downloading sketchup plans questions
Started by Jim_Rogers, March 22, 2012, 09:02:29 AM
Jim_Rogers
I don't know if any of you can help me with this problem or not.
It seems that now, not before, when I download a sketchup plan from the plan section of the timber framing section, the name and type of file always get changed to "index.php"
I don't know why this happens and I have to rename it every time to the name the poster gave his plan.
I am using firefox and I was wondering if there is a setting that got changed and that I can change back to download these plans correctly.
I think this also happens with pdf files.
Jim Rogers
I believe that is a bug in firefox 8. Have you tried to update your browser? I'm currently running 11.0
Jim_Rogers
Ok, I see that I am running eight.
Are you happy with 11?
I thought I downloaded some update and wasn't happy with it and rolled back my version, but my memory isn't what it used to be. And I maybe thinking about something else.
Jim Rogers
11 doesn't seem any different than the earlier versions. As one point fire fox changed the way it looks by putting the tabs on top and losing the visible menu in favor of a hidden one in the corner, but you can change all those things to make it look and feel like you want under view/toobars/customize.
Jim_Rogers
I just updated to 11 and downloaded the same plan again and it worked correctly this time.
Thanks for your advice.
The forestry forum saves the day again.....
Jim Rogers
