Tally-I/O
Author Topic: My Belsaw  (Read 1034 times)
Offline snowshoveler
  • Knotty Knot Sawmill
My Belsaw
« on: March 17, 2012, 06:03:48 PM »
Well folks...thanks to you for the most part my new to me belsaw can cut pretty nice lumber.
 I worked on it today for a few hours, made up and put a new flat belt on.
Lined up my pulleys and then locked it inplace with a turn buckle.
Ran the carriage back and forth a few times just to make sure things were true.
 Then I picked up a little fir log and dogged it in. Log only made a few 1x5s but they
are the same size end for end. Even straight.
I must say I am impressed with how it works.
 There are still things to do. I need to put together a log deck.
Would like it to hold enough logs to last an afternoon sawing.
Then a better feed control lever. And an off bearers table, roller.
 Thanks again I would have had a very difficult time without you and special thanks to Captain Crunch. I spent a lot of tme looking at his mill pics and reading how he did things.
 Regards Chris
International T5 dozer
JD M tractor
MF skidloader
Jonsered chainmill
Vintage Belsaw
Offline KyTreeFarmer
Re: My Belsaw
« Reply #1 on: March 17, 2012, 06:53:06 PM »
Congratulations smiley_clapping smiley_clapping, nothing like seeing your hard work come together into a working mill.
KTF
Woodmizer LT15G
Belsaw from Sears & Roebucks
8N Ford
87 Kubota 2550 W/FEL
Offline bandmiller2
Re: My Belsaw
« Reply #2 on: March 17, 2012, 09:41:29 PM »
Thats good news Chris.Cappy Crunch is our go to Belsaw guy.Frank C.
Offline reride82
Re: My Belsaw
« Reply #3 on: March 19, 2012, 03:48:25 AM »
Thats great Chris! I don't know how big of a deck would be required for an entire afternoons sawing, but mine holds about 20 feet of logs and it doesn't take long if things are running good. Congrats on another Belsaw up and running!  8)
'Do it once, do it right'
'First we shape our buildings, then our buildings shape us'
Living life on the Continental Divide in Montana
Re: My Belsaw
« Reply #4 on: March 19, 2012, 12:50:04 PM »
I put the logdeck together and its 8 feet wide and 18 feet long. Have 3  4x6 timbers on
top with channel iron on top of that.
I have to make the gates that go on the inside end by the mill.
I think i will also make the rollers on this as well because you should not roll the log toward the back.
I have gotten into the habbit of rolling the logs toward the logdeck on my Jonsered mill
this makes it easier once you get the hang of it.
  Regards Chris
JD M tractor
MF skidloader
Jonsered chainmill
Vintage Belsaw
belsaw m14
Started by mmartone on Sawmills and Milling
Last post September 22, 2013, 08:32:14 PM
by bandmiller2
New kid with an M-14 Belsaw, need help!
Started by robshepler on Sawmills and Milling
Last post November 25, 2019, 01:14:23 PM
by captain_crunch
belsaw
Started by kmdfarm on Wanted
Last post November 09, 2019, 08:49:12 PM
by Remle
Belsaw m14
Started by Mark K on Sawmills and Milling
Last post June 11, 2012, 03:45:43 PM
by Mark K
