem.
Cody
Logmaster LM-1 Sawmill
Kioti CK 30 w/ FEL
Stihl MS-290 Chainsaw
48" Logrite Cant Hook
never finished
  I'm building a side shed onto another side shed to store more lumber. Not a problem, got plenty of lumber. The building started as a 30' x 30'. With this 12' add on it will be 30' x 64'. Then I can saw more lumber. See I don't have a sawdust problem.(addiction)
Quote from: Chuck White on March 04, 2012, 11:12:26 AM
Can you ever have too much lumber  ??? :D :D.  I only have about 17,000 BF, so I need to saw some more oak  ;D.  (A man has to have sheds......)
Meadows Miller
Thats Simple Stop Hoarding it And Start Selling it Mate  ;)  :) :D :D 8) 8) You will need never to part with your mill then ;):) 8) 8) 8)
4TH Generation Timbergetter
POSTON WIDEHEAD
I did and I commented on it.  You are a poster child for the "A man has to have sheds" philosophy  ;D.
Sixacresand
Build something.  I thought I had too much lumber stacked up too.  But when I started using it on my barn the stacks went down pretty fast.  In fact, I kind of like nailing it up green, right off the mill.   I can skip the sticking, stacking process.  LOL
"Sometimes you can make more hay with less equipment if you just use your head."  Tom, Forestry Forum.  Eleventh year with a LT40 Woodmizer,
POSTON WIDEHEAD
Quote from: WDH on March 04, 2012, 08:50:40 PM
I know you commented on it.... :D Just wanted to get my shed mentioned in another thread.  :D :D :D
Your right....a man gotta have sheds!!!!  :)
red oaks lumber
sheds  isn't that topic in the outdoor section?
Meadows Miller
Okrafarmer
Sell it or use it. Maybe you need to work on your marketing strategy. You could end up with all kinds of money if you sell your lumber. Then you could buy stuff! Like... more logs.
Now selling Logrite tools!
Brucer
Stop sawing, keep the saw, and start marketing. Personally I hate marketing >:(. Fortunately marketing gets easier after you've done it for a while.
Bruce    LT40HDG28 bandsaw
Okrafarmer
Unfortunately, many people are either good at producing, or good at marketing, but not both. I mean, unfortunately for them. If marketing isn't your strong suit, see if you have a family member or friend who is better at it than you are. They can either help you accomplish it or at least give you some pointers as to how to go about it. Of course, we can give you some pointers on here, too.
tcsmpsi
Too much lumber....hmmmmm...I ain't never thought of that.       :D
\\\"In the end, it is a moral question as to whether man applies what he has learned or not.\\\" - C. Jung
Stephen1
I agree with MM , go portable, sawdust addiction is fed, and no lumber to store or mess to clean up or dispose of.
