Author Topic: Old Man of the Maple Tree  (Read 5132 times)
Offline LarryRB
Re: Old Man of the Maple Tree
« Reply #20 on: March 15, 2012, 08:29:48 AM »
I am just wondering if you have a book match to it?
Offline fat olde elf
  • Growing old is not for sissies - Betty Davis
« Reply #21 on: March 16, 2012, 04:03:48 AM »
Yes WDH, DanG could be an Ent.  He also could be Gandalf himself.  He also looks a lot like Dumbeldoor in the Harry Potter books.
Cook's MP-32 saw, MF-35, Several Husky Saws, Too Many Woodworking Tools, 4 PU's, Kind Wife.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #22 on: March 16, 2012, 06:06:30 AM »
Proof trees came frome monkeys.
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide,  Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline jueston
« Reply #23 on: March 16, 2012, 08:05:48 AM »
thats evolution for you...  :)
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #24 on: March 16, 2012, 09:21:19 AM »
So, that sly rascal has been an Ent all this time?  I guess he Ent-tended to keep this a secret  ;D.
Offline opticsguy
« Reply #25 on: March 17, 2012, 04:59:38 PM »
Just think if you had rotated the log 30 degrees before cutting, you would have had the image of the Space Shuttle flying overhead while Thomas Jefferson and others were signing the Declaration of Independence.
TK 1220 band mill,  1952 Ford F-2, 1925 Dodge touring, too many telescopes.
Offline WDH
  • Forester
« Reply #26 on: March 17, 2012, 10:27:29 PM »
Opticsguy, you have a good eye  ;D.
Offline Okrafarmer
  • Location: upcountry SC-- Sweetgum capital of the world!
  • Exiled from Sawdust Land--plotting a return
« Reply #27 on: March 17, 2012, 11:57:56 PM »
I'll keep an eye out for something like that.
No matter how conventional wisdom may fly in the face of radical thought, it's still the most popular type.
Reduced to Uber Driver and a broken MS290 Stihl
Genesis Hardwood Lumber
Offline Okrafarmer
« Reply #28 on: March 17, 2012, 11:58:48 PM »
I have to go back and look, but actually I think the match may have been an outer slab.  :-\
Offline Okrafarmer
« Reply #29 on: March 19, 2012, 11:42:49 PM »
Well, a week or so later, I hope to get back to the whack tomorrow. As long as the mill is not out of whack.  :-\  Anyway, I have three more logs to saw (remember this takes me an inordinately long time!). It may take me all afternoon to mill the three logs. Two of them are pretty good size. I need to try some blades that are specifically for hardwood, and maybe they will stay sharp longer. But my offbearing procedure is probably what slows me down the most. I am trying to improve my style, but right now I am lucky if I get 50 bf an hour. Maybe with the larger logs I will do better. But when the maple is done, I have a treat for after that-- HOLLY! American Holly! Four logs, about 8-10" diameter. When I have the holly finished, then I will take the holly and the maple, and the wood gnome, to the kiln. And hopefully the last load I took will be ready-- I need to time milling the holly until I know my wood that's in the kiln is ready, so the holly, hopefully, doesn't spend much time green.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #30 on: March 19, 2012, 11:48:09 PM »
I am still wondering if that was Holly that I sawed a few weeks ago?  Maybe I can get in the woods soon and check Holly bark out.   ???
Offline Okrafarmer
« Reply #31 on: March 20, 2012, 12:06:43 AM »
Well there are several kinds. I will post pictures. American Holly seems to be the one most likely to achieve millable size. The American Holly is definitely white or ivory color inside (the wood even seems to bleach out a little after it is cut, it is more of a very light yellowy or vanilla color before the surface dries.) . The trick, I've been told, is to get it dried in the kiln immediately after milling, but I am by no means an expert, so we are trying to achieve this as a learning process here.
Offline Okrafarmer
« Reply #32 on: March 20, 2012, 12:20:15 AM »
Oh, and American Holly bark is usually quite smooth and gray, kind of resembles beech bark. Of course there are knots every two inches or so and prickly hard green leaves every two millimeters or so on the twiggy little branches. I will definitely mill any piece 8" and up that appears to be even apologetically straight.
Offline Tree Feller
« Reply #33 on: March 20, 2012, 12:47:02 AM »
The trick, I've been told, is to get it dried in the kiln immediately after milling...
You've been told right. You also need to saw it the same day it's felled if you can, especially in warm weather. In cooler weather it may be possible to wait a bit before milling without the lumber staining.
Cody
Logmaster LM-1 Sawmill
Kioti CK 30 w/ FEL
Stihl MS-290 Chainsaw
48" Logrite Cant Hook
Offline Okrafarmer
« Reply #34 on: March 20, 2012, 12:57:34 AM »
Unfivefortunately, it was cut down about a week ago, or a day or two more. I'm hoping the cut-down time is not nearly as important as the milling-to-kiln time.
Offline WDH
  • Forester
« Reply #35 on: March 20, 2012, 08:06:05 AM »
The clock is definitely ticking on you with this hot weather.
Offline Okrafarmer
« Reply #36 on: March 20, 2012, 11:02:59 AM »
Yes and unfortunately again, I have just come down with Strep throat. And I am under pressure to help out with some other "urgent" projects.  :(
I have a doc appointment in an hour. Mrs. Okra made me say "Ah" and she saw a huge white spot on the back of my throat. Hope that isn't TMI.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #37 on: March 20, 2012, 11:22:10 AM »
GRITS.
Offline Okrafarmer
« Reply #38 on: March 21, 2012, 01:19:43 AM »
Good guess, but I think not. I went to the doc today and they did a test and it came back negative for strep, so it's just a nasty virus.  :-\
I milled up two maple logs today, took me four hours. About 200 bf.  >:(
Maple Tree
Started by firechief on Tree, Plant and Wood I.D.
Last post January 08, 2010, 07:52:05 PM
by bill m
Big Maple tree
Started by POC on General Board
Last post February 16, 2014, 06:11:45 PM
by beenthere
New Maple Tree
Started by Rhodemont on Urban and Community Forestry
Last post June 24, 2018, 09:17:15 PM
by Ron Scott
Maple burl tree
Started by mog5858 on Tree, Plant and Wood I.D.
Last post February 24, 2016, 06:05:19 PM
by mesquite buckeye
